Question about Sony Computers & Internet
Need to install memory upgrade on a,
Is this something that needs a tech?, where do I find the slot to install it?
    President:
  • 2,692 Answers
No . You should be able to do it. Go to the SONY website , find you producrt and download a manual which will show you how.
http://esupport.sony.com/
Posted on Jan 17, 2009
How to replace RAM in Satellite M45-S165
http://www.irisvista.com/tech/laptops/ToshibaM45/Satellite_M45_disassembly_1.htm
You can click on any photo to enlarge it.
Step 3 photo shows the Memory Compartment.
Two ram memory (SO-DIMM) can be used. There are two ram memory slots.
1GB however, IS the largest amount for EACH slot.
Regards,
joecoolvette
Apr 14, 2012 | Toshiba Satellite M45-S165 Notebook
Purchased two sticks of 1 G memory, want to upgrad...
Assuming you purchased the correct memory and you have two open memory slots it is very easy. Just open the computer case and look on the mother board for memory cards that look like the ones that you purchased. If there are two empty slots you just need to insert the cards into these slots (just ensure that you ground yourself before touching the cards or the mother board by anti-static band or at least touching something metal first).
When you boot up assuming the bios is fairly current should recognize the new memory and you should be good to go.
May 20, 2010 | Computers & Internet
Please advise how to install additional memory into a Toshiba Tecra A3. Is it something a layman can do or must it be taken to a computer store. Many thanks
Generally it is very simple. You need to find where the upgradable memory slot (s) are. This is generally under a panel on the base of the laptop. Unscrew the panel and, all being it's the correct panel, you will see the memory. There is normally a clip on either side, push these back and slide memory out. Replace with a bigger memory. There may even be an empty memory slot.
Only two things to watch out for, one is that your computer can take the memory upgrade (check Toshiba website) and secondly that you buy the correct memory (pins have to be in same place).
Well within the grasp of anyone that can use a screwdriver.
Feedback is always appreciated.
May 02, 2009 | Toshiba Tecra A3 Notebook
Upgrade Sony VGN-S580 to 2GB memory
flip the notebook upside down and disconnect the power adoptor and remove the battery from the notebook and you will have a flap showing a rectangle shape open that flap and hold the memory in45deg in the slot and press the memory in and it will get lock in the slot
Mar 12, 2009 | Sony VAIO VGN-S580P Notebook
Memory upgrade for Acer Aspire 3680
Each memory slot can hold DDR2 PC2-5300 with a maximum of 1GB per slot so you can install modules one at a time, and you can mix different densities of modules in your computer. But if your computer supports dual-channel memory configurations, you should install in identical pairs (preferably in kits) for optimal performance How much memory your Windows OS will recognize depends on which version of Windows you are running. 32-bit versions of Windows will see (and utilize) only 3GB or 3.5GB. To utilize more memory, install a 64-bit version of your OS hope this helps pls appreciate by rating as fixyaa.thanks and Godbless.
Jan 07, 2009 | Acer Aspire 3680 Laptop
Installing Memory
Hi
Yes, you can replace/upgrate the memory module under the keyboard.
Before you proceed, note that Dell Inspiron 2650 uses DDR200 3.3V SODIMM modules. Also, memory module capacities supported are 128MB and 256MB with a Maximum memory of 512MB. If the current memory installed is 128MB, you need to order 2x 256MB modules to replace/upgrade both memory slots. If the installed capacity is 256MB, you just need another 256MB for the slot underneath the laptop.
Check "Removing the Keyboard" for guide removing the keyboard to access the 2nd memory slot.
Read "Preparing to Work Inside the Computer" before committing to the above procedure.
Let me know how you get on.
Mike
May 24, 2008 | Dell Inspiron 2650 Notebook
Zlatko
Your laptop can have up to 1 GB of memory. You should have two slots and you can install 512 MB per slot. Your laptop is using 200 Pin DDR PC2100 266 MHz CL 2.5 SODIMM. You can also install PC3200, but your laptop will clock it down to 266 MHz.
Regards,
Feb 27, 2008 | ASUS A2H (A2HOB) Barebone
Computers & Internet Logo
21 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
