Question about Maytag M7DH45B2A Dehumidifier
My dehumidifier does not come on automatically.
After i press temperature and humidity; which i don't have a manual because it was for my grandmother, and she doesn't know where the manual is. I'd like to know exactly what is that I am doing wrong. What should I be doing first. model# m7dh45b2a
  • kathy1818 Apr 30, 2009
    All the lights are on the unit and it does not come on. I do not have the manual as I bought this second hand.
    Problem Solver:
  • 10 Answers
Power button on mne is on the far left of the control panel.
Posted on Mar 10, 2009
What are the recommended settings as far as % of humidity and room temperature? Does this set automatically?
Humidity is said to be good at 50% RH and temerature at 77*F. Air looses humidity when it is heated or cooled. Extremely humid conditionals it difficult for air conditioners to cool the air.
The temperature to be comfortable in varies from person to person.
Aug 11, 2017 | Dehumidifiers
I've been reading the other questions on this website. Like many others, our 54501 dehumidifier turns on and all controls still work. We just cleaned the filter but it does not collect water. I read...
No, it may mean that you don't have the humidity extraction level set low enough. The lower the setting, the more humidity it will extract. Try setting the extraction level at 35%, to see if the compressor turns ON.
If yours is being used in a basement, the ambient air temperature at floor level is between 40 - 60 degrees. Dehumidifiers do not work well between those temperatures (Unless, you have a Low Temp Unit). This applies mainly to where the air temperature at floor level is colder than at shoulder level in basement applications. Raising the unit up off the floor, onto a sturdy table, counter top, etc, that can handle the weight of the unit, plus a full tank of water, will usually resolve this problem.
I hope this helps you further troubleshoot & solve the problem. Thanks for choosing FixYa.
Jul 25, 2011 | Kenmore 54501 Dehumidifier
I have a 2 year old Frigidaire dehumidifier model FDM7051 and this summer when I turned it on it runs continuously with the fan moving normal amounts of air. The air filter and coils are clean and I have...
Don, unless your dehumidifier is a Low temperature model, that very well may be the problem.
The air temp in a basement at floor level is colder than that chest level. Dehumidifiers don't work well at temperatures at 40 degrees F or less. Raising the unit up off the floor on to a sturdy table, counter top, etc, that is strong enough to handle it's weight, plus a full tank of water, will generally solve the problem. The higher up you can safely put it, the better. Also, lower the humidity extraction level to 35%. As 50% is just not low enough in a basement application.
Hope this helps you to solve the problem.
Jul 20, 2011 | Frigidaire Dehumidifiers
What is the proper setting for the Temp &Humidity?
Set the temp level at whatever point your home's temperature is now. Lower the humidity level to 35%. If you don't have an LED screen on your unit, set the manual control to maximum.This way, you will extract the maximum amount of humidity and make your home more comfortable.
Hope this helped you. Please let me know. Thanks.
Jun 29, 2011 | Fedders A7DH45B2A Dehumidifier
The dehumidifier shut off automatically but will not come back on. Model M7DH45B2A
If the unit shut off automatically, because it had reached the humidity extraction level you had it set on. It won't turn back ON again, until the humidity level rises above the setting you have it on. Lowering the humidity extraction level to 32 -35%, should make it start up again and cycle like it should. If your unit does not have an LED Screen, set the manual control on Maximum.Be sure the bucket is not full and the air intake filter is clean.
Hope this helped you to troubleshoot and solve the problem.
Jun 28, 2011 | Fedders A7DH45B2A Dehumidifier
DDR2504 dehumidifier has always worked well. Now the fan runs and all seems normal, but the humidity is not dropping and you can tell that the dehumidifier is not cutting in and out. I do not have it on...
derkfarm - It may simply be a case of the humidity extraction level being set to high and/or the air intake filter needs to be removed and cleaned.
Solution: Lower the humidity extraction level to 32 - 35% and clean the air filter.
If the unit is in a basement, the ambient air temperature at floor level is colder than at chest level. Dehumidifiers don't work well at temperatures between 40 - 60 degrees F.
Solution: Set the unit up off the floor on a sturdy table, cabinet, counter top, etc. It must be sturdy enough to handle the weight of the unit, plus a full tank of water and the vibration, while in operation.
Any or all the simple solutions above may solve the problem. But, we won't know, until you try them.
Please let me know if it helped or didn't solve the problem. Thanks.
Jun 15, 2011 | Danby DDR2504 Dehumidifier
I have West ponte Mdf 65 Ae BA8 dehumidifier 1 year old. Filter is clean. It worked last summer but now after the winter it is running fine but no water is comming in the bucket eventhough basement is...
You may have the humidity/moisture level set to high. Try lowering it to 35%. Or if you don't have a LED Screen on your unit, turn it to maximum.
In addition, most dehumidifiers don't work well if the air temperature is between 40 & 60 degrees F. Keep in mind, the temperature at floor level in a basement is colder that the air temperature at chest high level. Raising the unit up, off the floor on something sturdy enough to handle the weight (with a full tank of water) and the vibration, may help.
Hope this helps you to troubleshoot and solve the problem. Please let me know. Thanks.
Jun 03, 2011 | Dehumidifiers
FAN AND COMPRESSOR START. HUMIDITY SET AT 30, ALWAYS RUNS. NO WATER IS CONDENSED. PAIL STAYS EMPTY. CLEANED FRONT AND BACK OF COILS, REALLY ONLY FINS,CAN'T GET TO COILS WITHOUT HAVING TO DO A...
Rather than have you disassemble the cabinet to get to the coils, I want you to do an "At Home Test".
Move the dehumidifier to a bathroom that has a shower. Plug it in, Turn it ON and set the humidity level at 30%. Turn the shower on to medium hot (enough to generate some steam. Do Not turn On the bathroom exhaust fan. As you leave the bathroom close the door. Wait 15 minutes and return to the bathroom. Turn the shower OFF and inspect the unit's water collection bucket for water. If you find any, the unit is working as it should. If you don't find any water, it may be that the humidity sensor has failed or the air intake filter is clogged. In which case, remove the filter and clean it. If it's the sensor, unless you are really DIY savy, I'd recommend buying a new dehumidifier. As finding the part (your unit was made by Fedders), the cost of the part and the labor involved, to me, out ways repairing it.
Now, on the positive side ... If you saw water in the bucket after the bathroom test. It may simply be, that at this time, there is not enough humidity in the room air (even at 30%) to trigger the sensor. If the unit is in a basement, the air temp (60 degrees or lower) will affect it. As the temperature at floor level (where the unit is) is 5 to 8 degrees colder than the air temperature. Dehumidifiers don't work well in cold temperatures.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
May 18, 2011 | Maytag M7DH45B2A Dehumidifier
Programming timer
SETTING THE MACHINE TO TURN ON
1. Make sure the dehumidifier is plugged in but turned off.
2. Press the button with the clock symbol below it.
3. Press the up arrow to set how many hours until you want the machine to turn ON. If you have pressed the button for more hours than you wanted then press the down arrow to lower the number of hours.
4. After you have stopped pressing the arrow buttons the display will return to the original display showing temperature and relative humidity.
5. After the above steps are completed the dehumidifier will turn ON in the number of hours that you have set (programmed).
SETTING THE MACHINE TO TURN OFF
1. Make sure the dehumidifier is plugged in and running. You should hear the fan blowing for sure.
3. Press the up arrow to set how many hours until you want the machine to turn OFF. If you have pressed the button for more hours than you wanted then press the down arrow to lower the number of hours.
5. After the above steps are completed the dehumidifier will turn OFF in the number of hours that you have set (programmed).
Jun 21, 2010 | Danby DDR5009REE Dehumidifier
Frigidare Dehumidifier will not turn off
Pressure and temperature is directly related with refrigerants in the system. Ice building on part of the coils shows that the pressure inside the system is low and the system has lost some of its charge. Very low humidity with a low ambient temperature will also cause such a problem.
Jan 10, 2008 | Frigidaire FDL45P1 Dehumidifier
Maytag M7DH45B2A Dehumidifier Logo
201 people viewed this question
Top Maytag Dehumidifiers Experts
Bill Long
Steve
Mike Squire
Are you a Maytag Dehumidifier Expert? Answer questions, earn points and help others
