Question about Sony Xplod XM-1652Z Car Audio Amplifier
Hot amp why does my amp shut off when it gets hot?
  • leo14 Feb 07, 2009
    i got a red light and then the amp shut off
  • 4 Answers
To avoid an electrical fire.
Posted on Jan 17, 2009
Water does not get hot on a hot wash
Shut off the water. Disconnect & check the BOTH water supply hoses at the MACHINE to check for obstructions / kinks / etc: Check for and clean any strainer / filter on the hoses and inlet to the washer. Direct the hoses into a tub or other container and turn water ON. make sure you have water flow from BOTH hoses and that one is HOT and the other is COLD. If OK, reconnect to machine. Turn water back ON. Choose a WARM wash.
If you get COLD only, you probably have a bad HOT solenoid - if HOT only you have a bad COLD solenoid. Be sure by:
Shut water off and swap hose connections (hot to cold & cold to hot) and try again.
If you get COLD only, you probably have a bad COLD solenoid - if HOT only you have a bad HOT solenoid. If you get HOT only, you probably have a bad COLD faucet / hose - if HOT only you have a bad COLD faucet / hose.
Replace the bad solenoid as needed. Good luck!
Sep 28, 2015 | Hotpoint WMA48 Front Load Washer
Amp gets hot and shuts down
Time for a bigger amp or better wiring to the amp. You can try a cooling fan setup to cool the amp. Brushless computer fans work pretty good, draw very little current and move quite a bit of air and they're really cheap to buy.
Dec 18, 2013 | Kicker Car Audio & Video
Amp kicks off after a few minutes of play. It will play again after a few minutes, but then kicks off again.
My best guess is that your over loading the amp. Check and see if the amp is hot when it cuts off. Most amps have a "safety" cutoff that will shut it off if it get to hot
Oct 26, 2010 | Sony Xplod XM-554ZR Car Audio Amplifier
Mtx thunder 6152 is getting way to hot and shuts its self off when it get really hot
okay, first thing i would do is turn down your gain. Sounds like you are over working the amp thats wire your amp gets hot and shut off, it's going into protection mode. Is your amp enough for your subs. Some times not getting enough power to your amp might do this too. But if your subs wattage is way over your amp watts, you need to upgrade your amp. Also check your subs and see how the are wired up with the ohms, And see if your amp can take a 1 ohm stable load or how ever it's wired up at. hope this was helpfull.
May 13, 2010 | MTX Thunder 6152 Car Audio Amplifier
Motor gets hot & the thermal cut-out shuts
one of the windigs in the stator has an open circuit
Nov 17, 2009 | Pool & Spa
Amp getting hot and shutting off
no mine do that and its pretty much normal
Jun 06, 2008 | Insignia 600W Bridgeable Amplifier with...
Sond gone
sounds like an internal problem. first disconnect all spks from amp, then switch on head unit and check if amp turns on (LED ON?) then feel the heatsink, if heatsink gets terribly hot then amp has internal fault. if amp doesnt get hot then try connecting a single working speaker to each channel separately, it may occur that one channel is faulty only. amps can shut down if the speaker/s is faulty as well, check all speakers and spk wires for shorts before taking amp in for repair. cheers
Aug 04, 2007 | MTX Thunder 8302 Car Audio Amplifier
Sony Xplod XM-1652Z Car Audio Amplifier Logo
37 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
