Question about Tamron Macro 90mm f/2.5 Manual Focus Adaptall Lens
Tamron 90mm 2.5 adaptall man focus lens
Would the 90mm man focus lens work on a Nikon D70s with the correct adaptall mount. Would accept no af or metering and what would the correct Nikon mount be hoping you can assist.
Kind Regards
John Carey
  • 11,896 Answers
You probably have to set the aperture manually on the lens, because it might not have CPU contacts. I think changing the aperture on the camera will probably have no effect, so just try twisting the aperture ring to wide open.
You usually have to set the aperture at the minimum setting (highest number) so that if the camera is choosing the aperture, it can stop down to the required value.
No good having it set at f2.8 if the shot needs f11.
If the lens is very old, it might have a manual iris that you have to set yourself on the lens. The lenses that stop down automatically will have a tiny peg on the mount that a suitable camera can operate. Gentle pushing of this peg while looking through the lens will tell if it is stopping down - set it wide open first.
If you have a depth of field preview button, this will also have the same effect with the lens on the camera if the body matches up with the lens.
Posted on Jan 17, 2009
  • Nate Stansfield
    Nate Stansfield Jan 17, 2009
    I have had very good luck with the following Nikon lenses on my
    D70:
    AF Lenses:
    12-24mm f/4
    18-70mm kit lens
    80-200mm f/2.8
    35mm f/2
    50mm f/1.8
    60mm f/2.8
    Manual Lenses:
    70-210mm E Series
    75-150mm E Series
    100mm E Series
    Good luck and enjoy!
"I also purchased a Fotodiox Lens Mount Adapter, Tamron Adaptall II Lens to Nikon Camera. The Tamron lens still will not fit
What mount do you have on the Tamron lens? (The built-in mount.) If it has a Nikon mount, you don't need an adapter at all. If it has the Adaptall mount then the adapter should fit onto the back of the lens, then the combo should fit onto your Nikon camera. If the lens has a different mount then nothing you can do will make it fit.
Does the adapter fit onto the lens?
Oct 16, 2013 | Tamron Cameras
I own a Tamron SP 80-210 adaptall II len with Pentax mount. I currently own a Nikon 7000. Can I use the Tamron with the Nikon by adding a adaptor? Any suggested adaptor I should be using? Thanks
Hi, The focal distance on Pentax camera's is different then the focal distance on Nikon's so because of that Pentax lens' can't be adapted to work on a Nikon camera. I'd suggest finding a similar lens with a Nikon mount as cross brand mounting is quite difficult.
Sep 09, 2011 | Nikon D7000 Digital Camera
Can I use Quantaray AF 28-90mm f/3.5-5.6 in a NIKON D5100? Thanks.
Quantaray makes lenses with a variety of mounts for a variety of cameras. A lens with a Sony mount, for example, will not fit onto a Nikon camera. Assuming the lens has a Nikon mount, it will fit on the D5100. However, the D5100 requires the lens to have an autofocus motor. If the lens does not have such a motor then it will not autofocus. It will still work fine as a manual focus lens.
Jun 19, 2011 | Quantaray AF 28-90mm f/3.5-5.6 Lens for...
Wil the Tamron AF 80-210mm 1:4.5-5.6 fit on my Nikon D3000 and if so how does it perform?
Assuming the lens has a Nikon mount, it will fit on the D3000. Tamron makes their lenses with a variety of mounts, so that one with a Canon mount, for example, won't fit onto a Nikon body.
This lens lacks an autofocus motor so you'll have to focus manually. Other than that, it will work fine. It's not the sharpest lens available, but it's also not the most expensive.
Apr 05, 2011 | Tamron 80-210mm f/4.5-5.6 Lens
Tamron Macro 90mm lens r07 error on Nikon D70S - any ideas how to fix?
Having gone over threee months without a response, I assume this is no longer a problem.
Apr 11, 2010 | Tamron Macro 90mm f/2.5 Manual Focus...
75-250mm F3.8-4.5 tamron lens compatible to a
As long as you can get the correct Tamron Adaptall 2 mounting for it, then it will fit. They're no longer made and not always easy to obtain at reasonable prices.
Adaptall 2 mounts for Minolta autofocus were never made, but the earlier MD mounts were, and they will fit any Minolta or Sony SLR. Obviously, there will be no autofocus but you will also find that you have to focus with the aperture ring wide open and then manually meter and take the shot after you have selected the aperture which you require.
Feb 16, 2010 | Konica Minolta Maxxum 50 QD with 28-100...
I bought a used Nikon D60 from a friend, used it a
Christine
Is it a Nikon mount indeed. What a question!?! Couldn't fit any other mount on the camera!!! Just a guess here, the lens is probably not aa AF-I, an AF-S or a DX lens. The D60 has limited lens usage. The lens types mentioned are the only ones that fully work on the D60. It will work with G types as long as they are also AF-I or AF-S. AF and AF-D lenses will not auto focus. Hope this helps. Will
Jul 10, 2009 | Nikon D70s Digital Camera
Detaching Lens Hood
I'm not sure of the exact model number of your lens, but the hood should have a bayonet flange and rotating it in one direction or the other should allow it to then simply pull off.
Nov 12, 2008 | Tamron Macro 90mm f/2.5 Manual Focus...
Tamron 28-300mm Model 185D Auto Zoom on Nikon d40
Autofocus function on the D40 only supports lenses with the
AF-S feature, which have an autofocus motor built into the lens,
instead of using an autofocus motor drive built into the camera.
The Tamron lens you have, does not have a built in motor and
the autofocus function relies on the motor drive in the camera.
It will not work with the D40 or D60, but it will work with other
Nikon digital SLRs, such as the D80. Need to get an AF-S
type lens or upgrade to different Nikon digital SLR. Unless
you do this, you will have to manually focus the Tamron lens.
All of the Nikon DX (for digital) series lenses are also AF-S
type, so they will work with the D40, which is designed as
an entry level digital SLR, therefore it is intended primarily
for use with DX lenses, which are typically sold in a kit with
the D40. Most common one is Nikkor 18-55mm DX AF-S.
Other Nikon AF-S lenses made for film cameras (FX type)
will also work with the D40, but these tend to be expensive
professional models. DX series lenses tend to be more
affordable. You might consider the 18-200mm DX AF-S
as an alternative to the Tamron, but these are not cheap.
Apr 19, 2008 | Tamron 28-300 MM XR AF F/3.5-6.3 LD ASP...
Tamron Macro 90mm f/2.5 Manual Focus Adaptall Lens Logo
425 people viewed this question
Top Tamron Cameras Experts
Steve
Jerry Greenberg
Jerry Greenberg
Are you a Tamron Camera Expert? Answer questions, earn points and help others
