Question about Brother GX-6750 Typewriter
Margins how to undo the margins
    Novelist:
  • Brother Expert
  • 297 Answers
Http://www.brother.ca/en/products/pdf/manuals/GX6750-UG.pdf
Section 4 on page 2 describes how to set the margins.
Posted on Jan 18, 2009
Cannot type further even margin released
Check to see if it is on Auto Return. If so undo and it should type to the end of the page. Typically Electronic Typewriters functions are a code Key + the green symbol underneath the Character Key. Hope that Helps
Oct 22, 2013 | Olympia Supertype 330 Typewriter
Tip
GM OBD1 Codes
DTC - 12 No distributor reference pulse (diagnostic test active)
DTC - 13 Oxygen sensor circuit open or no activity
DTC - 13 Left bank O2 sensor circuit open or no activity
DTC - 14 Engine coolant temp sensor error (high temp indicated)
DTC - 15 Engine coolant temp sensor error (low temp indicated)
DTC - 16 System voltage too low
DTC - 17 Camshaft position sensor error
DTC - 21 Throttle Position sensor error (signal high)
DTC - 22 Throttle position sensor error (signal low)
DTC - 23 Intake air temp sensor error (low temp indicated)
DTC - 24 Vehicle speed sensor error (open circuit or no activity)
DTC - 25 Intake air temp sensor error (high temp indicated)
DTC - 26 Quad Driver Module (QDM A) error
DTC - 28 Auto transmission range pressure switch error
DTC - 31 Wastegate solenoid circuit error
DTC - 31 Gear Position Switch (PRNDL) error
DTC - 32 EGR system failure
DTC - 33 MAP sensor circuit error (signal high indicating low vacuum)
DTC - 34 MAP sensor circuit error (signal low indicating high vacuum)
DTC - 35 IAC problem or idle error
DTC - 36 MAF sensor error
DTC - 36 24x Crankshaft position sensor circuit error
DTC - 36 4T60-E Shifting Error
DTC - 37 TCC brake switch circuit error
DTC - 38 TCC brake switch circuit error
DTC - 39 Clutch switch circuit error
DTC - 39 TCC error
on Sep 10, 2011 | 1991 GMC Sonoma
I cannot release the left margin on my Xerox Memorywriter 6015
When at the L. margin press the Mar Rel key not the L. mar key.
DickyO
Oct 24, 2012 | Xerox Office Equipment & Supplies
Occasionally, I still have to use a typewriter for some forms. I inherited a Xerox 6015 Memorywriter but I have no manual. Is there one online that I can download? Specifically, I'm trying to figure...
hit the carriage return key to put carriage at left margin. then hit your margin release key, then backspace key to put your carriage where you want it. then hit left margin key and that should set new left margin. good luck.
razors
Jun 06, 2011 | Office Equipment & Supplies
Windows driver
.Normal{margin:0.0pt;margin-top:0.0pt;margin-bottom:0.0pt;margin-left:0.0pt;margin-right:0.0pt;text-indent:0.0pt;font-family:"Times New Roman";font-size:10.0pt;color:Black;font-weight:normal;}H1{margin:0.0pt;margin-top:12.0pt;margin-bottom:3.0pt;margin-left:0.0pt;margin-right:0.0pt;text-indent:0.0pt;font-family:"Arial";font-size:18.0pt;color:Black;font-weight:bold;}H2{margin:0.0pt;margin-top:12.0pt;margin-bottom:3.0pt;margin-left:0.0pt;margin-right:0.0pt;text-indent:0.0pt;font-family:"Arial";font-size:16.0pt;color:Black;font-weight:bold;}H3{margin:0.0pt;margin-top:12.0pt;margin-bottom:3.0pt;margin-left:0.0pt;margin-right:0.0pt;text-indent:0.0pt;font-family:"Arial";font-size:14.0pt;color:Black;font-weight:bold;} .Normal{margin:0.0pt;margin-top:0.0pt;margin-bottom:0.0pt;margin-left:0.0pt;margin-right:0.0pt;text-indent:0.0pt;font-family:"Times New Roman";font-size:10.0pt;color:Black;font-weight:normal;}H1{margin:0.0pt;margin-top:12.0pt;margin-bottom:3.0pt;margin-left:0.0pt;margin-right:0.0pt;text-indent:0.0pt;font-family:"Arial";font-size:18.0pt;color:Black;font-weight:bold;}H2{margin:0.0pt;margin-top:12.0pt;margin-bottom:3.0pt;margin-left:0.0pt;margin-right:0.0pt;text-indent:0.0pt;font-family:"Arial";font-size:16.0pt;color:Black;font-weight:bold;}H3{margin:0.0pt;margin-top:12.0pt;margin-bottom:3.0pt;margin-left:0.0pt;margin-right:0.0pt;text-indent:0.0pt;font-family:"Arial";font-size:14.0pt;color:Black;font-weight:bold;}
The entire installation cd here: http://d01.megashares.com/index.php?d01=6b830bb. It‘s an image file that you‘ll have to burn to a cd. You can use a Nero, Imgburn, Roxio, or any program that will burn aniso image to a blank cd. Burn the cd, install the driver, and then start using your webcam!
Apr 03, 2010 | Radio Shack VGA PC Camera Webcam
How can i install my gigaware 25-157 cam if i lose the disc
.Normal{margin:0.0pt;margin-top:0.0pt;margin-bottom:0.0pt;margin-left:0.0pt;margin-right:0.0pt;text-indent:0.0pt;font-family:"Times New Roman";font-size:10.0pt;color:Black;font-weight:normal;}H1{margin:0.0pt;margin-top:12.0pt;margin-bottom:3.0pt;margin-left:0.0pt;margin-right:0.0pt;text-indent:0.0pt;font-family:"Arial";font-size:18.0pt;color:Black;font-weight:bold;}H2{margin:0.0pt;margin-top:12.0pt;margin-bottom:3.0pt;margin-left:0.0pt;margin-right:0.0pt;text-indent:0.0pt;font-family:"Arial";font-size:16.0pt;color:Black;font-weight:bold;}H3{margin:0.0pt;margin-top:12.0pt;margin-bottom:3.0pt;margin-left:0.0pt;margin-right:0.0pt;text-indent:0.0pt;font-family:"Arial";font-size:14.0pt;color:Black;font-weight:bold;} The entire installation cd here: http://d01.megashares.com/index.php?d01=6b830bb. It‘s an image file that you‘ll have to burn to a cd. You can use a Nero, Imgburn, Roxio, or any program that will burn aniso image to a blank cd. Burn the cd, install the driver, and then start using your webcam!
Jul 31, 2009 | Toshiba Installation Software
Cannot print avery labels, get message the margins of section 1 are set outside the printable page, or will run thru printer , printing complete get blank page
I assume this error is occuring in Microsoft Word.
  1. Create a new document, with a full page of the label you are having trouble printing.
  2. To see the margin settings of your document, go to File > Page Setup (or Page Layout > Margins > Custom Margins for Word 2007).
  3. Click OK on the margins dialog, and Word will check the settings against your currently selected printer. If a margin is set outside the printable area (usually the bottom margin set to zero), you should see the warning message.
  4. Click the Fix button to have Word change the margins
    to match your printer. You should now see the Margins dialog with the new margin settings.
  5. Click OK.
One thing to watch for- on some inkjet printers, the printable area is narrower than the labels. This will cause the labels to shift to the right on the page and be misaligned when you print.
If the labels run off the right edge of the page display, or are misaligned when you print, an extra procedure is needed.
  1. Undo ([Ctrl]+[Z]) the new margin setting, or create a new page from the label template again.
  2. Select the entire table of labels ([Ctrl]+[A]).
  3. Right-click the table, and select Table Properties.
  4. Click the Text wrapping "Around" option, then the Positioning button.
  5. Change the Horizontal position to Center, Relative to Page.
    Uncheck the "Move with text" option. Click OK to the Table Positioning dialog, then click OK to the Table Properties dialog.
  6. Left-click (or press an arrow key) to "deselect" the table, then go into the margins dialog (see above) and allow Word to fix the margin settings again.
With the labels aligned to the page, rather than the margins, the new margin settings should not cause the labels to shift.
Once you have the margins set correctly for your printer, I would save the empty page of labels to use as a "template".
Jun 29, 2009 | Lexmark P3150 All-In-One InkJet Printer
Brother GX-6750 Typewriter Logo
93 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
