Question about Brother GX-6750 Typewriter
How to undo margins
I need to undo the margins
    Novelist:
  • Brother Expert
  • 297 Answers
Http://www.brother.ca/en/products/pdf/manuals/GX6750-UG.pdf
Section 4 on page 2 describes how to set the margins
Posted on Jan 18, 2009
Cannot type further even margin released
Check to see if it is on Auto Return. If so undo and it should type to the end of the page. Typically Electronic Typewriters functions are a code Key + the green symbol underneath the Character Key. Hope that Helps
Oct 22, 2013 | Olympia Supertype 330 Typewriter
I cannot release the left margin on my Xerox Memorywriter 6015
When at the L. margin press the Mar Rel key not the L. mar key.
DickyO
Oct 24, 2012 | Xerox Office Equipment & Supplies
Occasionally, I still have to use a typewriter for some forms. I inherited a Xerox 6015 Memorywriter but I have no manual. Is there one online that I can download? Specifically, I'm trying to figure...
hit the carriage return key to put carriage at left margin. then hit your margin release key, then backspace key to put your carriage where you want it. then hit left margin key and that should set new left margin. good luck.
razors
Jun 06, 2011 | Office Equipment & Supplies
How do I type to the end
To reset the margins you need to first release the margins. Once you have released the margins you will be able to set the left and right hand margins.
Thanks,
Pat
May 12, 2010 | Brother GX-6750 Typewriter
Changing margins
To change or reset margins, the keys involved are the ALT key to the left of the spacebar, the #keys 3,4, & 5.
The ALT & '3' keys are used to bypass the set margins.
To bypass the left margin, move the carrier to the left margin. Press the ALT & '3' keys at the same time. Release them then backspace the carrier to the point the new margin is wanted. Press the ALT and '4' keys at the same time to set the new left margin.
To bypass the right margin, move the carrier to the right margin. Press the ALT & '3' keys at the same time. Release them and spacebar to the point where the new right margin is wanted. Press the ALT & '5' keys to set the new right margin.
The main thing to remember is to move the carrier to the point where the new margin is needed. ALT + 3 bypasses old margins, ALT + 4 sets the left margin, & ALT + 5 sets the right margin.
Feb 24, 2010 | Brother SX-4000 Typewriter
Right Margin: I need to move the right margin.
Space bar to where the current right margin is. Press "margin release" key once. Space bar to where you want right margin to be. Press "margin right" once. This should work.
Aug 20, 2009 | Brother ML-100 Typewriter
Cannot print avery labels, get message the margins of section 1 are set outside the printable page, or will run thru printer , printing complete get blank page
I assume this error is occuring in Microsoft Word.
  1. Create a new document, with a full page of the label you are having trouble printing.
  2. To see the margin settings of your document, go to File > Page Setup (or Page Layout > Margins > Custom Margins for Word 2007).
  3. Click OK on the margins dialog, and Word will check the settings against your currently selected printer. If a margin is set outside the printable area (usually the bottom margin set to zero), you should see the warning message.
  4. Click the Fix button to have Word change the margins
    to match your printer. You should now see the Margins dialog with the new margin settings.
  5. Click OK.
One thing to watch for- on some inkjet printers, the printable area is narrower than the labels. This will cause the labels to shift to the right on the page and be misaligned when you print.
If the labels run off the right edge of the page display, or are misaligned when you print, an extra procedure is needed.
  1. Undo ([Ctrl]+[Z]) the new margin setting, or create a new page from the label template again.
  2. Select the entire table of labels ([Ctrl]+[A]).
  3. Right-click the table, and select Table Properties.
  4. Click the Text wrapping "Around" option, then the Positioning button.
  5. Change the Horizontal position to Center, Relative to Page.
    Uncheck the "Move with text" option. Click OK to the Table Positioning dialog, then click OK to the Table Properties dialog.
  6. Left-click (or press an arrow key) to "deselect" the table, then go into the margins dialog (see above) and allow Word to fix the margin settings again.
With the labels aligned to the page, rather than the margins, the new margin settings should not cause the labels to shift.
Once you have the margins set correctly for your printer, I would save the empty page of labels to use as a "template".
Jun 29, 2009 | Lexmark P3150 All-In-One InkJet Printer
I have a typewriter brother I have a typewriter brother ML300 and I cant figure how to ajust the margin.....please help
Left Margin:
Move the carrier to the place you want to set the left margin by using (SPACEBAR) or (BACKSPACE). If you need to move outside the current left margin, press (ALT) + (M REL) (3). Press (ALT) + (L MAR) (4). The left margin is now set.
Right Margin:
Move the carrier to the place you want to set the left margin by using (SPACEBAR) or (BACKSPACE). If you need to move outside the current right margin, press (ALT) + (M REL) (3). Press (ALT) + (R MAR) (5). The right margin is now set.
Hope this helps!
Jay @ www.granadahillsbusinessmachines.com
Feb 06, 2009 | Brother ML-300 Typewriter
Margins
http://www.brother.ca/en/products/pdf/manuals/GX6750-UG.pdf
Section 4 on page 2 describes how to set the margins.
Jan 17, 2009 | Brother GX-6750 Typewriter
Brother GX-6750 Typewriter Logo
120 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
