Question about Canon PowerShot S2 IS Digital Camera
How to turn on my Protege PC Link and does it require a battery
I have had this thing for years and found it tucked away last nite and tried to load the software...i think i did that right! not for certain...but how in the world would you turn this thing on i thought it was the button at the bottom and also, do it equire batteries...the reg no is 2097855...please help this old school momma get into the new school with this device i have...HELP~~~ thanks jc.
  • 944 Answers
Here is the link to the user manual, FAQs, support and troubleshooting, updated software downloads etc; (just click on product/software manuals and follow the instructions to download the user guide first); http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=322&modelid=11368 Have a read and then please ask again if you need help with anything :) good luck, it's a good camera if it still works.
Posted on Jun 22, 2007
SOURCE:
Since it got freezing last nite & now it won't
If the engine will not turn over very fast,it is most likely your battery.Cold weather will kill a weak battery a lots of times.
Dec 29, 2012 | Cars & Trucks
The battery is good but it wont start
It may be the solenoid (electro-magnetic clamp) that engages the starter motor with the flywheel to start the car. Unfortunately, this usually involves replacing the entire starter.
Jun 14, 2012 | 2008 Pontiac G6 Sedan
Hi I have just been given a loan of a heartway mobility scooter. It was only used once but the lady found it to fast so it has been packed away for 2 years. I sent it off for new batteries and a service...
Willis try plugging in the charger and charging overnite tonite. In the morning check the charge and see if you get more than 3 bars. Also look at the charger light and see if it has turned green. If it is green then the lights should all be lit, if not then you could have received a bad battery. after charging all nite bring the scooter to the place that serviced it for you and have them check the batteries to make sure that they pass a load test (do not try to drive the scooter they need to check the batteries with a full charge) If the batteries check out ok then you will have to have them check the charger and replace the charger if necessary. Hope this helps you
Mar 01, 2011 | Health & Beauty
Not turning over, no sound from radio battery is origioal
Have you checked to see if the battery is charged?
If it's sufficiently charged, is the fuse(s) running from there all intact and working? (check with a meter, sometimes they don't "look" like they're bad..)
If you have just a little charge, but not enough you'd hear the starter at least trying to engage, even if it can't turn it over.
If you don't have radio, lights, nothing, then I'd be looking at the battery and the fuses closely. You may want to actually check the book on what fuses you should find, because some of them are not obvious, or all in the same place, like in a car. I've found them tucked away behind panels or behind the battery and the only reason I found them was I knew it was there and kept looking until I did.
If you leave your scooter hooked up in the cold weather but don't start it, or don't hook a battery-tender to it, then it can suffer for it and have reduced capacity over time. I used to ride mine most of the year so I started it regularly, even in the winter (Kentucky), but I have had friends who lose batteries because they just store them, cables hooked or not, and leave them for months at a time.
Heat and sitting idle on a shelf or in the bike can take their toll on the battery. If you actually show a charge on the battery on a meter it still may not have the "power" to turn the bike over. In that case I'd use a "load meter" which puts a load on the battery while it measures that performance and I can see if it'll hold up or not. But again, in this case you're not getting much coming on that you can see or hear, so I'd still look at the battery and the fuses.
Many auto parts stores will load check that battery for you for free if you bring it in to them.
Good Luck!!!
:o)
Jan 02, 2011 | Harley Davidson FLHTCUI Electra Glide...
Startup not happening
try replacing both batteries, not just one
this things old ' 14 years old in fact.
some have a tiny coin cell battery to inside./
why expect any battery to last that long?
HP ended support long ago (after 10 years it ends)
did you ask on HP forum first and not here, we are NO HP here.
here is real HP , this is not spam or the link its the real deal
https://h30434.www3.hp.com/
Feb 07, 2018 | HP iPAQ RZ1710 Pocket PC
Won't start
disconnected the battery last nite, reconnected this morning, started right away.
I noticed a cell phone charger was plugged in, I am hoping this is the thing that was draining the battery, if not, will look further.
Jul 06, 2009 | 2004 Chevrolet Silverado 1500 Crew Cab
I need a diagram on How to change a Serpentine belt for a 97 mazda protege
Have you checked Autozones website? Thats where I usually go to get all the details and diagrams I need
Oct 25, 2008 | 1997 Mazda Protege
Sony ericsson w910i
remove Battery and then try again
Oct 05, 2008 | Cell Phones
How do i turn on my protege pc link and does it require a battery
Jean, yes this does take 2 "cr2025 lithium" batteries, which are pretty easy to find anywhere that sells watch batteries. However, when I purchased mine it had a plastic tab sticking out of the back of it, from under the battery access cover, which was blocking the batteries from making contact to prevent them from draining before first use, so you might want to check if there's a piece of clear plastic sticking out of the back and if so, just pull it out. If that's not the case, then odds are the batteries did drain while sitting and you'll need to replace them. Hope this helps, Scott
Jun 22, 2007 | Canon PowerShot S2 IS Digital Camera
Canon PowerShot S2 IS Digital Camera Logo
61 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
