Question about Danby DDW1805W Designer Series Free-Standing Dishwasher
Stuck in 'drain' mode
When you turn it on, the pump just keeps runing and it won't shut off. Stuck in 'drain' mode.
    Sergeant:
  • 378 Answers
  1. Check for hose kinks or food plugging drain hose. Start at the drain port exit (there are others, this is just an example)
  2. Check the check valve and drain hose for debris.
  3. Check pump motor for reversing during the pump out make sure the dishwasher is pausing between the wash and drain cycles letting the pump/motor reverse for the drain cycle.
  4. Check timer for not letting the dishwasher pause. ( not all dishwashers )
  5. Check pump motor assembly for a drain solenoid, during the pump out make sure the solenoid makes that distinctive "clunk" noise
  6. If you have recently installed a new garbage disposal, check knock-out plugat connection.
  7. Check pump impeller for damage.
  8. Check that the water inlet valve isn't seeping fresh water into the dishwasher when off.
Posted on Jan 17, 2009
    President:
  • 2,110 Answers
Take bottom front panel off to expose bottom tray and you will probably find it full of water. disconnect from electricity and mop water out and machine should work. if fault reoccurs then you have a leak
Where the shut-off switch is located
sorry no make or model no help can we look for .
Aug 20, 2015 | Cars & Trucks
Wont turn off/stuck in drain mode
This sounds like a washer and not a dishwasher. The rubber you are referring to is the door gasket and it needs to be replaced in your case. It has got into the pump and it's plugging it. Please remove any debris from the pump and start the unit again.
Mar 11, 2014 | Dishwashers
Machine stuck in drain mode, beeps, can only turn off at powerpoint.
Your motor controller board is faulty
needs repair or new/recondition board.
May 06, 2013 | Fisher and Paykel Fisher Paykel Intuitive...
Pump won't shut-ff
Hi Ron...
Check your float switch....sometimes they can get stuck to cause this problem of not shutting down after draining the orginal water.
Take the float switch and move it up and down...this may help to clear the stuck switch inside of the float
Bud
Apr 24, 2013 | Utilitech 1/3-HP Cast-Iron 95 GPM Sewage...
Whirpool built-in puddle of water in bottom, food on drain
see this causes and proceed according. God bless you
Belt, Water Pump Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable Pump and Motor Assembly If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Check Valve If the dishwasher won't drain the check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher.
Check Ball If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Oct 16, 2012 | Whirlpool Dishwashers
For Miele Dishwasher G2470SCVI Need help with remaining water in the bottom. Model# G2470 SCV1 SF Type-HG03. Runs through the entire cycle,long,short ect..everything is clean and dishes look great but
see this causes and fix it. God bless you
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable.
Drain Hose If the dishwasher won't drain the drain hose might be clogged. Remove the drain hose from both the dishwasher and the sink drain to clean it out. The most common place for an obstruction is at the garbage disposer.
Sep 28, 2012 | Dishwashers
Hoshizaki water dont stop runing
float switch is stuck in the "down" position. The unit goes thru a fill cycle and after 1 minute, the board "Looks" at the float swith to "see" if the sump is full. If float is stuck down, it tells the board that the unit does not have enough water and stays in the fill cycle. The compressor will not come on as long as the machine "thinks" there is not enough water. let me know if I can help further
Aug 02, 2012 | Hoshizaki Freezer Commercial Ice Machines...
On a 96 grand am the fule pump won't stop runing.
Running never stop,it not the wiring,check the power soure that give the feul pump it power.
Nov 24, 2011 | 1994 Pontiac Grand Am
Washer will not drain out water . it will turn on shut offf and switch to diffrent options but it will not drain
Check the water pump or for somthing stoping up the pump or the drain lines.could be somthing like a sock in the water line from the tub to the pump . see if the motor is runing when it should be draining
Jul 15, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Danby DDW1805W Designer Series Free-Standing Dishwasher Logo
159 people viewed this question
Top Danby Dishwashers Experts
Kevin Getz
Kevin Getz
Are you a Danby Dishwasher Expert? Answer questions, earn points and help others
