Question about kawasaki Full Suspension Mountain Bike Men
I have 750 drifter. went to start it and I have lights and electrical but when I push the start button all I get is "clicking" noise. I checked the battery charge and it is full. what else can I check?
I took the battery out and had it tested at a friends shop. Turns out the battery really only had about 9% life left and the "clicking" sound was only the starter relay trying to work. The battery has a dead cell and won't hold charge anymore. Bought a new battery and all is well!
Thanks
Posted on Jan 18, 2009
Mazda drifter double cab does not want to start after engine was pressure hosed with water
Do not wash your engine with a pressure washer,you probably ruined quite a few electric components,never ever do that.check all electrical componants.Coil pack-alternator,fuse blocks-starter-all electrical components under hood
Jan 02, 2015 | 2005 Mazda Drifter 2500
1993 Honda CB 750 Nighthawk will not turn over
Hi, Anonymous before testing any electrical component in the Starting System it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage, the battery is faulty and must be replaced. AGM type batteries fall into this scenario more so than lead acid batteries.
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter.
4. Bank angle sensor needs a reset or is faulty.
5. FOB battery low or dead.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand, clutch, neutral safety switch.
9. Security alarm needs a reset.
10. Starter relay, solenoid, starter have failed or circuit wiring faulty.
11. Starter armature or field coils have failed.
12. Main fuse or circuit breaker may be blown or faulty.
13. Faulty ignition relay.
14. The electric starter is working but starter clutch has failed.
15. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Motorcycle Message Board Motorcycle USA
What Do Check When My Motorcycle Won Start Honda Shadow Forums Shadow...
Honda Nighthawk CB 750 1991 Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda CB Owners Manuals
Jul 30, 2017 | 1993 Honda CB 750 Nighthawk
99 shadow 750 ace w/4k bought on friday bike sat so i changed oil/filter with honda approved products flushed cooling system checked all fluids and rode about a total of 65 miles performed great all...
Remove starter from engine leaving the wire conected, earth out the strter to the engine and pres the starter button, if the starter spins, it is likely you have a starter clutch problem, this test will eliminate the starter being at fault, presume u have checked battery condition
Feb 22, 2011 | 2000 Honda VT 750 C2 Shadow
I was on a ride. Stoppedf for gas, when I went to start back up, no try to start. Pushed started and off I went. Started jumping across the solinoid after that. Fouind a guy to test it out and found the...
Replace your right switch assembly. The starter button is a two position switch. Push it in halfway and the headlight goes out(more power to the starter). Push the button in all the way and the solenoid kicks in. The starter button is causing both problems.
Sep 06, 2010 | 2002 Honda VT 750 CD Shadow A.C.E. Deluxe
Starter will not engage
Either your battery is bad or a connection has worked loose. Check battery cables (both ends) and if everything is tight replace the battery.
Apr 28, 2009 | 1999 Honda VT 1100 C Shadow Spirit
I need a wireing diagram.1999 honda 750 vulcan drifter,im having problem with running lights and turn signals
Im not sure of the model. The only vulcan 750 I know is a kawasaki. Im in europe so is there an equivalent model here?
Mar 16, 2009 | 1999 Honda VT 750 CD Shadow A.C.E. Deluxe
01SUZUKI KATANA GSX 600F Bad Starter/Relay Switch~that is the ?
If there is a clicking noise when you hit the starter button, then the relay should be fine.
If there is no sound, check the fuses before removing the starter.
Jan 24, 2009 | 2006 Suzuki GSX 750 F (Katana)
Dryer will not start.. Here clicking sound when i push start button but nothing happens
Did you clean the lint screen and replace? Also - all lint should be cleaned from back of dryer and the duct...many dryer manufacturer have safety sensors that will not light dryer due to there being too much lint, not enough air flow...(safety feature) ...
Oct 09, 2008 | Kenmore 62602 Electric Dryer
Dryer clicks when start button pushed but does not start.
A quarter was lodged on the thermal fuse , located below the lint screen on the blower exhaust housing, on our dryer. Remove the front lower panel , 2 screw, and you'll see 2 fuses. I suspect that our control board is burnt.
Aug 05, 2008 | Whirlpool GEW9200L Electric Dryer
kawasaki Full Suspension Mountain Bike Men Logo
135 people viewed this question
Top kawasaki Sport & Outdoor - Others Experts
Wayne McNeil
michael
michael
Are you a kawasaki Sport and Outdoor - Other Expert? Answer questions, earn points and help others
