Question about Sony FIU-600/W Fingerprint Reader
HELP I need a tool that is able to just save the fingerprint as an image without performing matching , is it OK ?
  • 661 Answers
I'm not sure that this device works like that, however you could try to set it up like a standard scanner. perhaps windows scanner & camera wizard may help Gareth
Posted on Jul 26, 2007
SOURCE:
What is the fingerprint sensor in iPhone 5s?
A fingerprint reader or sensor is basically the first step towards getting rid of passwords. It scans your fingerprint and matches it to a pre-defined image of your finger. Since every fingerprint is unique, the system can then securely verify your identity.
If you wish to read more about the fingerprint sensor benefit: http://www.theguardian.com/technology/2013/sep/10/iphone-5s-launch-fingerprint-technology
Sep 11, 2013 | Apple iPhone 5S
Tip
Forgot or Lost Windows 7 Password - Useful Solutions You Need to Know
There are many situations in life and work which may lead to or cause password lost in Windows 7. Luckily enough, there are several useful solutions that can be used to reset Windows 7 password, for whatever reason you cannot regain access to your computer. Following are listed 6 effective methods that you can make full use of to bypass a lost Windows 7 password.<br /><br /> <img src="forgot-password.jpg" /> <br />1. <b>Perform <a href="http://www.recoverwindowspassword.com/windows-7-password-recovery.htm">Windows 7 password reset</a> with an administrator account</b>. Users of administrator accounts have full control over the Windows system. They are permitted to install software programs and hardware drivers while entitled to reset password of another user accounts(including other administrator or standard user or guest accounts password). So if you forgot a user account in Windows 7, you can try to reset it through an accessible Windows 7 account with administrator permissions. It's the easiest way.<br /> <br />2. <b>Resort to Commercial Windows password recovery tool</b>. Considering the actual needs of Windows 7 password recovery when one failed to log on computer, some software providers also offer various commercial Windows password recovery tools fully compatible with Windows 7. Here we highly recommend you try Windows Password Breaker if you <a href="http://www.recoverwindowspassword.com/">forgot Windows password</a> and needed a password recovery tool, which can help you create a bootable password recovery CD/DVD or USB flash drive to reset lost password in a few minutes.<br /> <br />3. <b>Seek for free Windows password recovery tool</b>. In addition to commercial software, free Windows password recovery software out there can also help you recover a lost password in Windows 7. If you want to recover Windows 7 password without charge, Ophcrack and NT Offline Password & Register, the most popular recovery software, may be your best choice. <br /> <br />4. <b><a href="http://www.recoverwindowspassword.com/reset-windows-7-password.html">Reset Windows 7 password</a> with Installation Disc</b>. If you have a Windows 7 installation disc, it's not a big problem for you to log on your computer again if you get its password lost. Just insert the installation disc in computer and boot to the recovery options to do Windows 7 password reset. What's more, a system repair disc that also enables you to access the recovery options. But the repair disk need to be created in advance, before your password is lost.<br /> <br />5. <b>Use Windows 7 password reset disk</b>. A forgotten Windows password can be easily reset with a password reset disk, you also need to create a password reset disk for your Windows 7 account in advance(before you lost password). Please note that many users <a href="http://www.recoverwindowspassword.com/reset-windows-7-password.html">forgot Windows 7 password</a> without having created a password reset disk. If you don't have one, please start to create one right now, you will need it some day. <br /> <br />6. <b>Bypass a lost password with Fingerprint logon</b>. Nowadays password is not merely limited to letters, numbers and symbols. It can also be your fingerprint. In Windows 7, fingerprint logon can be easily enabled if you are lucky enough to have a laptop or computer with a biometric sensor, such as a fingerprint reader. If the fingerprint logon enabled, it is easy for you to bypass a forgotten or lost Windows 7 password.<br /> <br />If you have lost your Windows 7 password, select one method of the above which adapts your conditions to reset your password. At last, i recommend you to create a password reset disk when you set a Windows 7 log on password, it's a feature in Windows for one to easily reset a lost password. <br />
on Jan 27, 2011 | Computers & Internet
How do you clean the print rollers? All my copies have a long vertical smudge/streak that runs entire length of the right side of the sheet (8.5x11 and 11x17).
It might not be the rollers but the image drum. A bad image drum will sometimes cause streaks on print outs. If you look at the right side of the image drum you will probably see a streak that matches what is being left on your paper. Be careful not to touch the image drum as it will cause fingerprint on your printouts! Of course if the image drum is bad it will need replacing and fingerprints won't matter.
Mar 01, 2011 | Ricoh Aficio AP610N Laser Printer
Can i thumbprint without the use of fingerprint scanner.can i make it online
You can't thumbprint without scanner but you can be able to thumbprint without problem, if you have the right tool like:
- installing the right driiver of your scanner
- by providing the 16 xter security key
- by having biometric license
All will be history when you have the tool in place.
Email us me on [email protected] or call 08132829820
Feb 13, 2011 | DigitalPersona UareU 4500 Fingerprint...
CSI DARK MOTIVES PROBLEM
Here is the full walkthrough
http://www.gamefaqs.com/portable/ds/file/939564/46082
If this helps please leave feedback if not please let me know and I will look further into it
Jan 11, 2009 | Ubi Soft Entertainment CSI: Dark Motives...
Download problem
here you go:
Adobe Photoshop CS3 INFO:
Adobe Photoshop CS3 software, the professional image-editing standard and leader of the Photoshop digital imaging line
Adobe Photoshop software, the professional image-editing standard and leader of the Photoshop digital imaging line, delivers more of what you crave.
Groundbreaking creative tools help you achieve extraordinary results. Unprecedented adaptability will let you custom-fit Photoshop exactly to the way you work. And with more efficient editing, processing, and file handling, there’s no slowing you down.
Create with unmatched power
Timesaving file handling with Adobe Bridge (formerly the File Browser)
Multitasking.Take advantage of compact floating mode in Adobe Bridge to process images while simultaneously working in Photoshop.
Viewing options
Easily browse your Adobe Creative Suite and other graphics files in Adobe Bridge; present your images with features like Slideshow and Filmstrip mode; scale thumbnails to any size using a slider; and view and edit metadata.
Automated batch processing
Automatically process batches of images in Adobe Bridge to rename, convert format, adjust exposure, create a web gallery or Adobe PDF Presentation, and more.
Rating and labeling
Quickly rate and label photos in Adobe Bridge so you can instantly bring up your best shots.
Sophisticated search
Easily find any image using sophisticated search capabilities in Adobe Bridge that let you specify a variety of parameters. Save searches as Collections that you can recall anytime.
Professional color and tone control
Match Color command
Achieve a consistent look between package shots, fashion photos, and more by instantly matching the color scheme of one image to another.
Color Replacement tool
Easily change the color of any image area while retaining the original texture and shading.
32-bit High Dynamic Range (HDR) support
Create and edit 32-bit images, and combine multiple exposures into a single, 32-bit image with expanded range?from the deepest shadows to the brightest highlights.
Histogram palette
Monitor color changes to your image in the Histogram palette, which dynamically updates as you make adjustments.
Shadow/Highlight correction
Quickly improve the contrast of over- or underexposed areas of an image, including CMYK images, while preserving the overall balance of the photo.
Color management guidance
Get precise, consistent color from display to output with helpful color management guidance.
Intelligent image editing
Revolutionary Vanishing Point
Achieve amazing results in a fraction of the time with the groundbreaking Vanishing Point, which lets you clone, paint, and paste elements that automatically match the perspective of the surrounding image area.
Image Warp
Easily create packaging mock-ups or other dimensional effects by wrapping an image around any shape or stretching, curling, and bending an image using Image Warp.
Spot Healing Brush
Effortlessly retouch photos?including 16-bit images?in a single click with the advanced power of the new Photoshop Spot Healing Brush.
Healing Brush
Perform expert retouching to remove dust, scratches, blemishes, wrinkles, and other flaws with minimal effort using the Healing Brush
Essential photography tools
One-click red-eye correction
Instantly neutralize red eyes with the one-click red-eye correction tool, which supports 16-bit images and lets you set pupil size and darkening level.
Optical lens correction
Easily correct common lens distortions, such as barrel and pincushion, and fix chromatic aberrations and vignetting.
Smart Sharpen
Easily counteract common image blurring with fine correction control based on the specific blur types: motion, lens, and Gaussian.
Advanced
noise reduction
Polish digital photos with advanced noise correction in high-ISO shooting plus JPEG artifact reduction.
Camera raw workflow enhancements
Process an entire photo shoot in a fraction of the time by simultaneously adjusting color, curves, cropping, and more?and continue working in Photoshop! With support for a comprehensive range of digital cameras, Photoshop lets you automatically adjust settings, convert to Digital Negative (DNG) format, and apply nondestructive edits to batches of images.
Comprehensive 16-bit support
Perform precise editing and retouching with support for 16-bit images in core features, including layers, brushes, text, shapes, and more.
Crop and Straighten command
Scan multiple images at once and let Photoshop automatically straighten and save each image as an individual file.
Design freedom
Flexible layers
Composite images, text, and effects on hundreds of layers that you can organize with up to five levels of nesting and save in different combinations as Layer Comps.
Painting and drawing tools
Create or modify images with a wide assortment of professional, fully customizable paint settings, artistic brushes, and drawing tools.
Special effects filters
Achieve amazing results with more than 95 special effects filters. Easily preview and apply more than one filter at a time from the Filter Gallery.
Advanced type control
Add vector-based text that you can edit at any time, format, warp, place on a path, convert to outlines, and use for masks or other special effects.
Advanced web capabilities
Create sophisticated web page elements with rollovers, transparency, image slicing, and more.
Web animations
Quickly create dynamic GIF animations?using one or more images?directly within Photoshop by taking advantage of the new Animations palette and layer palette animation options
Customize with unprecedented adaptability
Adaptable workspace
Custom menus and keyboard shortcuts
Set up and save custom menus and keyboard shortcuts for quick access to the features you need.
Custom, task-based workspaces
Reduce onscreen clutter by choosing from task-based workspaces, or create your own with just the tools you need.
Adobe Help Center
Quickly get answers from the new, floating Adobe Help Center window with improved search features and convenient, task-based topics.
History Log
Automatically track all editing steps within your Photoshop files. Export steps to a text file or save them as part of image metadata for easier documentation of your work, file audits, and more.
Flexible measurement systems
Enter precise numeric values in inches, pixels, and other measurement systems. Even enter different measurements on-the-fly without changing global settings
Automated image processing
Links: http://rapidshare.com/files/74640212/photo_cs3.part01.rar
http://rapidshare.com/files/74669474/photo_cs3.part02.rar
http://rapidshare.com/files/75514140/photo_cs3.part03.rar
http://rapidshare.com/files/75542536/photo_cs3.part04.rar
http://rapidshare.com/files/75575871/photo_cs3.part05.rar
http://rapidshare.com/files/75712872/photo_cs3.part06.rar
http://rapidshare.com/files/75732517/photo_cs3.part07.rar
http://rapidshare.com/files/75751914/photo_cs3.part08.rar
http://rapidshare.com/files/75762829/photo_cs3.part09.rar Pass: freshdl.com Or http://rapidshare.com/files/66187460/AP.CS3.sxforum.org.part1.rar
http://rapidshare.com/files/66199878/AP.CS3.sxforum.org.part2.rar
http://rapidshare.com/files/66212869/AP.CS3.sxforum.org.part3.rar
http://rapidshare.com/files/66254078/AP.CS3.sxforum.org.part4.rar
http://rapidshare.com/files/66276200/AP.CS3.sxforum.org.part5.rar Pass: sxforum.org
Dec 13, 2007 | Ulead CD & DVD PictureShow 3 Deluxe for PC
Laptop fingerprint reader
http://www.newfreedownloads.com/find/fingerprint.html
Jun 26, 2007 | Toshiba Satellite M105-S3004 Notebook
HELP
Are you thinking about buy one? You want to know if it will work for your needs? Ray CompuGuy44
Jun 21, 2007 | Microsoft Fingerprint Reader
Want only fingerpring password for hx2755 without rest of security overhead
You can turn off HP Protect Tools, or simply configure HP Protect Tools to not encrypt your data.
Sep 11, 2005 | HP iPAQ HX2755 Pocket PC
Sony FIU-600/W Fingerprint Reader Logo
167 people viewed this question
Top Sony Office Equipment & Supplies Experts
Jaime Hernandez
jasbo
jasbo
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
