Question about Kenmore 63792 Microwave Oven
Looking for the grill above my microwave model number 721.80823500
  • 5,911 Answers
Go to searspartsdirect.com. Type in the model number you provided and look under the "Oven Cavity Parts" heading for item number 3024. The part number is 3530W0A034D. I hope this helps you. If this is not the part you are talking about, please let me know.
Posted on Jan 17, 2009
CHANGE THE BULB
Remove the top grill assembly. It is usually held on by 2 screws going down through the cabinet top. You may need to tap the grill to the left slightly to get the tabs to release. Once the grill is off, look near the middle of the top edge of the microwave frame for 1 screw that looks like it goes through a metal lip. It will be right above the inside light bulb area. remove screw and then pull the metal tab towards you. The complete light bulb assembly will slide up and out towards you. Replace bulb and reassemble microwave.
Mar 01, 2015 | General Electric GE Profile SpacemakerR XL...
How to replace lightbulb
Is this a countertop microwave or an over-the-rang (OTR) microwave? If it's a countertop model, you need to completely remove the outer case to get to the lightbulb. If it's and OTR microwave, there usually is an access cover located behind the grill vent. You can remove that grille vent by removing the 2 to 4 screws above the grill vent. Then either slide the grill vent 1/4" to the left to remove it, or else (depending on the model), just pull out the top of the grill vent, followed by the bottom. Then you should be able to see the lightbulb access cover. Usually there is 1 screw that you have to remove. But unplug the microwave before you to any further! Now remove the screw, lift up and remove the cover, and you should be able to get to the light bulb.
Aug 10, 2014 | Kenmore Microwave Ovens
Shorted out microwave when i tried tochange lightbulb. GE model jnm1731dm1bb, where is the fuse located?
The fuse is probably located behind the grille, and it may again be behind a small panel behind the grille. Look for the fuse label when you get the grille off.
There is a video here which shows you how to remove the grille.
But chances are good that you also damaged the circuit board when you removed or inserted the bulb without first unplugging the oven, as it says on the label by the light socket.
But that can usually be repaired economically repaired.
Or you can order and install a new smart board.
For model jnm1731dm1bb (also called JNM1731DMBB01) it is part number WB27X10933 and you can get it from the Pros here for $151.56.
Aug 10, 2013 | Smeg MD6CAS Microwave Oven
Hi i have a george forman grilling machine GR10ABWG model number 10198 ,and i am looking for operating instructions and recipes,can you help,thanks very much
HELLO.
solution below.
The best place to get the GRILLING MACHINE manual guide is to visit the manufacturer website to order for the manual stating the GRILLING MACHINE model number and give our house detailed address.
However GRILLING MACHINE manual guide can also be purchase at any GRILLING MACHINE authorized dealers around your local area with the model number for compactibility(easy use).
Thanks.
Sep 20, 2011 | Microwave Ovens
I need to replace the interior bulb on my GE profile model jvm1850dm2vv microwave oven. Can I access it from the area where the replaceable filter is?
The oven interior bulb is on the top. Look closely at the grille above the door. There are two recessed screws that hold the grille in place. Remove these and carefully pull the grille straight out. You may have to wiggle it a bit - it's a tight fit on most of those I've serviced. Look in the center of the oven above the door. There is a sheet metal cover held in place with one or two screws (usually one, plus a plastic tab going into a slot in the sheet metal). Remove this screw and pull out the sheet metal. You will see the light bulb and the microwave stirring plate motor. Note that the instructions say you should unplug the oven before changing the light bulb. GE's lawyers are afraid you'll stick your fingers in the wrong place and somehow get shocked if you don't have the power removed.
Jan 31, 2011 | GE Profile Over-the-Range Microwave
How do you install the carbon filter on GE model 1540. I can not get the grill off. There are supposed to be screws but none are visible
You can download GE owner's manuals and installation instructions here.
Your full model number (
like JVM1540SMSS for example) is on the tag in the cavity of the oven.
On some models the screws are in the front of the grille, and on some models they are on the front edge of the top cover of the microwave above the grille.
If yours is the latter, hopefully the installation was done correctly so these were not covered up!
Jan 10, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Broken vent grille for a Whirlpool microwave hood combination
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
At our Web site, we have a video available showing how to remove a typical grille in seconds.
Jun 06, 2009 | Whirlpool GH8155XJ Microwave Oven
Looking to buy a top vent grille
Depends on the brand, but you can usually find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
If not, Please reply back with your brand and model number so we can help you.
Feb 11, 2009 | Amana ACO1840A Microwave Oven
Microwave oven
No personally, but the lack of results when I do a Google search concerns me!
I would look at the owner's manual and make a note of their contact info.
Hopefully they have a Web site, especially one that has good links for customer service, servicers, and FAQs and help.
If they just have a phone number listed, beware!
Aug 11, 2008 | Microwave Ovens
Front vent fell off
This should be a very easy fix. I assume you are talking about the plastic vent grill on the top of the oven above the door. There should only be a couple of screws holding it in from the top. The grill then should tilt out from the top first then from the bottom to remove. Since you said that it had fallen off, it sounds like the tabs where the screw holes are have broken off. This is a common problem. You can buy the part by ordering from the manufacturer, or from most repair websites. All you need is the model number from the microwave. Good luck.
Jun 19, 2007 | GE JVM3670 Microwave Oven
Kenmore 63792 Microwave Oven Logo
99 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Jim Thurston
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
