Question about Brother HL-2040 Laser Printer
Cartridge removal how do i take out the old cartridge
    President:
  • 2,692 Answers
How to remove the printhead from an HP 6520
Step one: Remove the old cartridges
  1. Press the Power button ( ) to turn on the product, if it is not already turned on.
  2. Open the cartridge access door. The carriage moves to the center of the product. Wait until the carriage is idle and silent before continuing. Figure 1: Open the cartridge access door c02937518.gif
  3. To remove an old cartridge, press the tab on the front of the cartridge, and then pull it up to remove it from its slot. Figure 2: Remove the cartridge from its slot c02938232.gif
  4. Repeat the previous step to remove each of the cartridges.
Step two: Remove the old printhead
  1. Lift the latch handle on the carriage until it stops. Figure 3: Lift the latch handle c01795083.gif
  2. Lift the printhead to remove it from the carriage. Figure 4: Remove the old printhead c01795084.gif
    Regards
    Gary
Jul 07, 2014 | HP Photosmart 6520 e-All-in-One -...
Please give us step by step instruction on how to change ink cartridge?
  • Turn on your printer and raise the lid or press the cartridge changing button.
  • Wait for the cartridge carrier to slide out.
  • Put your finger behind the ridge on the top front of the old cartridge and pull it toward you to remove. If you have an Epson printer, lift the cartridge holder lid, and the cartridge will pop up for removal.
  • Carefully remove the tape from the ink opening on the bottom of new cartridge.
  • Insert the new cartridge into the cartridge carrier. Make sure the new cartridge is oriented the same way that the old cartridge had been.
  • Feel and hear the cartridge click into position. On some models, arrows will indicate the cartridge is correctly positioned.
  • If you have an Epson printer, close the cartridge holder lid and press the cleaning button to charge the cartridge.
  • Close printer cover.
  • Mar 03, 2011 | Epson Stylus Multifunction Inkjet Printer/...
    How do I intstall a black ink cartridge in a hp desk jet 5550 printer?
    Follow these steps to install the cartridges. Step Example
    1. Make sure the product is on.
    2. Open the top cover. Wait until the carriage moves to the center of the product and is idle and silent.
    3. Open the cartridge latch.
    4. If you are replacing the cartridge, slide the old cartridge out of its slot.
    Figure 6: Open the product and remove the old cartridgec00160484.gif Remove a new cartridge from its packaging, and then carefully remove the plastic tape. Hold the cartridge so that the copper strip is on the bottom.
    CAUTION: Do not touch the cartridge ink nozzles or copper contacts. Touching these parts will result in clogs, ink failure, and bad electrical connections. Do not remove the copper strips. They are required electrical contacts. Figure 7: Remove the protective tapec00160485.png
    1. Slide the cartridge firmly into the cradle. Make sure that the copper contacts of the cartridge meet the copper contacts inside the printer.
    2. Press down on the cartridge latch until it snaps closed.
    3. Close the top cover.
    Figure 8: Insert the new cartridgec00160486.gif
    Nov 03, 2010 | Office Equipment & Supplies
    How to change the ink cartridge in a Canon iP1900 printer please
    1•Protect your desk, printer stand or work surface by placing an old newspaper in front of or next to the printer. The newspaper will provide you with a place to work without getting ink anywhere you don't want it. It seems as though no matter how careful or neat you are, a little bit of ink always manages to escape when replacing an ink cartridge.
    •2
    Prepare the new ink cartridge for installation. Remove the replacement cartridge for your Canon printer from all of its packaging. You may need scissors to remove the heavy wrapper. Leave the protective orange cap or tape in place for now. Set the new cartridge aside on the newspaper.
    •3
    Remove the old ink cartridge from the Canon printer. With the printer on, open the front door or panel of the printer. Wait a second or two and the ink cartridge holder should move to the opening where it is accessible. If it does not move, shut the door, turn the printer off for a moment, turn it back on and try again. Lift the small lever that secures the ink cartridges within their holder. On most Canon printers, it is colored green and located on the right side of the ink cartridge holder. Gently lift the old ink cartridge out of the printer.
    •4
    Place the new ink cartridge in the printer. Remove the plastic cap or tape protecting the ink cartridge, being careful not to touch the black and gold "sensor" area of the cartridge. Gently but firmly push the new cartridge into the empty slot left where you removed the old ink cartridge. The label should be facing outward. You should feel the cartridge pop into place. Then push the lever back down that you lifted in Step 3. Close the printer door. Use paper towel or wet wipes to clean any ink from your hands.
    Aug 18, 2010 | Canon Office Equipment & Supplies
    Mp830 5200 error how to fix
    Hi, this error code 5200 indicates that one of the cartridges is having problem with it's print head. You need to replace it, but first you need to find which one. For best solution, we need a set of new cartridges so that there'd be no problem testing.
    Let's begin like this;
    Remove all the old cartridges, Turn off the printer, disconnect the all the cables including power cord and ethernet cable (if any), leave it Off for few minutes and again turn it on after connecting the power cord. Now install all the new cartridges and check if the error message is still there or not (Hope it's gone, but you need to find out the culprit from among the old ones so that you can use those that are functioning properly).
    Now remove one for example yellow and install the old yellow and check the message, if it's ok, go on replacing with the corresponding old cartridges after removing the newly installed, and so and find out the cartridge which is the creating this problem. After that, you'll be able to use the other remaining old cartridges.
    This might be a problem for you if you don't have a new set of cartridges, but this is the best way, you can also use old working cartridges [those with no more inks].
    This will definitely fix. I would also suggest you to clean the contact points on the cartridges and on the printer properly using soft brush/cotton dipped in alcohol/acetone/spirit.
    Take care
    Jul 18, 2010 | Canon PIXMA MP830 All-In-One InkJet...
    Error 5200
    This error code 5200 indicates that one of the cartridges is having problem with it's print head. You need to replace it, but first you need to find which one. For best solution, we need a set of new cartridges so that there'd be no problem testing.
    Good luck.
    Thanks for using FixYa.
    Jul 09, 2010 | Canon Office Equipment & Supplies
    Cannon selphy es2 - how do i remove old cartridge?
    you can remove the old ink cartridge from the Canon selphy es2 by simply lifting the small green lever on the ink cartridge carrier. Take note of how the cartridge was situated in the carrier, then gently take the old cartridge out of the printer.
    Jan 18, 2010 | Canon Office Equipment & Supplies
    REMOVING OLD INK CARTRIDGE
    Click on this link:
    Z600 Series Manual
    Go to page 42. There are detailed instructions for removal and replacement of your cartridges. (With pictures.) :-)
    Thanks for using Fixya.
    Jun 19, 2009 | Lexmark Z640 InkJet Printer
    Hp deskjet printer640c/colorcartridge no 49
    sounds like either part of the tape that covers the cartridge (you did remove the tape right?) is still stuck on it and it didn't seat right. Was it harder (applied more force) to latch the new cartridge in place than the old one? If so then there is something either stuck on the new cartridge foot or nozzle face.
    Another explaination is that the foot came off the old cartridge and is still in the printer. This happens some times. Examine the new and old cartridge carefully. Are they different? How?
    Remove both cartridges and look at the emply holes where they were. See the metal pins? Is anything covering them? Remove any tape or pieces of tape carefully.
    Jun 22, 2008 | HP Office Equipment & Supplies
    Ink cartridge
    you have to on the printer. Then you open up the front cover, the cartridge place will move to the center of the printer.  push the lock button of the cartridge and you may remove the old cartridge. You have to remove the old cartridge and change with the new one.
    May 06, 2008 | Lexmark Z600 InkJet Printer
    Brother HL-2040 Laser Printer Logo
    CheckitRight
    CheckitRight
    Soulvisitor
    Soulvisitor
    Ron Dufek
    Ron Dufek
