Question about IBM ThinkPad 600E 2645 Notebook
IRe: IBM 600E
Ziraffa,
Thanks for your quick replay...I tap Del and boot the laptop as you told me and showed me the following errors 00161, 00301, 00163,00173 then I pressed ok and year, date, time displayed and I enterd the correct year, date and time then won't load windows just showing me the RAM size 163254 ok
Thanks,
Aaron
  • nolansims Feb 10, 2009
    i have a thinkpad 770ed with the same problem. ihave changed the battery and reset the date and time, then i get a screen with a circle, a greater than symbol and a vertical line, but i have no use of any keys or the mouse.
    any suggestions?
    thanks, nolan
  • 827 Answers
Hi, sorry I was out last night.
Errors 00161/00163/00173 mean you need to replace the CMOS/BIOS battery and update the time, date etc, like you did.. and Error 00301 means a keyboard error. Just press CtrlAltDel past this.. or try using an external PS-2 keyboard..
So, when you startup and then get to the errors, just press CtrlAltDel to restart, then tap F1 to enter the Advanced Settings and try to load Windows in Safe Mode, and let it do a Scan Disk.
It's possible that the machine won't be able to load any hardware drivers for the machine because the CMOS information might have been corrupted due to the flat battery, but try and boot into Safe Mode anyway and see how you get on.
This is a really old machine but still has driver and troubleshooting support at the Lenovo website, and it might be fun and interesting to resurrect..
Hardware Maintance Manual - June 1999: ThinkPad 600, 600E
On pages 109 and 115of the attached pdf file (actual pages 103 and 109), the Li-Ion batterypack part number should read 12P4064 replaces 02K7018.
IRe: IBM 600E - c.gif Battery test utility diskette - ThinkPad 600/E/X
BIOS Update (Diskette) - ThinkPad 600
PCMCIA SelectaDock I/II driver for Windows 95/98 - ThinkPad 600, 770
c.gif Windows 98 installation supplement files - ThinkPad 600, 760, 765, 770
This is the Setup Guide for the thinkpad 600.
Of course, it may very well load Windows fine after a new battery and a scandisk and you'll find it has Windows 2000 on it, so maybe I'm jumping the gun with the Win98 stuff there, but let me kow how you get on..
Chris (ziraffa)
Oh by the way, if we are going to be using a different Solution thread this time, can you go back to the other page and rate it as Fixya! so that they can take it off the system? It saves the unrated pages filling up the servers..
Posted on Jan 18, 2009
My laptop IBM ThinkPad 600E 2645 by turning on shows the notice Error 129 in system board. The laptop cannot be put into service.
The ThinkPad error code 129 is a motherboard problem. This is a component failure on the motherboard and cannot be fixed easily.
The 600E is a very, very old laptop. I suggest you don't spend money on it, put your money towards a new or later model laptop.
Aug 18, 2010 | IBM (30L2872) for ThinkPad 600E 2645-55x...
I get disk read error when I try to boot it up.
hi there, here are possible solutions to your issue
1. make sure first that your computer would be able to identify your harddrive. you can check this one by going to the setup utility page. upon pushing the power button quickly tap the F1 key or F2 key. then check your Harddrive if motherboard was able to detect it.
2. make sure that there is now usb flash drive or external drive attached to your usb ports when booting up your computer. sometimes if you have this devices attached to your usb this error happens when booting up.
3. Power on the computer and keep on tapping F8 key the moment you push the power button. select safe mode once oyu enter the black screen. if same error occured. then, ou need to use the recovery disk that came with the system and restore the computer back to original factory settings.
Apr 07, 2010 | IBM ThinkPad 600E 2645 Notebook
IBM Thinkpad 600e (2645),error 189 and could not installing win98
Usually this means a hardware failure. I would suggest reseating the CMOS battery overnight to reset the system. Also you might want to replace it as well. It could also be more serious such as a motherboard component failure.
Also IBM error code # 189 according to Scott Mueller's Upgrading and Repairing PC's (8th edition) - "Excessive incorrect password attempts." Is there a password on your CMOS ?
Also try hitting ESC key on boot to bypass. Good luck!
Sep 23, 2009 | IBM ThinkPad 600E 2645 Notebook
IBM Thinkpap 600E 8611 error
http://www.repairspot.com/thinkpad_8611_error__disabling.htm
pls rate this solution if it works
thanks to choosing FixYa.
May 29, 2009 | IBM ThinkPad 600E 2645 Notebook
On a ibm 600e, how do I boot from a cd? I'm
ok go to the bios system by pressing esc or F12 or F2 key when the computer restart. After that change the boot sequence. CD drive first after that HDD or follow the instruction that are given by computer in bellow or side, after configure just press F10 for saving.
Mar 14, 2009 | IBM ThinkPad 600E 2645 Notebook
Ibm think pad 600e
Do a search for memtest86.iso. Burn this image to a cd and reboot your computer. When your computer reboots it should begin checking your memory for errors. If you still have problems it might be your hard drive.
Feb 13, 2009 | IBM ThinkPad 600E 2645 Notebook
IBM 600E
Hi Aaron,
Sounds more like a hard drive issue, although it could be either or both.
Tap either F8, F, F10, F12 or Del when you boot up. You have to do it right on the bootup. This will let you enter the BIOS/Advanced Settings.
See if you can Start Windows in Safe Mode from there. When you get to the Desktop, in Safe Mode, you might be able to do a System Restore back to a time before you started experiencing problems, although you will lose any configuration settings you made after that point.
Also if you could do a Repair Windows with a system disk, that would be wise.
The reason I mentioned so many possibilities for buttons to enter the BIOS is because is varies from machine to machine. It usually says which button it is at the bottom of the screen for a very short time when booting up.
Try that and let me know how you get on..
Chris (ziraffa)
ps The fact that you can see your RAM size is a good sign, with regards to the actual hardware. I think the worst case scenario is probably having to reinstall your operating system from scratch.. and then the hassle of finding and installing the hardware drivers so that the new operating system can 'recognise' the motherboard, and the network cards, sound etc
Jan 17, 2009 | IBM ThinkPad 600E 2645 Notebook
IBM ThinkPad 600E problem
might wann redo it or repiar it with orginal xp cd ok boot into cd
Jan 25, 2008 | IBM ThinkPad 600E 2645 Notebook
Thinkpad 600E
IBM Thinkpad error code 19990301 is a Hard-Disk sector problem. Basically your hard-drive is faulty and you need to replace it. This is why it wont boot; because the area of the hard-drive that stores data is damaged.
Sep 20, 2007 | IBM ThinkPad 600E 2645 Notebook
My ibm s showing a certain error no. on startup
Without seeing the error, you may be best just typing the number into Google.
Feb 20, 2007 | IBM ThinkPad 600E 2645 Notebook
Open Questions:
ibm thinkpad does not boot My IBM Thinkpad 600 (Type 2645-310) stops and hang during bootup. What happens is: 1. LED test, then green Power on and orange battery/charging 3. RAM OK (Responds when I take out /put in different amount of RAM and displays correctly. I have 128 + 32 removable, + 32 internal not possible to take out) 2. I can hear fan, CD drive and evt diskette drive. If I use diskette drive the LED wil give 1 blink, if I use CD drive it will give 14 blink. 3. No cursor seen, but this is displayed: Upper left show the amount of RAM present: 196032 KB OK Upper right IBMs logo in blue; IBM Lower left shows "ThinkPad(R)" in large letters and red dot over "i". 4. Then a "rrrrrr" sound from the loudspeakers after a while, this is in fact 28 clicks shortly after each other. Then nothing more happens. Diskette and CD drive is OK (But can not be used because bootup is never finished). I hear CD speed up and then down again but nothing more happens. No effect in booting with bootable diskette or CD, "Live Linux" CD or else. Backup battery OK (3V) and if I take it out I will be asked for correct date and time when Power on. I can then use keyboard or TrackPoint to set date and time, and after that hangup at the usual point. Starting without battery, HDD, CD drive and removable memory sticks makes no difference in symptoms. Pressing and holding F1 before and during poweron and startup (in order to enter BIOS and selftest) has no effect. I could not find help on IBMs home page, but maybe I did not look at the right place. Is somebody able to help me?
Feb 28, 2017 | IBM ThinkPad 600E 2645 Notebook
See all IBM ThinkPad 600E 2645 Notebook Questions
IBM ThinkPad 600E 2645 Notebook Logo
485 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
