Question about Bunn CDBCF 15 APS Coffee Maker
Stopped making hot enough water
This coffee maker is for a business. I came into work and brewed some coffee but it only came out look warm. The light on the machine was green so I knew it was good to go. I poured some hot water from the machine and temped it. It was only 120 degrees
    Novelist:
  • 125 Answers
Hello. If the temp is coming out low, there are a few possibilities. You said the "green" light was lit, is this a ready to brew lamp? if so, your thermostat is indicating it is at temp, even though it is not. I would say that it has failed, and needs replacement. It could be it has overheated, and tripped the safety limit, the heater has failed, a wire burnt off, it would require checking with a multimeter to know for sure. Take it to, or call a servicer, and have it checked, if its commercial, you can find a servicer in the phone book, under "restaurant equipment repair".
Hope that helps, and thank you.
Posted on Feb 22, 2009
Brews good hot coffee but warming plate has stopped heating! Are replacement elements readily available or could it be a fuse...??
The DCC-1200 has only one element, that both heats the water for brewing and keeps the carafe warm. If you're brewing coffee then the element is fine and the suspect part is the Thermistor. Another forum suggested this was a Vishnay NTCLG100E22245B, available from DigiKey (their part # BC2467), connected to the control board with thin yellow wires. The same forum suggested that this thermistor should test at 220K ohms at room temperature, dropping to 20K at about 220F.
Nov 17, 2015 | Cuisinart DCC-1200 Coffee Maker
Jura S7 says fill tank but tank full
The brew unit is damaged and needs to be repaired.
Aug 18, 2014 | Jura Capresso Impressa S7 Coffee Maker,...
Keurig coffee maker is on, lights lit, machine said it is brewing but no water is coming out
Even though the light is on, this does not mean the element that heats the water is working. After you fill the machine with COLD water, and the light has been on for a few minutes, unplug the machine and dump the water out into a bowl. Carefully, feel the water. Is it hot? OR just warm? Or still cold? If it is warm, the element is not heating properly. If it is cold, the element is NOT working. If the water is HOT, then perhaps the tube from the water storage reservoir to the brewing basket is clogged. If that tube is clogged, it needs to be removed from the machine and cleaned out. If the element is not working, or heating the eater hot enough, that element needs replacement. Chances are, the replacement cost/cost of repair would be more then a new coffee maker.
Feb 03, 2010 | Keurig Special Edition B60 Coffee Maker
My Vienna Digital suddenly makes weak coffee and it not hot
Try resetting the maching to factory settings.
Here is another question, bear with me, what do you brew the coffee into? And is it pre-warmed?
Jun 08, 2009 | Saeco Vienna Digital Coffee Maker,...
Coffee not brewing
This machine depends on heat to move the water to the top. The heating element, or thermal fuse, or burned contacts are the usual suspects. The warmer under the coffee pot is not part of the coffee making process. It is repairable.
May 05, 2009 | Mr. Coffee 072179228578 12 Cup Coffee...
Braun Flavor Select will not brew coffee.
I assume You are talking about the water-brewing heater thereare two, the second is the heater that warms the coffee pot (I think!). When the water-heater is encrusted with calcium deposits it "thinks" that the water reservoir is emptyand ceases the brew cycle. water boils at 212 degF and the heater will go to a much higher temperature. I will leave you with the same solution as was posted to another problem that may have similar cause:
corvette2
I have the same machine, Braun KF180 12 Cup Coffee Maker. In normal operation the brew cycle is stopped when the water reservoir is empty. The only way the coffee maker knows if that is true is when the water-brewing heater gets too hot. Your brewing heater is probably encrusted with calcium deposits if you have been heavily using the coffee maker. Vinegar will work but it is weak and you will have to cycle this solution through many many times. You should instead use "Lime Away" or "CLR" and let it sit there in a brew cycle or multiple brew cycles for a while. NOTE: Remove the filter when cleaning this way and when the brew cycle is complete, rinse thoroughly -- your taste buds will let you know if the machine is not rinsed thoroughly. -- Good Luck!!
Nov 16, 2008 | Braun FlavorSelect KF 180 Coffee Maker
Hamilton Beach Brew Station
My brewStation 47214 stopped pumping water today, even though the warming element continued to get hot. A half dozen screws later I discovered a second heating element inside the coffee maker. The internal element is what heats the water and forces it into the basket. This element was burned out, religating my brewstation to the garbage. Probably last 3+ years.
Jul 11, 2008 | Hamilton Beach BrewStation 47214 Coffee...
Warmer stopped working
the coffee maker brews but the pot warming plate isn't hot
Nov 14, 2007 | Cuisinart DCC-1200 Coffee Maker
CofferMaker won't brew coffee properly
Sounds like maybe the temperature sensor is cutting it off too early. This is an expensive ($200 US) pot so I would contact the mfr. They might have a quick solution.
Feb 25, 2007 | Alfa CM-110 Coffee Maker
Bunn CDBCF 15 APS Coffee Maker Logo
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Y
Jim Y
pawnpower
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
