Have a hotpoint aquarius + 740 keep getting error message f-03 the washer seems to be filling with water and pumping back out ith the error message flashing
It is possible your water supply is to low or your screens may be blocked at the inlet attachment to the washer. The other scenario a sticky or failing pump solenoid ; by which a direct replacement of the pump assembly may be required. Try to lubricate and actuate valve by hand if possible.
You may have soap & grease in the pipe that leads to the pressure switch. Remove and flush through and/or replace. dry before refitting. Thus constant high would give pump faults (thinks machine still contains water). Constant low may cause over filling. If you have a plug that suddenly moves, that can cause the above errors.
Seems like a blockage or maybe pump worn out. Fill machine and take grey outlet pipe on rear of machine. Place this pipe as low as possible into a bowl. If water flows free from this pipe then your pipes are not blocked and most likely you will need to change your pump. Before you try this just put machine onto spin and ensure this will work when machine is almost empty
will it stop when you stop the cycle? if so your pressure switch could be the problem however if that does not stop the water you intake water valve is most likley the problem
The error code F03 indicates that the wash thermistor is open or short circuit.
Check heater element and thermistor,if ok, then you need to call an engineer.
Sounds like water pressure could be low or inlet pipe is kinked.
F04: possible filling or water level problem. Check water inlet pipe (or shut-off valve), or the outlet pipe, or the pump or pump filter if accessible (check for blockages or foreign objects). Also could be the water valve solenoid weak, causing filling to be too slow.
F05: possible draining (pumping off) problem, check the pump filter, or pump, outlet pipe, or U-BEND.
