Question about Lexmark P4350 All-In-One InkJet Printer
Windows does not start when I leave my printer plugged in
If I connect my Lexmark P4350 to a USB 1 I find that windows does not start unless I unplug the printer before booting. There is no problem if the printer is connected to a USB 2 port but I dont have any spare USB 2 ports so that is not a satisfactory solution. Any ideas?
  • daley259 Jan 20, 2009
    The book doesn't say whether it's a USB 1 or 2 device but it works fine on USB 1, it's just that the computer wont boot up if it is plugged into the USB port on startup. I get the logo of the motherboar manufacturer and it freezes there. This doesnt happen when the printer is left plugged into a USB 2 port but then it doesnt print properly - I just get the first few lines of a page printed and then the rest of the page is blank. Weird.
First if your USB cord is too long try to switch it out with a smaller cord. If that does not work please unplug printer boot up and enter the BIOS settings.
http://www.michaelstevenstech.com/bios_manufacturer.htm
Then check to make sure your boot sequence is setup to Hard Disk first and not USB, you need to make sure the USB Boot Device does not have priority over HDD.
Finally make sure that USB Emulation is not turned on in the BIOS.
If all of the above does not fix the issue you may have a faulty USB port or a bad mother board.
Posted on Mar 27, 2009
I had the same problem - I disabled legacy USB support and the problem is fixed. Hope this helps :-)
Posted on Apr 19, 2010
    President:
  • 2,692 Answers
Is the printer a USB 1 or a USB  2  item? @ hardware is not backwards compatable to 1 but a 1 item can run on a 2 port. Swap ports with the other item?
http://support.lexmark.com/perl/support/support.cgi
Posted on Jan 18, 2009
OS is windows 7 and i want to connect lexmark p4350 inkjet printer
Use the Lexmark P4350 printer driver for Vista OS on Windows 7. But first, check if your Windows 7 is running on 32-bit or 64-bit operating system. On your computer, go to Start menu > right-click on Computer > click on Properties. Take note of the System Type.
Use the link below to download and install the printer driver on your computer:- Lexmark P4350 Printer Driver for Vista 32-bit or Windows 7 32-bit- Lexmark P4350 Printer Driver for Vista 64-bit or Windows 7 64-bit
Simply follow the instructions on your computer screen to complete the installation.
I hope this helps. Thanks.
Nov 14, 2011 | Lexmark P4350 All-In-One InkJet Printer
Trying to add a lexmark p4350 to a laptop e.system windows vista
You can first download a new driver from the link posted at the very bottom. If that still does not work please follow the instructions as shown below here.
This behavior can be caused by your security programs. It may blocked some components when you install the driver, or it may blocked the communication between the system and the printer driver.
I suggest that you remove the printer again, temporary disable the anti-virus and firewall and reinstall the driver.
The following steps can be referred when you remove the printer.
Remove printer
1. Click the "Start" button, type PRINTER in the search box and press Enter.
2. Find the icons which are related to Lexmark P4350, and delete them.
3. Right-click on the blank part of the window, and choose "Run as administrator"->"Server Properties".
4. On the Drivers tab, select the listed printer and click the Remove button. Please then select Remove driver and driver package.
5. Open Start menu, input APPWIZ.CPL in the Search box and press ENTER to launch "Programs and Features".
6. Try to remove all related printer software.
Additionally, please check if your driver is downloaded from the following website.
http://www.lexmark.com/lexmark/sequentialem/home/0,6959,204816596_1019285789_0_en,00.html
Important Note: Microsoft provides third-party contact information to help you find technical support. This contact information may change without notice. Microsoft does not guarantee the accuracy of this third-party contact information.
Before reinstalling the driver, I suggest that you temporary disable the anti-virus and firewall. After reinstalling, check if the issue is resolved.
If the issue persists, I suggest that you change the USB port. If the printer is connected via a USB hub, please bypass the hub and directly connect the printer to the USB port on the motherboard.
Hope it helps.
Here are a few websites for your Lexmark driver downloads
http://windows-vista-updates.blogspot.com/2007/09/lexmark-p4350-vista-driver.html
http://www.lostmydrivers.com/printers-drivers/lexmark/lexmark-p4350-all-in-one-printer-driver-v1.0.3.1-windows-vista.html
Jul 18, 2010 | Lexmark P4350 All-In-One InkJet Printer
P4350 dose all but wont scan
Try this. Unplug the printer usb connection from the computer. Re-run the installation cd in the computer. When the software asks for the printer to be plugged in via the usb cable, do so. If this does not help, maybe a firewall is blocking it. Make sure to allow all Lexmark and printer communications to go through the firewall. Leave a comment if you need more assistance. Thanks.
May 14, 2010 | Lexmark P4350 All-In-One InkJet Printer
Lexmark p4350 printer no disc cannot connect to laptop
download driver from given link and install downloaded setup and follow instruction..
download from here
have a nice day....
Oct 29, 2009 | Lexmark X1270 All-In-One InkJet Printer
I had imaging studio for my last computer but when I loaded the peinter program on my new computer the imaging studio did not come in. What did I do wrong. I have vista
You will need to uninstall and reinstall the printer driver. Please follow the steps given below:
To uninstall, please follow the steps given below:
1. Click "Start" and "All Programs."
2. Go to the "Lexmark P4300 series."
3. Click "Lexmark Uninstall."
4. Click "Next."
5. Click "Finish."
6. Click "Restart Windows" and unplug the Usb cable.
You may copy and paste the web address below to access the Lexmark P4350 printer Vista driver again:
http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=229:1:0:479:0:0&emeaframe=&fileID=11416&searchLang=en&searchLang=en&os_group=Windows%20Vista
To download the Lexmark P4350 Vista driver, please follow the steps given below:
1. Click on "Downloads." tab next to Publications and click on "Driver for Microsoft Windows Vista." Click on "Download.
2. On the "File Download" screen, choose "Save."
3. The next screen will be titled "Save As." Choose to "Save in Desktop" and click "OK."
4. You should see files being transferred.
****Note**** If your browser uses a different file downloading format than specified above, you will need to resort to your browsers help files for downloading instructions. The object of steps 1 - 4 is to download the driver to your desktop. This way it is easily accessible.
5. Once the files have completed downloading, double click on the icon with your file name.
6. On the "Win Zip Self-Extractor" screen click "OK." To unzip the downloaded file choose "Unzip."
7. A screen will then display the number of files unzipped successfully, click "OK."
8. Please follow the on screen instructions to complete installation of your Lexmark printer.
Note: Please plug the USB cable when prompted while installing the driver. The USB cable should still be removed from the system, and the on-screen prompts will remind you of this. Eventually, you will get to a screen asking you to plug in the USB cable. This screen also has an "OK" button. Do not hit this button yet. First, plug in the USB cable. The screen should automatically detect and install the Lexmark P4350 scanner and printer drivers.
Oct 18, 2009 | Lexmark P4350 All-In-One InkJet Printer
The computer does not communicate with the printer
If using Windows - Leaving the printer on and plugged in- go to the add Hardware and you can either do an auto search or a manual one for the printer.
Jun 26, 2009 | Lexmark P4350 All-In-One InkJet Printer
Computer won't communicate with printer
Make sure that the printer driver you are using is compatible with your version of windows. If so, open all printers in "control panel" and make sure that this printer is the preferred printer and not an old one you might still have installed.
May 09, 2009 | Lexmark P4350 All-In-One InkJet Printer
Lexmarkpritermodel p4350
hi
Its simple...Visit www.lexmark.com U would find a search box on the website..just type P4350 in the search box.download driver..save it to ur desktop.connect USB cable..run the downloaded file..follow instructions for installation.
goodluck
Jan 25, 2009 | Lexmark P4350 All-In-One InkJet Printer
Lexmark 4300
Download Vista drivers from here.
After downloading unplug printer usb, and start downloaded file.
Nov 11, 2008 | Lexmark P4350 All-In-One InkJet Printer
Lexmark P4350 All-In-One InkJet Printer Logo
348 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
