Question about Epson LX-300 Matrix Printer
Font too big!
My Epson DX600 has started printing in really big font even thogh I haven't changed any of the settings. Have tried the tools button on the printer but to no avail, It's driving me mad!!!!
    Problem Solver:
  • 5 Answers
The font defaults have changed. You don't have to change it on purpose. Sometimes it just happens. ( like rain). The defaults in the printer for the PC need to be reset. You should have a way to do this on the printer (see operators manual for printer Keyword reset factory defaults). You can also try to reload the printer drivers but make sure you know what you are doing so you don't wind up with a printer that doesn't print at all.
Posted on Jan 20, 2009
With Print Shop 23.1-If I am adding text inside a text box, say font 60 and I complete the line and press "Enter" to start a new line, the font # changes back to what it was previously. Then I have to
When using text boxes I typically type the entire box in the preset font/size and then double click the text or select all, and choose my fonts ,sizes, spacing, etc. afterwards. Typically I use text boxes for smaller font items as I find the headline feature to be the most useful for larger size text. also under the text tab , after you double click your text box, you can select a paragraph style which has presets up to 143. I apologize that I didn't really answer your question, but maybe this will you get you by until you do, that is if you haven't already figured it out.
Oct 18, 2011 | Broderbund The Print Shop 23 Deluxe
How to change epson lx 300 font size
Unfortunatelly you can not change the fontsize of the printer, but you can change the font.
To do this hold Pause button for 3 seconds, then push Font button. Two lights will light on and then off and will show you the current settings of the font. To change the font just click repeatedly the font button untill you reach the desired font following the combinations of light on the table below.
The fontsize is controled by the software you use.
Oct 06, 2011 | Epson LX-300 Matrix Printer
How to change Epson Lx300+ II Font
The Epson printer is controlled directly by the computer it is connected to. The printer actually has no say in how and what it prints, so if you want to change any aspect of your print document (such as the text) you need to adjust the text in the document you are printing from. This only requires a few clicks of your mouse and once the text style is changed you may begin printing with the next font.
1. Open the program you are printing from and want to change the text font of.
2. Select "File," "Open" (or click the "Open" button on the front of the program), then choose the document you want to print.
3. Click-and-drag over the text you want to change. Once highlighted, click the font type option on the top of the page and choose the new font you want. Once selected, all the highlighted area changes.
4. Click "File," "Print" and choose the Epson Stylus CX5000 as the device you are printing from. Click "OK" and the document will print with the new text.
I hope you find it very helpful.
Thank you for choosing where we provide greater solutions.
Aug 11, 2011 | Epson LX-300 Matrix Printer
How to use draft mode in epson lx_300+ii printe
Change the printer's default settings.
Hold down the Font button and switch the printer on. The printer will print language setting
Press the font button again and the printer will print instructions for changing from default settings
Follow the instructions to change draft mode on/off.
Jun 08, 2011 | Epson LX-300+ II Matrix Printer
How to change boud rate from 19200 to 9600
Here are the complete steps to change your LX-300 bit rate to 9600.
1) Load a paper with the friction lever up.
2) Hold the FONT button and switch on the printer. The printer must sense the loaded paper and must start printing some stuff. If not it rolls and tries to load the paper. In such case insert the paper again and press PAUSE button. Now the printer will print the stuff i.e) the current printer settings.
3) After the printing finishes (the print matter will be around 25% of a 11inch page length), press LF/FF. You will find the current settings. Check the current bit rate which is indicated in the 10th line of the current settings table.
4) Now press LF/FF which takes you to the Table B.
5) Now you are in table B and the lights 1, 2 and pause must be Blinking, Off, Off conditions respectively.
6) Now press the FONT button 9 times. After pressing FONT nine times, Light 1 = Blinking : Light 2 : Blinking : Pause light : ON.
This means that you are in Bit rate menu now.
7) Press PAUSE button.
8) Note down this order of bit rate and the status of 1, 2 and Pause lights.
--300 = ON-OFF-OFF
--600 = OFF-ON-OFF
--1200 = ON-ON-OFF
--2400 = OFF-OFF-ON
--4800 = ON-OFF-ON
--9600 = OFF-ON-ON
--19200 = ON-ON-ON
From the current bit rate you are in now, press the FONT button a particular number of times accordingly.
Suppose you are in 1200 bit rate currently, the lights status will be ON-ON-OFF. If you want to set to 9600 you have to press FONT button 3 times and the lights status change to OFF-ON-ON , which indicates 9600 bit rate.
9) Now, press PAUSE button so that the settings get saved.
10) Switch off the printer and turn it back on after 20 seconds.
11) Switch it off again, Hold the FONT button and switch it in again.
12) After printing finishes, press LF/FF and check the bit rate in the current settings that is printed.
You can have the user manual for your reference.
Thats' it. You're done!
Sep 30, 2009 | Epson LX-300 Matrix Printer
change the fonts of the printer by pressing the font button on the panel (Refer user manual for more details)
Feb 04, 2009 | Epson LX-300+ II Matrix Printer
Epson LX-300+II not printing in draft 10 cpi using visual studio .net
use courier font. it works just as draft font. no problem in VB-6 i hope it will also work with .Net as well.
tell if dont work.
asad khan
Oct 27, 2008 | Epson LX-300 Matrix Printer
Epson LX-300+II, the font problem
yes you can change the font tray to print the printer internal setting tray that press and hold any key by tarn the printer off then on after you tarn the printer on release the key
Sep 06, 2008 | Epson LX-300+ II Matrix Printer
Epson LX-300 Matrix Printer Logo
420 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
