Question about Pioneer SD-582HD5 58" Rear Projection HDTV-Ready Television
Blue convergence on Pioneer SD-532HD5
Hi, After 7 great years, my Pioneer gave me a problem with blue convergence. It can't be adjusted, and creates lower ghost image on the screen. I am outside of Pionneer's service area, and was wondering what convergence IC(s) (part numbers etc) can I order on-line to replace the faulty ones? Your help is greatly appreciated!
  • 2 more comments
  • Eros Double Jun 27, 2007
    Hi, Tom!
    Well, Bob is out until Monday, so I went ahead and ordered 2 STK392-110 from his on-line store. They only 8 bucks each, so the shipment will be more expensive!
    I will let you know how my replacement goes...
    Thanks again, for your feedback.
  • Eros Double Jul 12, 2007
    Thank you guys for your help. I replaced the SDK chips, and calibrated convergence.... My "baby" is back better than ever... Well spent 20 bucks!.... Thank you!
  • Anonymous Nov 26, 2007
    red convergence on my pioneer projetion tv.I tried udjusting but it does not work.
  • Bourgeois Jan 02, 2008
    Where can I buy the convergence board for my pioneer SD-532HD5? I would feel more comfortable changing the whole board then just the STK392-110 chips.
    President:
  • 3,130 Answers
If you are going to replace these IC's that are only 8 bucks, you will most likely be having the same problem down the road in the near future. You should not buy the cheap replacement IC's my friend. If the IC's do not say Sanyo on them, they are generic, and do not meet the specs. of the manufacture. Good Luck
Posted on Jun 29, 2007
    Scholar:
  • 47 Answers
The converence IC's are the problem. Unfortunaely, I do not a service manual for that unit. You will find the IC's mounted on a large heat sink. The nuers usually start with STK-xxxx. Find these IC's and copy the number off them. Usually the can be replaced by generics. You can order them directly from Mat Electronics 1-800-628-1118. Be extremely careful when you desolder these ICS the foils are easy to lift. Use desoldering braid(chemtronics) 10-25L. Also ask for BOB and tell him that Tom from TOM's Tv suggested him. This will insure you the lowest price. Also some times the current limiting resistors open up. Always replace both convergence ICS. In your case only one is bad. Replace both anyway. (they only cost about $12.00 @ Any further questions, contact me. These are great TV's and well worth repairing!!! Scrivitron
Posted on Jun 22, 2007
  • Thomas R.  Scrivner II
    Thomas R. Scrivner II Jun 22, 2007
    Thanks for the great feed back, some times when you try to help people, the just don' t appreciate it. Scrivitron
SOURCE:
RED OUT OF ALIGNMENT / CANNOT ACCESS CONTRAST, BLACK LEVEL OR COLOR IN PICTURE MENU.
Hi, this is a fairly common problem, what has happened is your Color & Convergence section is faulty usually fixable by replace both convergence ICs.
but First you MUST obtain a Service Manual, this will show you what to do and how to set it all up.
http://www.pioneer.owner-manuals.com/SD532HD5-service-manual-PIONEER.html
The above link is for your service manual.
Dec 20, 2010 | Pioneer SD-532HD5 53" Rear Projection...
I HAVE A PIONEER 50' TV AND THE TV REPAIR MAN WORKED ON THE COLOR CONVERGENCE AND NOW HE SAYS THAT I HAVE TO FINE TUNE IT? the main problem was the blue line.
YOU need to have the original Pioneer remote to do this--I do not understand if someone fixed and you had the remote why he did not adjust it?
With the Pioneer remote you go into the customer menu and adjust convergence--most also have a TECH menu for this but you still need the remote and a code to get into this--REMOTES FOR THESE SETS ARE HARD TO FIND AND EXPENSIVE.
Let me know if you have questions--I am here to help.
If this helped you, rate this solution as I do this here for FREE.
SD TECH
Nov 12, 2009 | Pioneer SD-532HD5 53" Rear Projection...
Alinement of blue cross with red and yellow.
you will need to call someone in to realign the picture...
Feb 16, 2009 | Pioneer SD-532HD5 53" Rear Projection...
I have a pioneer SD-532HD5, the red convergence went wacko and cannot adjust
A microchip controls the color convergence. There is no easy way to fix it. A new chip will be needed.
Nov 14, 2008 | Televison & Video
Pioneer projection blurry picture
Sounds like you lost the converigence. Have you tried to realign the convergence through the user menu? Try that first and see what happens.
Jul 20, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Blue lines on the screen
Remove Convergence / power supply circuit board...replace
convergence IC's with first quality ....either Philips,Toshiba or
best choice = upgrade to Hitachi = CZ 01341....let me know
if you have ? 's............T.
Feb 12, 2008 | Televison & Video
Right side convergence
A convergence IC has burned out. If I remember correctly, those Pioneer sets have one huge convergence IC, but that IC only has 5 channels in it so they use another smaller dual STK IC and one half of it is used for the 6th channel and the other half is the vertical output. Look on the convergence board, find the blue convergence jack, identify the blue horizontal channel, follow the traces and replace the IC handling the blue horizontal channel.
Aug 28, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
Pioneer SD-532HD5
This fault happens with just about any tube type projection set. The convergence IC's simply need to be replaced. They are two black, 2"X3", stand up ICs that will start with the letters STK on the surface of them and are mounted up against a large metal heatsink. If you have the soldering skills this should not be so hard for you to do, but please if you do not have the skills or experience to replace these IC's call in a pro to assist you with this repair. Good Luck
Mar 28, 2007 | Pioneer SD-582HD5 58" Rear Projection...
Pioneer SD-582HD5 58" Rear Projection HDTV-Ready Television Logo
214 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
