To copy from internal memory to memory card, follow the instructions on this page of the user guide.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries. Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
SOURCE: internal memory photos download to sd card
Press the menu and look for the utilities section on the camera. There should be a copy from memory to SD.
SOURCE: camera said memory full but I have memory card
You need to format the SD card before it will be used by the camera. Formatting instructions are in the manual.
SOURCE: How to download pics. from my camera to my computer
Question :
How do I transfer pictures from the internal memory of my KODAK Digital Camera to a memory card?
Answer :
Follow these steps:
When you have finished copying pictures, reset the Image Storage location to your original setting.
Once your pictures are transferred to the SD card it will be easy to transferre onto the computer.
SOURCE: I lost the download cable for my Exilim camera.
This procedure will copy all files from internal memory to a memory card.
1. Load the memory card to which to copy the files.
2. Turn on the camera, enter the PLAY mode, and press the MENU button.
3. On the "PLAY" tab, select "Copy" and then press right-arrow.
4. Use up/down-arrows to select "Built-in->Card" and then press SET.
Wait until the Busy message disappears before doing anything else. After the transfer the last file transfered will appear on the display.
Testimonial: "Exactly what I needed to know! Someone had told me my camera could do this - I searched and searched but couldn't figure it out. Thank you FixYa!"
