Question about Mach Speed (S755) Motherboard
Memory confusion different readings
I have the mach speed P4M800CE mb. I recently upgraded my memory from 512mb to 2gb. I installed ocz Platinum 2gb (2x1gb) 184 Pin ddr sdram ddr400 (pc 3200) Dual channel memory.
When I check the memory in System Information - It lists Total Physical Memory at 512 mb and Available Physical Memory at 1.43 gb. How can I have more Available Physical Memory than I have Total Physical Memory ?
Thanks for your time.
  • 32 Answers
It sounds like something isnt working right, what operating system are you using, Vista? I would take out the original 512 and see what it says after, often ram isnt compatible if it is too different in size and speeds. Also, if your motherboard supports dual channel ram and you have the extra 512 chip it wont run in dual channel mode, you would run better with just the 2 chips then the added 512 chip.
Posted on Sep 12, 2009
Upgrading memory from 512mb to 2gb but the memory i have seen says 800MHz yet i have seen somewhere on my computer 533MHz is this something else?also i can go to 4gb would this be to big a step and a waste...
upgrading to 2GB will have a significant increase in speed, the jump from 2GB to 4 GB will be faster but the additional speed increase will be less than the 512 to 2 GB jump. In my book, get as much RAM as you can afford, for go with 4 GB. THe 533 Front side bus is set by the processor installed on the MB, using 800 Mhz RAM will have no ill effect as it is backwards compatible to 533
Aug 30, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Hp Compaq dx2200 MT RAM Problems
Firstly, you have to know that you can upgrade RAM as Double or Half of your pre-installed RAM. For example, like your pre-installed RAM is 256 MB, you can only upgrade RAM of capacity 128 MB or 512 MB. Secondly, check your previous installed RAM's speed that is shown in Ghz. You can only upgrade RAM to its similar speed, otherwise you get slow performance of PC.
Jul 18, 2010 | HP Compaq dx2000 Microtower PC Desktop
I need to add extra memory now my lap top works with 128 MB i need to be 256 MB
thats no problem sir,u can upgrade the memory cards of the computer to the level which it supports may be 1gb,2gb or 4gb.....
u can purchase another memory stick of same specifications because its availiable is different size like 128Mb,256Mb,512Mb or 1Gb.....you can use any one according to your wish...
Apr 26, 2009 | Toshiba Tecra 8200 PIII-850MHz/ 256MB/...
Not enough memory
  • your Toshiba Satellite M35X-S311 has the following memory configuration
  • Configured with 512MB
  • The maximum memory you can have is 2048MB (Max),
  • 2 memory slots using 1024MB PC2700 DDR333 SDRAM 2.5V SODIMM Memory modules (Both slots may be occupied). Go to a store and request for this memory specification and you will have 2GB of memory for all the programs you have listed here. Good Luck!
Mar 30, 2009 | Toshiba Satellite M35X-S311 Notebook
Wanting to upgrade the memory on a hp pavillion a6220a
Standard Memory:
256 MB or 512 MB or 1 GB (Removable)
Maximum Memory: 2 GB Memory Expansion: 2 Sockets
256MB Memory (PC2-5300) 396519-001, PX974AA, PX974AT KHEW974
512MB Module (PC2-5300) 396520-001, EK477-69001, PX975AA, PX975AT KHEW975
1GB Module (PC2-5300) 398038-001, PX976AA, PX976AT KHEW976
You can upgrade your system to 2GB MAX
Your memory type is PC2-5300
Please be sure to get the right memory (above listed)
Have a great day
Pablo :-)
Let me know if you have some questions about this issue...
Oct 22, 2008 | HP Computers & Internet
Memory upgrade
We have the memory you need. Memory-Up is committed to provide the best memory and excellent services for all of our customers. We know that sometimes it is a bit confusing to buy the correct type, speed, and capacity of memory for your system. Therefore we hope that these tips below would help you for buying the new memory.
Memory Upgrade Tips
What is Compatibility and Memory Density Issue?
Memory module can be composed using different type of memory chips and therefore created different type of density for the module. For instance, a 512MB PC2700 DDR SODIMM memory can be composed using eight 32x16(High Density 512Mb technology) memory chips or sixteen 32x8(Low Density 256Mb technology) memory chips. As the laptops are equipped with different memory chipsets, some older laptop (chipset) would have compatibility issue working with the modules that is built with the newer 512Mb technology. Using the Not-Compatible memory will result the laptop to either not boot or only recognizing half of the memory modules. Thus that is not the correct memory for your system. Our Memory Finder and Memory Scanner will help to eliminate those problems and find the correct memory for you. We guaranteed the memory to work or your money back.
How much memory do I need?
Here are some general descriptions for different type of users and the amount of memory they would need for their systems.
Normal User: The system is mainly used for checking e-mails, processing word/excel file, and web surfing. Suggestion: 512MB to 1GB of system memory.
Power User: The system is mainly used for playing computer games, editing photos/videos, running database queries, or multi-tasking environment. (Surfing web/Processing Word/Excel File/Listening to Music). Suggestion: 1GB to 2GB of system memory.
Super User: The system is mainly used for running large number of database queries, professional editing of photos/videos, heavy multi-tasking environment. Usually a server or a workstation would be considered as Super User due to the multiple accesses from users. Suggestion: 2GB and above of system memory.
How much memory and memory slot do I have with my system?
You can download our Memory-Scanner to find out the the amount of memory that you have and the memory slots that are available for upgrade.
How many memory module should I buy?
It is recommended to purchase one module with bigger capacity than two modules with smaller capacity. For instance, if you can buy either one 1GB memory module or two 512MB memory modules for your system, it is recommended to get one 1GB and leave the other memory slot empty for future upgrade if necessary.
Note: For systems that supports dual channel memory mode, although memory modules need to be installed in pairs to enable Dual Channel Memory Mode, we still recommended users to purchase one bigger module than two smaller modules since Dual Channel Memory Mode has only a minimal improvement in the actual system performance.
What if I want to mix different memory together?
Different sizes/speeds of memory can be used together as long as their specification are qualified by the systems. For instance, a laptop can use one 256MB and one 1GB of memory for the total of 1.25GB system memory. Mixing two different speeds of memory modules would result the system to run at the speed of the slower memory between the two modules. We recommend users to use our Memory Finder or Memory Scanner to find the correct memory for your system.
i thnk that will helpfull for u
Oct 18, 2008 | HP Pavilion ZE5730 Notebook
Asrock K7VM2 Motherboard Memory Upgrade
Some MOBO support different type of memory modules like ddr 400, 333,533 and other, if your computer is working fine with that PC400 it only means that your MOBO is compatible with it. Since you're planning to upgrade the memory just get another PC400 because the memory should be the same to work fine.
Jun 06, 2008 | Asrock K7VM2 Motherboard
Upgrading ram
Hi reisrui, yes it is odd. (It's not the first time I have seen this.)
According to you're manual on page 6, under Specifications. The manual say's you can run up to a Max speed of PC3200 400MHz, 1GB in slot one. In slot 2 you can run a Max of 1GB of PC2700 333MHz in slot 2. Every motherboard I have come across that can run two different speeds of memory. The system will reduce the Max speed to the lower MHz memory speed. If you currently are using 512MB PC3200 400MHz in slot 1 & add 1GB of PC3200 400MHz into slot 2 for a total of 1.5GB of memory. The motherboard will ruduce the total memory over all speed to PC2700 333MHz. Motherboards alway run at the lower memory speed if two different speeds are presant.
I can’t be 100% sure of the 1GB of PC3200 400MHz into slot 2, will run at all! Or if it will be reduce down to 333MHz. I am sure you can run 2GB of PC2700 333MHz, 1GB of memory per slot in you're board for a total of 2GB.
If I can help you further, feel free to post.
Suggestions & comments welcomed.
Mike
May 27, 2008 | Asrock 775VM800 Motherboard
Ram memory upgrade
1 gig is the max. Get two sticks of 512mb kingston. If you go to kingston.com you will see ways on how to find the optimized RAM for your computer. If i am correct here are the specs for the ram that you need. 512MB-DDR333 PC2700, 184p DIMM, 2.5v, Sync, CL=2.5
Feb 25, 2008 | Areca ARC-1210 Serial ATA Controller
Mach Speed (S755) Motherboard Logo
107 people viewed this question
Top Mach Speed Computers & Internet Experts
David
David
Abhinandan  Patil
Abhinandan Patil
Iqbal Husain
Iqbal Husain
Are you a Mach Speed Computer and Internet Expert? Answer questions, earn points and help others
