Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Dishwasher will not start up.
Hello, my service company installed a new motor, float and mother board and fuse. My Kitchenaid model number KUDSO1DJSS will not start and only has the - - Green light on They also replaced the heating coil. It still does not work. Can you help me out?
Thanks,
Jim
Hello, I solved this problem. I opened the front of the dishwasher (top) and replaced the thermal fuse and then looked at the mother board. The service company had placed two wires back onto the mother-board and were placed in the wrong slot. I moved the wires back to the right location and the dishwasher has since washed to loads without any problems. The service company has been fired.
Thank you for your help,
Jim
Posted on Jan 18, 2009
Dishwasher took 3 hours to complete cycle
If you have set the unit to heated water or your hot water is not hot will delay the wash cycle. The heater in the dishwasher is very slow!
The following is from the user manual.
15
TROUBLESHOOTING
First try the solutions suggested here and possibly avoid
the cost of a service call...
Dishwasher is not operating properly
Dishwasher does not run or stops during a cycle
Is the door closed tightly and latched?
Is the right cycle selected? Refer to the "Cycle Selection
Charts."
Is there power to the dishwasher? Has a household fuse
blown or circuit breaker tripped?
Has the motor stopped due to an overload? The motor
automatically resets itself within a few minutes. If it does not
restart, call for service.
Is the water shut-off valve (if installed) turned on?
Dishwasher will not fill
Is the overfill protection float able to move up and down
freely? Press down to release.
Dishwasher seems to run too long
Is the water supplied to the dishwasher hot enough? The
dishwasher runs longer while heating water. Refer to the
"Dishwasher Efficiency Tips" section.
A delay automatically occurs in some wash and rinse cycles
until the water reaches the proper temperatur
Hope this helps?
http://www.repairclinic.com/UserManual/f75a81f2957b4b86b396c8c3629d9078/8531130/Use-Care-Guides-Owners-Manual/Use-and-Care-Guide-8531130
Oct 16, 2016 | KitchenAid Dishwashers
Dishwasher won't start
Try resetting the unit by shutting off the circuit breaker first for 1 minute then try the reset button. If nothing happens, then i would recommend having someone take a look at it.
Feb 09, 2008 | Maytag MDBH945AWW / MDBH945AWQ /...
Kitchenaid whisper quiet plus dishwasher
It is likely the thermal fuse is cut off and will need to be reset or replaced depending on the model number of your dishwasher. Please provide actual model number in the comments.
Apr 25, 2014 | KitchenAid Dishwashers
Kitchenaid kuddo1dppa
test this steps and fix it. God bless you
Water Inlet Valve
The dishwasher has an electrical water valve called a water inlet valve. If the dishwasher won't fill with water, the water inlet valve might be defective. These valves are not repairable and will have to be replaced.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Float
The float assembly is normally inside the dishwasher near the door on the floor of the dishwasher. If something gets stuck underneath it and holds the float assembly up, the dishwasher won't fill with water. If the float assembly moves freely up and down, the float switch might be defective.
Float Switch
The float switch is actuated by the float assembly. It is a protection device designed to prevent the dishwasher from overfilling. If the dishwasher won't fill with water, it may be because this float switch is defective or stuck.
Water Supply Problem
The dishwasher is connected to the hot water supply from the house. Check to be sure the household water supply valve is turned on. Over time, calcium deposits can build up in the water supply valve or in the small filter screen inside the water inlet valve. The water supply line may need to be removed from the water inlet valve of the dishwasher, then run some water into a bucket to see if there is enough pressure. Be certain to turn off the water before working on the water line.
Jul 22, 2013 | Dishwashers
Kitchenaid kud101flss won't start
see the causes and fix it: God bless you
Power Supply
The main power supply is the first thing to check. Also remove the toe kick and the cover on the power box and check the connections. Also check for 120 volt at the power box.
Hi - Limit Fuse
This will fail if your dishwasher overheats and occassionally with power surges. This is easy to check, inexpensive and a quick fix. Just check the terminals for continuity ( remember always remove one wire) if you have none replace the hi limit fuse.
Door Switch
This is the second place to look. Again an inexpensive easy fix. The following video will walk you thru checking the door switch. The power comes into the main power box and usually runs to the door switch next before entering the main control module.
Main Control Module / Timer
The main control module or mechanical timer controls all the functions of the dishwasher. To check this you will need to find the 2 leads that supply the power to the control. They will be marked on the wiring diagram. They usually come from the hi - limit fuse or the door switch. When the door is latched you should have 120 volts entering the main control. If you do not the problem is not the control. If you do have power entering the control but none of the functions work properly or it does not respond at all you will need to replace the control module, this is easy to replace but not very inexpensive to purchase. Consider the age and overall condition when purchasing this part.
Motor
The motor may have failed. If the control illuminates on electronic versions the problem may be the motor. To check the motor refer to the tech sheet located behind the console cover on most models, this will sometimes have the ohm reading of the motor. Also check each lead to the metal housing of the motor to check for shorts in the motor. If you do not have the ohm reading specicifications, check for continuity if none replace the motor. Make sure the motor is recieving power.
Float Switch
If the float switch has failed or is stuck the dishwasher control may not respond. The float switch is easy to check and replace. We have video and tutorials that cover several styles.
Jul 20, 2012 | KitchenAid 24 in. KUDI02IRBS Stainless...
My KitchenAid dishwasher quit workin no light no nothin, float switch is good, having problem troubleshooting water fill valve with solenoid???
Hi
Thanks for using FixYa. Please check for the following if your dishwasher is not working--
1. Fuse (blown or tripped).
2. 120 VAC supply wiring connection faulty. Repair or replace wire fasteners at dishwasher junction box.
3. Electronic control board faulty.
4. Motor (inoperative, check resistances).
5. Door switch (open contacts).
6. Door latch not making contact with door switch.
7. Touch pad circuit defective.
8. No indicator lamps illuminate when START or OPTIONS is depressed.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 18, 2009 | KitchenAid Dishwashers
Lights are on, but dishwasher will not start. Called a local repairman. He decided the control board failed. he ordered a new board and replaced it. Now he says the new board is defective. I think...
That model has an electronic thermal fuse that clips onto the control board housing. the dishwasher will not start if that fuse is blown. you can check it if you have a meter. If it has continuity through it, its good, if no continuity, replace it. They cost between $20-$30. If that is not the problem, I would be looking at that motor. Kitchenaid makes a great dishwasher, but I can't count how many motors I've had to replace in them. Hope this helps, good luck.
Oct 16, 2009 | KitchenAid 24 in. KUDU02FR Built-in...
Fuses blown & controller card fried
Take this from a 4 board and 9 fuse owner.I believe the ceramic thermal fuse does not blow quick enough and during voltage spikes,or under a load cause overheating of the control board.All my boards had burnt marks on the back of the board(apposite where the 4 prong plug goes).I purchased a new board ,new ceramic fuse with the wire.They say the wire must be replaced too.(Ebay under Whilpool dishwasher fuse 14.00) Next on Ebay I purchased a 15 amp marine push button circuit breaker which I mounted in the side of the front panel.Split the one leg going to the ceramic fuse,run it to one of the legs of the breaker and run the other side of the breaker leg back to the ceramic fuse.I know someone out there is saying you don't need the ceramic fuse if you have the breaker in the line.Humor me.Lets say you get a large surge that fries the breaker closed as in a lightning storm.The ceramic fuse may save the day.Since I have set ours up this way the breaker trips once in a blue moon.Reset it and your off and running again.Oh and don't bother calling Whilpool(makers of Kitchenaid) You can't get anywhere with them.Now if for some unfortunate reason this doesn't solve your problem,don't throw away that dishwasher.Remove the upper and lower baskets,bolt them to the trunk of your car and the next time you go to the car wash bring your dishes with you.LOL
Jul 26, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Trying to access the pump and motor section
You should check the thermal fuse problem listed elsewhere on this site. My power went out on mine, and it was a cheap {less than $20 part} that snaps into the control panel. It eventually blew again a month later, and I replaced the heater element, and the new heater element came with a new board that was very easy to install. the new programming on the board actually speeds up the cycle due to a higher wattage heating element.
But what I didn't do the first time was replace the wires going to the thermal fuse that came with the replacement kit. (Apparently the OEM wires are too thin) Had I done that, I probably never would have tripped the fuse again and not bought the new heater element.
Jan 08, 2008 | KitchenAid 24 in. KUDI01FLSS Stainless...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
173 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
