Question about Garmin Forerunner 305 GPS Receiver
I have the forerunner 305 - it is not taking a charge and won't turn on??? I have only used it 4 or 5 times
  • afuentes127 Jan 25, 2009
    I cant turn it on, it works fine on cradle but as soon as I disconect the device it turns off, I have tried reset but didn t work
  • randi325 Feb 04, 2009
    I have had the same problem. And it turned itself on after a couple days, but then the problem occurred AGAIN this morning. It is really frustrating and would like someway to "fix" this permanently.
Plug in the garmin to the wall.
Hold down the reset and mode buttons for 3 seconds.
Try to turn it on or look for the "charing in process" words.
Posted on Jan 22, 2009
I didn't do anything - it just started charging itself and now its working????
Posted on Jan 18, 2009
Garmin Forerunner 305 won't turn on and won't charge. Is there a fix or is this it for the device?
Look at
"http://www.activesplit.com/my-garmin-forerunner-305-doesnt-power-on-its-just-dead-solutions/"
You can soft reset or hard reset the device. Hard reset deletes all data.
Apr 01, 2010 | Garmin Forerunner 305 GPS Receiver
Garmin 305 would not turn on after a ride. would
Reset your unit by pressing the "Mode"(reset/lap) and "Power" buttons at the same time. afte it turns on run system updater on computer
Jan 10, 2010 | Garmin Forerunner 305 GPS Receiver
Ive not had my garmin 305 long, it will not charge or turn on.
This might just need a reset. To reset the Forerunner or Edge 205/305:
  1. Connect the device to the computer using the USB cable
  2. Press and hold the mode and reset (lap) buttons together for 10 seconds
  3. Release and wait for 3 seconds
  4. There should be some indication of battery charging (either Finished or In Process)
  5. Power the device on while keeping it connected to the computer
In addition, please make sure that the device has the latest software version available by downloading and running the WebUpdater program. To update the software, please use the following link:
http://www.garmin.com/products/webupdater/
Sep 21, 2009 | Garmin Forerunner 305 GPS Receiver
Forerunner 305 keeps beeping, turning on and off every 5 seconds
I think I had the same problem. You do not write if your device were connected to the PC. My device was, and I finally got the suspicision, that it died because the battery was so low, that it crashed when the PC polled it as an usb unit.
So, I connected the unit directly to the charger unit that came with the unit, and now it works. So, try to connect directly to your charger, when your battery is totally drained.
Sep 16, 2009 | Garmin Forerunner 305 GPS Receiver
Garmin Foreruner 305 will not turn on or charge
I had the exact same problem and thought my beloved forerunner 305 had finally died. Try pressing the lap and mode keys simultaneously, and then power on. That may do a "soft reset." Worked for me.
Jan 05, 2009 | Garmin Forerunner 301
My Forerunner 305 was working when I ran today.  I just went to download and the 305 is completely dead.  No display when pressing 'on', and none in charging deck. What do you recommend? Thank you.
Press the reset and mode button simutaneously to reset watch
...then press the mode and start button at the same time for several seconds to start the watch up
Dec 22, 2008 | Garmin Forerunner 305 GPS Receiver
Battery doesen't keep the charge. I can't open the case to change battery forerunner 305
Hi Samdot,
I have just been through a similar problem through ingress of water into the device (They are not in the slightest bit water proof)
My device would power on, but only in the cradle attached to the usb and it would say the battery was fully charged after 4 seconds.
Any way, the battery can be replaced using the following method.
Take a decent, thin penknife and gently lever the top off the Garmin (follow the crease above the buttons). There are no catches to be aware of it is just lightly glued.
Once the lid is off you will be able to remove the two circuit boards (they just sit in there) and you will see the battery in the bottom of the case.
Unscrew the two small screw above the battery connections and you will be able to replace the li-ion battery which is in place.
I can provide images if that would be useful.
Phil
Jun 17, 2008 | Garmin Forerunner 305 GPS Receiver
Forerunner 305 won't charge
Question: My Edge or Forerunner 205/305 won't power on. Is there a soft reset that I can do?
From the Garmin web site.
--------------------------------------------------------------------------------------------------------------------------------------------- Answer: If a Forerunner or Edge 205/305 is unable to power on, a soft reset can be performed to un-freeze it. This will not erase any user data and is most effective if the device is connected to the computer while performing the reset.
May 26, 2008 | Garmin Forerunner 305 GPS Receiver
NO life in my Forerunner 305
There is a hidden recessed button on the right side of the Garmin. Press this button and it should reset the unit and it should turn on immediately.
Jan 13, 2008 | Garmin Forerunner 305 GPS Receiver
Garmin Forerunner 305 usb cable won't be read
The problem is probably not with the USB cable if the GPS wont even turn on. The older firmware of the Forerunner 205 and 305 have a problem with locking up. This causes the Forerunner to look completely dead. There is a reset procedure: push the mode and reset button at the same time and then let go and hit the power on button. If it powers on that is the problem. Go to the Garmin site and load the newest rev. of firmware into the Forerunner. Fixed mine and a few friends with the same problem.
I do however have a cable problem. Sometimes my PC will come up with unrecognized USB device and my 305 wont talk to the PC, it does charge. It is the cable or dock for sure, because I have tried a different cable/dock and the 305 has no problem. This is the reason I ended up here. I hope the lock fix works for those with the above problem.
Dec 16, 2007 | Garmin Forerunner 305 GPS Receiver
Garmin Forerunner 305 GPS Receiver Logo
217 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
