Question about Kitchen Appliances - Others
Water Leak from top heating element in Whirlpool Water Heater
Do I need to replace top heating element? Whirlpool was talking about a cleaner for corrosion. Do I need to replace the top heater element plus add the cleaner? Or will just the cleaner work?
  • 3 Answers
SOURCE: Whirlpool Dishwasher Heater Element
service manual for gu1200 and 1500
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/52521bdbd0ef763c85256cbc00520548/$FILE/8178022.pdf
Posted on Jun 12, 2008
  • 68 Answers
SOURCE: I have a Whirlpool 30
It is not unusual for an element to fail when turned on after non-use.
Turn off the power, and check the electrical resistance of each element. If either is infinite, then it needs to be replaced. Also, if only one is bad, then it can cause the whole unit to malfunction and not heat the water.
Posted on Jul 14, 2008
picatudo
  • 239 Answers
SOURCE: Water Heater Connections
there is no extra conectio,n it is just a pressure release valve
Posted on Jan 02, 2009
picatudo
  • 239 Answers
SOURCE: I have a Whirlpool hot
faulty, replace it because that leak has damaged the tank inside it must all rusty and will give up soon
  • 117 Answers
SOURCE: Replace Heater Element for Whirlpool Model GU 1200XTLB1 Dishwashr
Look inside the dishwasher to see where the heating element terminals are. If they are in front you might be able to change it but if the element is in back, you will need to have the dishwasher pulled out to install the element.
http://tclaundryrepair.com/
Posted on Feb 20, 2009
Water only stays hot for about 5 min or
Gas or electric?
Electric water heater ... then test for crossover, check for water leak, replace thermostats, test elements
Gas water heater ... test for crossover, check for water leak
http://waterheatertimer.org/Crossover.html
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
http://waterheatertimer.org/How-to-test-water-heater-element.html
water leak: turn off all taps and put ear against pipe and listen for water leak... check if water meter advances when all water taps are off.
Gene
Oct 09, 2014 | Water Heaters
I have a water cooler with bottle on top and heater does not work for the hot water side
The model number is not a good number, but check the heating element make sure it is working, check the thermostat power to it and through it, if power through it but not going through it replace thermostat. if going through it to heating element and element not getting hot replace heating element.
Jul 11, 2014 | Whirlpool GI15NDXTSS
Water heater heats water and then cuts off. I replaced the lower element with a guaranteed for life element. It still heats up and cuts off. There is a control box on top that allows for an easy reset. ...
1) Bad thermostat or thermistor depending on model.
Whirlpool/Craftmaster/American energy smart has control box on top, and you can order parts from Whirlpool.
2) Copy following links to help identify product.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
http://waterheatertimer.org/Whirlpool-Energy-Smart-electric.html
3) Add a comment with more detailed information:
You have electric water heater.
Unknown brand, possibly energy-smart.
Unknown control box.
Cut off? Do you mean 'reset' is tripped?
4) Whirlpool energy smart requires 10 gauge wire and 30 amp breaker.
Control panel may not function with undersized electric supply.
Control panel has blinking-light errors ... if no error code then maybe the control box is bad.
Jan 18, 2013 | Water Heaters
Water is not getting hot
1) Copy following link for detailed troubleshoot resources:
2) How are you testing a 240Volt water heater and getting 12.5? Or 60?
Dec 15, 2012 | Whirlpool Water Heaters
Hi...I have a Whirlpool water heater and the water only stays hot for a few minutes. How do I adjust the temperature or settings so that I can have hot water all the way through the shower instead of...
I am guessing this is an ele water heater and the temp setting are not the problem.
Problem: Not enough hot water or water temperature too low. When the top of the tank is hot the upper thermostat removes power from the upper heating element and transfers the power to the lower thermostat and heating element. If the lower thermostat is defective, then the lower portion of the tank will not be heated and the supply will be greatly reduced.
Check for power at the upper thermostat terminals where the power is sent to the lower thermostat and heating element. If there is no power then the upper thermostat should be replaced. If there is power then check for power at the lower heating element. If there is no power at the lower heating element then replace the lower thermostat.
If there is power to the lower heating element then it should be getting hot. If it is not, replace it. Another possibility is a broken dip tube. Check for a broken dip tube and replace if necessary.
The dip tub is located under the fitting where the hot water comes out.
Feb 03, 2011 | Whirlpool Water Heaters
After connecting a drain line to the pressure relief valve of my MR85245 water heater, I now have water leaking badly out of the heating element door.
Turn off the electricity.
Turn off the water valve going into tank.
Open a bathtub spout to let hot water pressure off the tank.
Check top of tank for any leaks.
Open the top access panel and see if element is leaking.
Open bottom access panel and see if lower element is leaking.
The reduced pressure on the tank will slow the leak.
If element is the problem, you can squeak by for a while by turning on the hot water heater only when you need hot water.
Order the 'Marathon MR85245 replacement element' online
http://www.gpconservation.com/rheem/marathon-sp213670-titanium-4500w-lower-element
These elements may be available locally, but they are not the same as 'ordinary' tank-type electric heater elements that you buy at the hardware store.
Buy more than 1 element because the Marathon elements have problems.
One of the reported problems with marathon elements is the high price of stainless steel replacement elements.
Drain tank.
Replace element.
Another resource for water heater information is:
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Nov 04, 2010 | Water Heater Innovations MR85245 High...
To check the elements hot water hearter stop heating.whirlpool electric
While the power is off to the water heater it's safe to remove the access panels. Once the elements are exposed a multimeter that is set on the Ohms can be used. The average reading of a good element is around 12 ohms. This can range a few ohms up or down. If you don't get a good reading the element will need to be replaced.
If the water heater has two elements the top element should be checked first. When a Whirlpool heater has two elements and the top goes out this will cause the water heater not to heat at all.
If both elements show they are good it would be recommended to contact the manufacturer. The technical support line for the Whirlpool water heaters is 1-877-817-6750.
Sep 02, 2010 | Whirlpool Water Heaters
We just bought a new water heater and it's not heating up water.
The heating element was bad. It's hard to believe that a brand new water heater would have a burn element, but that's the problem. I replace the heating element and its started working properly.
Dec 01, 2009 | Whirlpool Water Heaters
Hot Water Heater Trouble
(1)Have the unit check for electric voltage to the element
If voltage going to the element and no heating
(2)Your heating element may be defective.
(3) Have it replace by qualified personel
Mar 27, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Kitchen Appliances - Others Logo
105 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
