INCREASE MEMORY FROM 4GB TO 8GB.
Hi, I'm trying to increase the mem from 4gb to 8gb.
The motherboard is a Asus P5K Deluxe, CPU is 2.4 intel core duo,64 kilobyte primary,4096 kilobyte secondary. The memory is 4x2GB Corsair DDR2 XMS2. With 4GB it runs ok, when I increase it to 8GB, I get a message saying the graphics card has lost it's driver. I've altered the DRAM voltage upto 2.20 v, and the Northbridge upto 1.55v, but it's still the same. The graphic card is ATI RADEON 1650.
Regards,
N.S.Cobain.
  • nscobain Jan 20, 2009
    Yes it's Vista 64 bit.
  • 170 Answers
Do you have a 64 bit system? If not you are wasting money. 4 Gigs is the max on 32 bit systems
Posted on Jan 17, 2009
    Sergeant:
  • 378 Answers
It must getting a software conflict.or its supporting your operating syatem also try changing the graphics card or the loading the drivers for youer card again and it should work.
  • 258 Answers
Ues the crucial website and scan your system
crucial.com
Excellent experties, service, prices and quick delivery
  • Peter Conway Jan 17, 2009
    Sorry, didn't see the comment below, will re-submit a solution as a comment,
    apologies again
    HPC
Asrock gm31-gs optical drive
Hello here is the homepage:
http://www.asrock.com/mb/Intel/G31M-S/?cat=Download
Update any drivers for your windows system, if any missing, or you could have a faulty drive.
Good luck
Jan 05, 2013 | ASUS P5K WS INTEL CORE2 EXTREME/CORE2...
What arethe compatible components of this kind motherboard
CPU P5KPL-AM empty.jpg Valuable Intel G31 uATX solution with FSB overclocking 1600MHz!
- Intel® Core™2 Quad Ready
- Intel® 45nm CPU Ready
- FSB 1600(O.C.)/1333/1066/800 MHz
- Intel® G31/ICH7
- Dual channel DDR2 1066(O.C.)/800/667
- EZ Flash2 & CrashFree BIOS3
- 8 Channel High Definition Audio
Intel® Socket 775 Core™2 Quad/Core™2 Extreme/Core™2 Duo/Pentium® D/Pentium® 4/Celeron® E1000 Series and Celeron 400 Series Intel® Hyper-Threading Technology ready
*Refer to www.asus.com for Intel CPU support list
Chipset Intel® G31 Intel ICH7
Front Side Bus 1600*/1333/1066/800 MHz (*1600 is overclock speed) Memory 2 x DIMM, Max. 4 GB, DDR2 1066(O.C.)/800/667 Non-ECC,Un-buffered Memory
Dual Channel memory architecture
*Overclock speed
**Refer to www.asus.com or user manual for Memory QVL (Qualify Vendor List)
***When installing total memory of 4GB capacity or more, WindowsR 32-bit operation system may only recognize less than 3GB. Hence, a total installed memory of less than 3GB is recommended. Expansion Slots 1 x PCIe x16
1 x PCIe x1
2 x PCI
VGA Integrated Intel Graphics Media Accelerator (Intel® GMA 3100)
Max. resolution:2048x1536X32bpp, Horizontal:127.5KHz Vertical:85Hz Storage Southbridge
1 xUltraDMA 100/66/33
4 xSATA 3 Gb/s ports
LAN Realtek RTL8102EL 100/10 LAN
Audio VIA VT1708B 8 -Channel High-Definition Audio CODEC
Anti-Pop Function
Jack-detect & Multi-Streaming
Support S/PDIF Out connector USB 8 USB 2.0 ports (4 ports at mid-board, 4 ports at back panel) Overclocking Features SFS (Stepless Frequency Selection)
- FSB tuning from 200MHz up to 600MHz at 1MHz increment
Overclocking Protection
- ASUS C.P.R.(CPU Parameter Recall)
Special Features ASUS MyLogo 2
ASUS EZ Flash 2
ASUS CrashFree BIOS 3
ASUS Q-Fan
Back Panel I/O Ports 1 x Parallel
1 x VGA
1 x PS/2 Keyboard
1 x PS/2 Mouse
1 x LAN(RJ45) port
4 x USB 2.0/1.1
1 x COM port
8 -Channel Audio I/O
Internal I/O Connectors 2 x USB connectors support additional 4 USB ports
1 x Floppy disk drive connector
1 x IDE connector
4 x SATA connectors
1 x internal speaker connector
1 x S/PDIF Out connector
1 x CPU/ Chassis/ Power Fan connector
1 x Front panel High Definition audio connector
1 x Chassis Intrusion connector
1 x CD audio in connector
24-pin EPS 12V Power connector
4-pin ATX 12V Power connector
1 x System Panel connector
BIOS 8 Mb Flash ROM
DMI 2.0
AMI BIOS
PnP
WfM 2.0
SM BIOS 2.5
ACPI 2.0
Manageability WOL,PXE,RPL,WOR ,PME Wake Up Accessories User's manual
1 x UltraDMA 133/100/66 cable
1 x Floppy disk drive cable
1 x SATA cable
1 x SATA power cable
I/O Shield
Support Disc Drivers
ASUS PC Probe II
Anti-virus software (OEM version)
ASUS Update
Form Factor uATX Form Factor
9.6 inch x8 inch ( 24.4 cm x 20.3 cm )
hope this helps
Jul 18, 2011 | ASUS P5KPL-AM - Motherboard - micro ATX -...
Asus 1366 X58 - Lights up on power. No diagnostic
The symptoms are problem at the CPU. Extract i7, check it vissually and try again. Try with one stick of memory too.
Stelios.
Feb 22, 2010 | ASUS P6TD DELUXE Motherboard LGA 1366...
What are the compatible processor for asus p5p800 mx
Asus P5P800-MX Motherboard Features
64bit CPU support
64-bit computing, the next generation technology to replace current 32-bit architecture, delivers advanced system performance, faster memory access and increased productivity. This motherboard provides excellent compatibility and flexibility by supporting either 64-bit or 32-bit architecture.
Intel EM64T
Intel EM64T (Intel Extended Memory 64 Technology) allows processors to run newly written 64-bit code and to access larger amounts of memory, which delivers exceptional graphic performance and higher data processing speed. Digital media applications can take advantage of Intel EM64T in high quality video and audio processing as well as 3D rendering.
Intel EIST
Intel EIST (Enhanced Intel SpeedStep technology) automatically adjusts Intel 64-bit processor voltage and core frequency according to system performance demand, establishing a self-managed, lower-power consumption, less heat and quieter environment. Combined Intel EIST and ASUS Q-fan technology (adjusts fan speeds according to system loading), this motherboard provides excellently quiet, cool and efficient platform for Intel lovers.
Intel 865GV chipset
Leveraging the Intel 865GV chipset to support P4 CPU on 800MHz FSB, Dual-channel DDR 400 memory, Intel Hyper-Threading Technology, and a full-range of advanced features, P5P800-MX really delivers a full-value, high-performance solution for today's most demanding tasks.
Intel LGA775 Pentium 4 CPU
This motherboard supports the latest Pentium 4 CPU from Intel in LGA775 package. With 800MHz FSB, 1 MB L2 cache, Hyper-Threading Technology and core-speeds up to 3.6GHz and beyond, Intel's LGA775 Pentium 4 is one of the fastest desktop processors to date.
Jul 27, 2009 | ASUS Computers & Internet
Memory Upgrade
Depends of your buget, Extra 4 GB DDR2 800 = $35 (total 8GB) I Have 4GB installed now seems fine, but all of this is necessary?
what application do you need to work?
Mar 27, 2009 | Computers & Internet
P5k motherboard
remove the ram, do you hear beeps?
you might want to get your hands on one of these
http://cgi.ebay.com/New-8digit-PC-Motherboard-CPU-Ram-Analyzer-Test-Card_W0QQitemZ190231285206QQcmdZViewItem?IMSfp=TL0806211611r25031
if link broken click here
Reseing the bios shouldn't be a problem go ahead, or is there something I don't know? does it void the warranty? I don't think so.
Jun 23, 2008 | ASUSTeK P5K Desktop Board - Core 2 Extreme...
Raid sys on p5k/epu
You are correct. The Asus P5K does support SATA RAID configuration. Page 4-14 in the user manual.
Congifuration [Enhanced]. Only real option is IDE. That does not mean the SATA drives will run like an IDE. The SATA's will function faster. In order to get RAID function you would need to have bought the Asus P5K Deluxe. http://support.asus.com/download/download.aspx?modelname=P5K%20Deluxe/WiFi-AP&SLanguage=en-us
Mike
Jun 06, 2008 | ASUSTeK P5K Desktop Board - Core 2 Extreme...
Wont post with 1333 fsb
This board wont take a 1333 cpu. The fastest it will run is 1066
This motherboard supports the latest Intel® Pentium / Celeron CPU in LGA775 package with 1066/ 800/ 533MHz FSB, Hyper-Threading Technology and core-speeds up to 3.8GHz and beyond.
Make sure your RAM is DDR2 800mhz
The Pentium D830 runs at 800fsb which is in line with the board capabilities.
Feb 24, 2008 | ASUS P5ND2-SLI Deluxe Motherboard
Computers & Internet Logo
104 people viewed this question
David Payne
David Payne
