Microsoft Xbox 360 Console
Problem for Microsoft Xbox 360 Console
Xbox 360 disk tray will not open
By phillyeagles on Jun 22, 2007
Ever Since I opened the box, when I go to put in a disk, the disk drive only comes out a little bit then goes back in. I've looked on other websites and have tried the paper clip trick (the drive is the one which uses the second hole from the left) and adjusting the face plate. When I tried the paper clip trick, I felt like I was spining the cog, but the drive wouldn't open. I can't send it in to Microsoft either because the tamper sticker had been removed before I got the system. Please Help!!
Clarification Request
Posted by ramjan on May 04, 2009
Solution Link . . . www.MicrosoftXbox360Console.com
Same Problem
May 06, 2009
-   disk tray wont open on the first attempt.. can take up to 20 presses of the eject button for the tray to actually open. mines a 360 elite. -   Guest
Apr 28, 2009
-   Ever since I bought my Xbox 360 the disk drive door would not open unless i bashed it against the side. I was stubborn and just put up with this problem for far to long. I really don't want to pay to send it in and have it fixed. Can I fix the problem my self? I have already opened the Box but have not clearly identified what the problem is. -   akmadrippa
Apr 12, 2009
-   Disc tray not opening and controller not being detected either :( -   Guest
Apr 05, 2009
-   i need help!! my xbox on/off button flahes automatically, opening then closes, but when thers no disc it and its closed. it says reading. the disc tray wont come out. paper clip trick diddnt work :( somebody help me please !!! -   Guest
Mar 04, 2009
-   i think their is a little crack on the bottom of my xbox 360 and every time when i try to open it it just nudges a little and im tring to find a disc tray online-   Guest
Solution #1
posted on Oct 20, 2008
Not Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
ok first go to 3pic.com then youll see instructions it shows u how you open when not opening and how to stop ur disk from spinning when the disk tray is opening
Solution #2
posted on Jun 27, 2007
Very Helpful)
Hoyt
Rank: Apprentice
Rating: 93%, 46 votes
The reason the drive tray will not open is due to the belt on the motor slipping. This is a common problem with ANY optical disc drive that uses a belt and motor combination instead of direct drive gears. When the belt gets old, or in the case of the 360 VERY HOT it will stretch and slip. When it slips it can not break the magnetic clutch free that is on the spindle (the nubbin that goes through the center of the DVD disc) and the tray can not open.
What you can do is disassemble the drive and take the belt off (it is in the front of the unit under the tray) and take it to an electronics supply house and have them match it up. This process was common in the old days of repairing VCRs. A popular company that makes all types of belts is PRB (Projector Recorder Belt Company). The salesman has a chart he can measure the belt with and give you a replacement.
If you are in a hurry you can put the belt in boiling water for a couple of minutes to shrink it and it will work for a short while, but as hot as the 360 DVD drives get you should really match it up and get a couple of spares, you will probably encounter the problem again (especially with the Samsung drives; even the original Xbox Samsung drives were bad about this problem).
In every case where I have encountered either Xbox with a DVD drive tray that would not open the slipping belt was the problem (and I have fixed a BUNCH of them).
Hope this gets you going,
Hoyt
Comments:
Oct 20, 2007
- I just thought I'd post the part number for the belt.  It is a PRB number SCX 2.6.  I just fixed another one and figured the info might help someone.
Oct 21, 2007
- I forgot to mention that the SCX 2.6 is for the Samsung drives.  On the 360 I don't recall seeing the other brands of drives do this much, so I don't know a part number for those.
Feb 24, 2008
- I also figured I should mention that if you open the tray and are VERY careful you can replace the belt with a pair of hemostats through the opening. This way you do not have to disassemble the drive, but if you let the belt slip off it will fall down inside the drive and you would then probably end up taking it apart.
As to the user that mentioned that gears could also be the problem the only time I have ever seen gears involved in this problem was when the user pried the tray open with a screwdriver and broke them. As usual, the problem was caused by the belt slipping. In about thirty of these repairs I have done the original problem was the belt every time.
If you have a drive that will not open and it is not too bad just after you press the eject button rap on the top of the unit above the DVD drive with your knuckle. This will usually pop the clutch loose and allow it to open and then you can replace the belt. If it will not open this way then use the paper clip through the emergency eject hole.
These methods I just mentioned will work with the Samsung drives in either the original Xbox or the 360.
Was this helpful?
Yes
No
6 people thought this was helpful
Solution #3
posted on Apr 26, 2008
Helpful)
Lifelong
Rank: Apprentice
Rating: 95%, 41 votes
I have the solution my friends :)
<object width="425" height="355"><param name="movie" value="http://www.youtube.com/v/5mVjVXZtOms&hl=en"></param><param name="wmode" value="transparent"></param><embed src="http://www.youtube.com/v/5mVjVXZtOms&hl=en" type="application/x-shockwave-flash" wmode="transparent" width="425" height="355"></embed></object>
Comments:
May 13, 2008
- There you go guys, and your all good....THE solution to your problems
Was this helpful?
Yes
No
32 people thought this was helpful
Solution #4
posted on Aug 10, 2008
Helpful)
tom 450
Rank: Apprentice
Rating: 94%, 24 votes
when the xbox is trying to open use the base of your hand and give it a quick hit it opens up perfectly then and if you leave a game in it it will not stick again i use this all the time when it makes  the noise like a click give it a moderate hit then  it wil pop open
Was this helpful?
Yes
No
18 people thought this was helpful
Solution #5
posted on Apr 08, 2008
Helpful)
Liystalander
Rank: Apprentice
Rating: 92%, 42 votes
This worked for me!
Was this helpful?
Yes
No
29 people thought this was helpful
Solution #6
posted on Jul 05, 2008
Helpful)
Hexie
Rank: Apprentice
Rating: 92%, 13 votes
I've had this same problem for most of the life of my console. The funny thing is I originally sent it in for a problem relating to the Red Rings of Doom, and got it back with a malfunctioning drive. Originally I solved the problem by permanently keeping a disc in the tray. Sadly a friend was playing GTA4 on there and took the disc out, and didn't replace the disc that was in the drive before when he was finished. Now the drive is jammed shut. I can't even hear it trying to open the drive. In short I'm severely annoyed and probably about ready to have a coronary.
Was this helpful?
Yes
No
7 people thought this was helpful
Solution #7
posted on Apr 27, 2008
Helpful)
BoogerBill41
Rank: Wiz
Rating: 81%, 46 votes
Hoyt has the correct answer. Read his listing above or get a different video game system all together!
Was this helpful?
Yes
No
Solution #8
posted on Nov 14, 2007
Helpful)
vdnovach
Rank: Apprentice
Rating: 86%, 7 votes
I found a solution to spending all the money for new belts and it only cost me $0.98. I went to Walmart and bought a package of the rubber ponytail holders and they work great. The added bonus is you get like a hundred in the package so they wil last awhile.
Was this helpful?
Yes
No
3 people thought this was helpful
Solution #9
posted on Nov 21, 2007
Helpful)
titanfan4758
Rank: Apprentice
Rating: 84%, 8 votes
This is a great video clip relating to this problem!
Was this helpful?
Yes
No
Solution #10
posted on Aug 26, 2008
Helpful)
maniac983
Rank: Apprentice
Rating: 83%, 3 votes
The two things I did to get mine to open were:
1: Test to see if the large pulley will spin freely after you remove the gears so you can test it, and if it does a turn or two on it's own when you spin it, then it should be fine, but if not, then pull of the large pulley, and check the lubrication on the hub it was on to see if it has gunk in it, and if it does clean the lubrication off, and put new lubrication on, or just put the pulley back on and test to see if can spin freely again, and if it does then put it all back together, with the top of drive case, and see if it'll open up alright, if not then your belt is stretched out, so onto step two, which is really easy.
2: Use a little rubber band, that you can loop around the big pulley several times, then put the drive together again, and try again, since the little rubber band basically expands the inside of the pulley making the belt tight again.
I did both of these to get my 360 drive to open, since I bought it with a stuck drive tray off ebay in the first place, I had every intention of opening it up, but if you don't want to, or can't, then you should find the method somewhere on the internet that tells you how to take off the belt without opening your 360 using tweezers or whatever, and see if you can get a rubber band wrapped around the big pulley, anyway, I hope this helps somebody.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #11
posted on Jun 26, 2007
Helpful)
halberd
Rank: Apprentice
Rating: 82%, 10 votes
my mate had the same problem there is a simple solution why it doesn't open. the xbox 360 was probaly drop before getting to you!once drop because it is so fradgil and made from cheap plastic it jams it inside
Was this helpful?
Yes
No
Solution #12
posted on Apr 30, 2009
Somewhat Helpful)
sadfgh
Rank: Master
Rating: 78%, 29 votes
Try this link . . . www.microsoft.com/Xbox360Console
To find your best solution.
15
Was this helpful?
Yes
No
Solution #13
posted on Feb 06, 2008
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
ok for one all of your a mostly idiots. the xbox 360 is not cheap plastic. 2 there are multiple problems here for one the belt, two not hte belt it can be the gears. but the easiest solution here i think is just u take the front of the xbox bring it up about 2 centimeters and drop it. the disc tray will open
Solution #14
posted on Jan 21, 2008
Somewhat Helpful)
Fixed it
Rank: Apprentice
Rating: 75%, 2 votes
well my 360 won't open either and if you press the open button and then keep pressing in on the actual drive it sometimes opens. but if your like this hoyt dude and you love to open your 360 then your a crackhead.
Was this helpful?
Yes
No
Solution #15
posted on Jan 13, 2008
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
the xbox 360 uses a lot of cheap parts so it is the most easy system to break. microsoft is cheap
Solution #16
posted on Oct 14, 2007
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
just keep on pushin the open button and dont stop
Solution #17
posted on Dec 07, 2009
Not Rated)
kentkrajick
Rank: Apprentice
Rating: 0%, 0 votes
SIMPLE TO FIX DOOR NOT OPENING!
Looked at the video on how to replace the belt (in previous siloution). Heres how it is done:
1) virtually all XBOX use samsung drives. can get replacement on line from richspsxparts.com (TS-H943A Samsung DVD drive belt)- $6.95, free shipping.
2) as noted in video, open drive (by tapping on hard on top when hitting open button if needed), unplug power.
3) you see see belt on top, on 2 drives, One small, in back, bigger one in front. Use toothpick to take off belt- careful to not have it fly off).
4) put on new belt (you should notice your replacement belt is smaller, as the old one probably has stretched). Put on small drive in back first, as it is harder to reach. Then put belt on backside on large drive in front and gently stretch belt with toothpick aqroud to the front of drive..
Once on, turn drive with your finger and the door should close- If so- it is fixed. Be careful to ensure belt is straight and didn't get twisted when you put it on. By turning by hand you should see if it is.
hope it helps!!!!!
Was this helpful?
Yes
No
Solution #18
posted on Dec 06, 2009
Not Rated)
greg687_w
Rank: Apprentice
Rating: 100%, 1 votes
Dirty drive belt on mine. Cleaned it and it's working fine, though a replacement will be in order soon I figure. Thanks for all the help on this site!
Was this helpful?
Yes
No
Solution #19
posted on Jul 18, 2008
Not Rated)
daddy31
Rank: Apprentice
Rating: 0%, 0 votes
hey thanx titan...that really helped. i did it a couple times and it finally opened. thanx again
Was this helpful?
Yes
No
Solution #20
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
thx for video titan very helpful!
Solution #21
posted on May 30, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
i am able to swap the sammy drive belts without opening console, by tilting it with the tray partly open
Solution #22
posted on May 17, 2008
Not Rated)
Scootre
Rank: Apprentice
Rating: 0%, 0 votes
Lifelong gets my legend award! Nice work man. Good solution to the problem. I can offer some additional advice based on what I learned from your excellent video and tips.
I've lived with this problem since the XBOX was new and I refused to take it back because there was no other problem with the thing... so didn't want to risk getting a replacement with some other MS sponsored known problem.
Lifelong's solution shown in his video clip works perfectly. But I can add to this by saying BEFORE you try taking out that drive belt (it's pretty easy but there's a small chance you can drop it inside the XBOX), try cleaning the belt with pure alcohol (isopropanol etc - but NOT anything oil based). Put some on a cotton bud and, referring to the video he posted, give the belt and particularly the wheels a clean. You can spin the wheels and belt back and forth by simply pulling the tray in and out a bit. Just be caureful not to catch large bits of the cotton bud between the belt and the wheels.
As soon as I did this, problem solved.
However, I did also see that my drive belt was a little loose, so slipping it off as shown in Lifelong's video and taking it along to an audio/video supplier to match the part should solve the problem long term.
Once again, thank you Lifelong from me and my kids!! :)
Was this helpful?
Yes
No
Solution #23
posted on May 12, 2008
Not Rated)
frankmanuk
Rank: Apprentice
Rating: 92%, 4 votes
i just put my xbox in the horizontal position and press open the tap the drive till it opens
Was this helpful?
Yes
No
Solution #24
posted on Mar 26, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
this has just happend 2 me and i allways thourght xbox was better den ps3 but ovessly not
Solution #25
posted on Feb 03, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
yeah man i xbox is doing the same thing, but now the eject button is starting to go haywire..... i really have to push hard to even get it to register that i want it to open.....really pisses me off, anyways thanks for letting me no that the belt is the main problem...also which systems have the samsung disc drive in them?
Solution #26
posted on Oct 04, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Umm no dude the xbox 360 is not cheap plastic, it is a 2 cased piece of technology the plastic case is 1, and on the inside there is a metal case. so HA!
Popular Solutions for Microsoft Xbox 360 Console
Questions and Unsolved Problems for Microsoft Xbox 360 Console
Do you recommend Microsoft Xbox 360 Console?
Answer
Answer
what are the wep64 codes and where can i find them cant get connected to my home hub
Answer
the picture is going fuzzy and the colour is wrong after a few minutes of playing a game.
Answer
my 360 has three ring problem and it's overheating.it's also not displaying on tv.
Answer
when i put a xbox 360 game in my xbox 360, it says i have to put the xbox 360 game in an xbox 360... (More)
27 Other Users Have The Same Problem - Continued
Comment by mr saintelus, posted on Feb 16, 2009
its like wen i press the button to open the tray i opens alil bit then it goes back in so wat should i do
Comment by tj shaw, posted on Feb 15, 2009
Comment by Guest, posted on Feb 03, 2009
lol mine when i go nto open i hear it trying to open and it doesnt and i dont wana burn out the moder so ima stop looking for fixes and send back to microsoft
Comment by Pyro515, posted on Feb 02, 2009
Yeah mine did the same thing i have to hit it one the edge of the 360 in front of the cd drive to get it to open then i have to hit it agian to get it to read the disk.
Comment by privatefunk, posted on Jan 04, 2009
my xbox wont open after i got 3 red lights. 1st the red light's and then the disk drive opened with the disk still spinning. now the disk drive wont open. I can still access xbox dashboard and the games i have on the h/drive, i just cant open the drive.
Comment by Guest, posted on Jan 04, 2009
my drive opens all the way and then it closes within a few secondss without me pressing the botton please mail me on kieran@madasaferret.org
Comment by hoffman_ride, posted on Jan 02, 2009
it wont open or close as many times i try the paperclip trick it just wont open or close for me plz help me
Comment by Guest, posted on Nov 22, 2008
The thing won't open
Comment by Guest, posted on Oct 23, 2008
i have the same problem i mean it takes about like 3-5-6 times b4 the disk drive even comes open. i never had that problem before but now i have had it since the beginnin of this yr 2008. i dont know why. can you pls help me
Comment by gabrielc, posted on Oct 15, 2008
when I open my disk drive,the disk is still spinning.
Comment by Guest, posted on Jul 27, 2008
yes
Comment by aefsrjsgfjr, posted on Jul 25, 2008
I have hade the console for almost a year and it has always worked fine. Recently a friend pushed in the disk tray by hand and it got jammed inside. Now when i press the button the tray doesnt open and there is a game still trapped inside. I then turned it on a few hours after it happened and i got the 4 red lights. What can I do?
Comment by dkflame32, posted on Jul 14, 2008
my disc tray wont stay closed
Comment by Guest, posted on Jul 11, 2008
disc tray wont close
Comment by Guest, posted on Jul 10, 2008
i have the same problem, if i do not leave a disk in the tray when i close it, it won't open up again, but if there is a disk in it, it works just fine.
Comment by jew frow, posted on May 18, 2008
My disk drive is the same but it started early on. but it just kept on getting worse. So I decided to take a look at it. I spraied some of the propper lube in it (White Lithium Grease). So i have decided to send my xbox 360 back in. I dont Know If they are going to say any thing about the lube i put in there. but why was your sticker removed???
Comment by dorrington, posted on May 15, 2008
every thing works exept the disc tray will not open, you can hear it trying but will not open.
Comment by Random Name, posted on Mar 17, 2008
I have the same problem and when it does open I put the disc I want in it and when I close it it will open again!!! I am actually starting to think that the xbox was a jip!!!!!!!!!!!! ):
Comment by Guest, posted on Dec 30, 2007
My disk tray won;t open either, and i have to knock on the back to open it. I have tried a lot of things and none worked
Comment by Guest, posted on Dec 17, 2007
disk
Comment by xobode, posted on Nov 15, 2007
My disc tray will not open and my game is stuck in there. I keep pressing the button to open the disc tray, but no luck. What do I do?
Comment by Guest, posted on Nov 03, 2007
the dick tray will not open
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Video Game... Experts
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
