Question about Bosch PS20 2 Factory Reconditioned 10.8V Litheon Pocket Driver
I have a drill bit stuck in my bosch 10.8 cordless litheon- it is
A standard phillips head bit which i was using in a quick release bit holder, (bad bad me), any ideas on how to extract it- I have tried every kind of pliers and etc, but it is a very small bit with just the tip protruding and nothing can really grab ..can you help  me? carolina clare sebastopol. ca
  • 2,176 Answers
Without having the exact model number for this tool I have in the past removed the outer collar on the quick release holder. After that you take out the small steel ball and the bit would come out but If you can provide the model I will look at it and see and call a friend that is a Bosch Authorized Service and see what they do in this case.
Posted on Jan 19, 2009
  • David Ford
    David Ford Jan 21, 2009
    Had another thought, can you pull collar and if so do you have a strong magnet that you can try and pull it out with.
DC212 does notlock the bits
First are you using the correct SDS style bit? They do not use just standard drill bits. They have two long cutouts on each side and two oblong ones on the opposite side. You should be able to push (and rotate to line up the slots in the bit with the tool) the bit in without touching the bit holder and it should lock into place. You push down on the holder only to release the bit. The holder is spring loaded with a small metal ball that contacts and holds the bit at one of the oblong sections.
May 16, 2012 | Dewalt Dc212 18 Volt Sds Plus Rotary...
I have a Hitachi WH 18 DFL cordless impact driver, which I love. I was doing a little bit of heavy drilling, and now the drill bit is stuck. The sleeve extends as if to release the bit, but the bit do
My guess is that the bit twisted a little in the bit holder so the steel ball is bound. If the collar moves you could try a slide puller on the bit and see if you can impact it out with the slide puller. Or you could take the bit holder apart. There is a retaining ring that holds it all together right on top. Pull that off and a washer, spring and the collar will come off. Becarefull to watch for the steel balls on the spindle. They WILL fall out! Now hopefully the bit will come out. If not it may need to be twisted in the oposite direction that it got stuck when you were using it to break it free. Hope that helps and good luck!
Jan 19, 2012 | Dewalt 18 Volt Compact Drill Kit
I have a Bosch Litheon Impactor 18V Hammer drill. I've had it for about two years and used it often so I'm pretty familiar with it's operation. I seem to have gotten a bit stuck in it. I really...
If the bits get a bit distorted they will stick, if you have a bench vise clamp the bit in the jaws and give the trigger a quick pull.(reverse) That should dislodge the bit. This happens quite often on lesser quality bits that are made of soft metal.
Aug 03, 2011 | Bosch Drills
New Black and Decker, 18 volt, cordless drill. I can't tighen the bit
I oil mine up to help the jaws move . also check the screw at the base of the chuck inside its a standard head. shine flash lite where you put the bit it holders the Jacobs chuck to the shaft.
Jul 07, 2011 | Black & Decker & Cordless Drill
I need to extract the printhead from a Canon MP540 printer in order to install a new one. I have just received an incomplete answer from FIXYA. When I turn on the printer and raise the cover, the...
The print head is not designed to be moved manually and damage may occur if you try to do so forcefully.
To center the print head to replace ink tanks and to replace/remove print head you should do the following:
1. Make sure power is turned on and open the Paper Output Tray gently. 2. Lift the scanning unit (cover) until it stops. Lift with document cover closed. The print head holder should move to the replacement position (center).
Do not force print head holder to move nor touch it while it's moving. These parts are very delicate and generally are made mostly of plastic.
IMPORTANT If the Scanning Unit (Cover) is left open for more than 10 minutes, the Print Head Holder moves to the right. In this case, close and reopen the Scanning Unit (Cover).
May 04, 2011 | Canon PIXMA MP540 All-In-One InkJet...
I am trying to take apart my cuisinart ice cream maker and 3 of the bolts are phillips but the last one I have no idea what kind of head it is and can not unscrew it. Is it some special cuisinart bolt...
Hey G,
This bit set has all the "special" safety bits you need... I have one and its always had what I needed..(even has the reverse three blade phillips head.. - they use them on police monitoring ankle bracelets) ....you will need a driver handle..
good luck..
100 Pc Security Bit Set with Case
Dec 16, 2010 | Cuisinart (ICE-20) 1.5 Quart Ice Cream...
Cannot remove bit from chuck brother-in-law put a small phillips head bit in the chuck
try to jam the chuck so its open. Put the forward and reverse so that it is slipping (like a grinding gear sound) and hold the drill upside down. If that doesn't work ,buy a screw extractor kit.
Oct 21, 2010 | Bosch PS20 2 Factory Reconditioned 10.8V...
Can you give me step by step on how to change drill bits on the Mastercraft Souce One 18V Cordless Drill.
pull the collar on the front forward and insert hex end of bit in and let collar go back. this locks the bit in.
Aug 29, 2010 | Bosch PS20 2 Factory Reconditioned 10.8V...
Bosch PS20 2 Factory Reconditioned 10.8V Litheon Pocket Driver Logo
1,064 people viewed this question
Top Bosch Drills Experts
Matt Olenzek
Matt Olenzek
woodzowl307
Are you a Bosch Drill Expert? Answer questions, earn points and help others
