Question about Sony PlayStation 2 (PS2) Console
Disc Read Error-My ps2 only reads certain discs
Recently, my PS2 has stopped reading all silver bottom discs. Now it only reads blue bottomed and Audio CDs. I've already tried cleaning the lense and moving the white gear around. Please help!
Try this thread it might help as well: http://www.fixya.com/support/t147428-disc_read_error
Posted on Jun 29, 2007
    New Friend:
  • 129 Answers
The optic needs to be replaced ,the part cost its around 45.00 but you need to provide model,serial# and manufactured date . or you can sen the unit for a repair around 120.00. let me know if you need more info
Posted on Jun 22, 2007
  • Luis Amado Jun 29, 2007
    any luck , more help? let me know
SOURCE:
PS2 will play any audio cd and any ps2 blue game disc. but it will not entertain a silver game disc or dvd. just keep getting Disc read error.
sounds like your laser is failing. You can find tutorials on how to adjust, clean or replace your laser. Do a google search for " ps22_bing.gif disc read error " it will give you a choice of plenty of tutorials to follow. Good luck
Feb 04, 2010 | Sony PlayStation 2 (PS2) Console
PS2 wont read Silver bottom games
really...mostly its the blue backs that mess up ..all i can say is if u have not already change you component video out in you configuration and change the disc speed and texture mapping.u can find that by going to the main screen and press triangle and go to ps driver and press triangle and pick the one u want to change..hope this helps :)
Aug 29, 2009 | Sony PlayStation 2 Slimline Console
Will not read blue discs no problem with clear(silver) ones tho.
1. Apparently, blue PS2 discs are lighter than silver ones, so they tend to move around more when the PS2 is reading them. To fix this, you can put duct tape on the top of the disc. This will make it heavier, so it won't move around too much and it should make reading the disc easier for your poor PS2. People have told me that this indeed works (but not always). Don't go overboard with the tape though. Attempt at your own risk. 2. If the problems occurs when the PS2 is horizontal, try putting it into its vertical position. Or try putting it horizontal if it is vertical. 3. Use a can of compressed air to clean dust out of the system. 4. Make sure your game discs are not the problem. Keep them as clean as possible. Even small scratches can cause problems. 5. Open up your PS2 and clean it out or try adjusting the lens. Very risky and voids your warranty. 6. Try using a DVD lens cleaner (for problems reading silver discs) or a CD lens cleaner (for blue disc problems). 7. Send your system to Sony for repairs. Due to a lawsuit, Sony may have to repair your PS2 for free even if there is no warranty. Contact Sony for details. That is all the advice I can give. If the len(s) cleaners or compressed air don't work, then you are probably just out of luck. There is no magic way to suddenly get your PS2 working again without professional repair.
The trick to getting the discs to play on any [email protected] (old or new) when they are black or blue is to put a piece of tape lengthwise and width wise around the hole in the disc on the topside (picture-side) of the disc. What this does is add weight to the disc and thus allows the PS2 to read it more accurately. I had bought many older titles not too long ago and was disappointed when they didn't work. Then I spoke with a Japanese expert online and he suggested using scotch tape around the hole in the disc and it worked instantly. Don't be fooled into buying a new PS2, just a roll of scotch tape. You'll only need four one inch strips.
Thank you for using FixYa - a FixYa rating is appreciated!!
Jan 27, 2009 | Sony PlayStation 2 (PS2) Console
My Ps2 wont turn on
take the ps2 apart and take the disc tray out the strip connects under it
Dec 28, 2008 | Sony PlayStation 2 (PS2) Console
My ps2 wont read normal disks
you might have something turned off in your settings ps2 settings.
Nov 25, 2008 | Sony PlayStation 2 (PS2) Console
Had ps1 game resurfaced, no longer works on ps2
Sounds like you need to get your money back ..the resurfaceing can also do more bad than good
But a little trick lightly rub a crayon over the disk ,,old pantyhose works great rub it off from center out then try your disk ,,have saved many good games that way
Nov 20, 2008 | Sony PlayStation 2 (PS2) Console
PS2 will not read disc for Guitar Hero
theres a difference in the older guitar hero games and newer ones, CD Rom for the older and DVD Rom for the newer, Ps2 wont read the DVD Rom ones, my experiance so far.
Oct 02, 2008 | Sony PlayStation 2 (PS2) Console
Silver bottom games
You may want to replace the laser
Mar 26, 2008 | Sony PlayStation 2 (PS2) Console
Play station 2 won't read silver disc only reads blue disc
Hi Elvis,
The Blue back disc is CD format. The DVD laser circuit is giving you trouble. You can adjust the DVD pot some on the back of the Laser. Turn it about 3 degrees clockwise. Then put it the laser back in. Test the PS2 with no cover on, and use the white round disc from the laser drive cover to clamp a disc onto the spindle. Test DVD and PS2 Games that do not have Blue back.
Nov 28, 2007 | Sony PlayStation 2 (PS2) Console
My ps2 doesnt read some of my games
This can sometimes be caused by the actual PS2 media. PS2 discs usually have either a silver or blue bottom. Silver is DVD media and Blue is CD media. Sometimes the laser mechanism gets a little wonky and can't read one type or another. Typically, older games had the blue discs (Kinetica and Gran Turismo are some of the oldest games on the system) I would check the color of your existing games and see if that is an issue. Another possible idea is that you just got a bad disc, it doesn't happen very often but it does pop up from time to time.
Aug 19, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
98 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
