Question about Xerox Phaser 7700 Laser Printer
Xerox 7700 prints with streaks that look like water running along
They seem to be in the same general area but not exactly the same, closer to the edges rather than the middle. They run in the print direction. This is in black print mode or full color.
  • fp_jacq Jan 20, 2009
    leroyal,
    My comment in header wasn't showing and it said the streaks look like water running along page. The problem was the same before I recently replaced the fuser rollers. Could it be anything else?
    Thanks,
    Frank
    Genius:
  • 2,120 Answers
The teflon may be worn off of the fuser rollers.
Posted on Jan 17, 2009
Streaky cyan, grip to back
I'm not sure which model # you have but if it's similar to the 7700 series you can try cleaning the laser window, if that doesn't change the problem it's probably the developer roller.
Mar 18, 2015 | Xerox Office Equipment & Supplies
When printing 2 sided sheets our machine puts dark gray streaks on the paper after printing more than 6 pages. The streaks continually get larger until they cover most of the page.
When you are printing 2 sided sheets the reason you are getting streaks, is your first sided not dry yet. I know it is a laser printer, even laser you have waite a bit.
Dec 03, 2009 | Xerox Phaser 7700 Laser Printer
Yellow streaks on phaser 7700 prints
You have a bad yellow developer housing and it will need to be replaced. The manual can be downloaded at: www.lpscomputer.com/ec/Phaser_7700_Service_Manual.pdf
The parts can be ordered here: http://www.lpscomputer.com/p-3063-1-116-1115-00-developer-housing.aspx
Jul 05, 2009 | Xerox Phaser 7300DT Laser Printer
Phaser 7700 steaks on Magenta, sometimes yellow.
Each color has its own laser. Use the cleaning wand in the front door to clean the lens covers for each color. You will need to remove the waste toner cartridge in front of the the slots to do this. If that does not cure the problem, you will need to replace the developer housings for the colors that are streaking. The manual can be downloaded at: www.lpscomputer.com/ec/Phaser_7700_Service_Manual.pdf
and parts purchased at: http://www.lpscomputer.com/p-3063-1-116-1115-00-developer-housing.aspx
Dec 12, 2008 | Xerox Phaser 7700 Laser Printer
Xerox Tektronix Phaser 7700 Laser - Wrinkling paper slightly.
Hy the problem is: You have to clean the 2nd BTR and the transfer belt cleaner. There is a large amount of used toner on those things.
Oct 30, 2008 | Xerox Phaser 7700 Laser Printer
Xerox phaser 7700 having problems printing transparencies and accumulator belt problems
Hi xander4265:
I
Streaks in direction of paper travel
There are dark lines running along
the page in the direction of paper
travel from the leading edge to the
trailing edge (B-size print shown).
The printer displays no error code.
Note A-size prints are processed
through the printer with the short
edge of the print parallel to the
direction of the paper path --
making horizontal print artifacts
parallel to the shot edge of the
print.
B-size prints are processed
through the printer with the long
paper path -- making horizontal
artifacts parallel to the long axis
of the print.
1. Check the end of life for each of
the consumables by printing the
supplies usage page. From the front panel’s Printable Pages Menu, select
Print Supplies Page.
2. Run the solid fill test pages; From the front panel’s Printable Pages Menu,
select Service Pages, then select Print Solid Fill Pages. If the missing bands
only occur in a single primary color, replace the print cartridge of the affected
color.
3. Swap print cartridges and run another test print.
Note Under some circumstances, streaking may occur in the margin of
SRA3-size paper. This is due to the edges of the paper extending
beyond the end of the imaging components. print-quality in the
margins of SRA3 paper is not guaranteed.
4. Inspect the Accumulator Belt cleaner; replace the cleaner, if necessary.
5. Run the Remove Print Smears routine. From the front panel’s Support Menu,
select Improve Print-Quality?, then select Remove Print Smears.
6. Replace the Developer Housing Assembly (RRP 27, on page 7-171).
7. Remove the print cartridge and (with a flashlight) check for debris along the
edge of the developer housing.
3041-42
Leading Edge
hope that this will help you.
Sep 18, 2008 | Xerox Phaser 7700 Laser Printer
Xerox 7700 intermittant banding on a diagonal black only
You most likely have a bad black developer housing.
You can try removing the waste bottle and using that bla\ck stick inside the cover to clean the laser ****.
But it sounds like the developer housing has failed.
Sep 07, 2008 | Xerox Phaser 7700 Laser Printer
Xerox Paser 7700 not printing seemingly large files from CDR13
Have you tried downloading a different driver?
Sounds like that may be the problem
Nov 01, 2007 | Xerox Phaser 7700 Laser Printer
Xerox Phaser 7700 Laser Printer Logo
223 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
