Question about Directed 434MHZ Remote Control
Harmon/Kardon AV520 universal remote code
Can't find code to work with new Dish VIP 612 DVR and Harmon/Kardon AV 520 Universal remote.
It worked with my VIP211 box.
Ant suggestions?
Dr. Gary Thomas Scott
  • greats Jan 17, 2009
    need control capacity for AV unit
  • 66 Answers
The Dish & Bell Satellite boxes are the same and can be changed to Remote Address 1 by doing the following. By default, the Harmony will send out the primary or 'Remote address 1' version of these codes. To change your device to use the primary remote address please perform the following; (note this is a general guide as screens and steps may not appear exactly as below)
1. With the original remote of the device go into the System and Settings screen.
2. Within the System and Settings menu go into Installation menu.
3. In the Installation menu go into System Info screen.
4. Once in the System Info screen find and note the remote address. Write this down.
5. With the original remote press and HOLD the 'Sat' button until the mode light blinks.
6. Press the '1' button, then press '#' button, and finally the 'Record' button on the original remote.
7. The remote address on the System Info screen should change from it's previous setting to 1.
8. Turn the device off and being using the Harmony. It will now work. Hope this helps.
Posted on Jan 17, 2009
    Sergeant:
  • 221 Answers
As it turns out, 0110 largely works. However, it does not turn OFF the unit. It does turn the unit on and control the channels/volume. It does not really enable channel control (regardless of cable/tv/aux mode) to always be handled by the cable box. It does not really enable volume control (regardless of mode) to be always handled by the HK unit. However, it did get it working to a point that it is quite usable - just have to press AUX or Cable at the appropriate time.
You can fix all of that.
To add Power Off to Shift-Power button (accessed by pressing and release SETUP and then pressing POWER)
1. Press and release AUX
2. Press and hold SETUP until the remote blinks twice
3. Type 994
4. Press and release SETUP
5. Type 00002
6. Press and release SETUP
7. Press and release POWER
The remote should blink twice to confirm
Now, POWER will turn on and pressing SETUP, releasing and then POWER will turn off the receiver. If you don't want to put the power off on shifted key, pick another key and leave out step 6 and press the key you want for step 7.
To use AUX for volume control in all modes
1. Press and hold SETUP until the remote blinks twice
2. Type 993
3. Press and release AUX
Now the receiver should control the volume in TV and CABLE mode.
To set the AUX channel to use CABLE channel keys, you can use the Keymove function to add functions from CABLE to AUX keys (this is not documented in the instruction for the remote).
2. Type 994
3. Press and release CABLE
4. Press and release CH+
5. Press and release AUX
6. Press and release CH+
Do the same for CH-. You may not want to do this, however. This will remove the Tuner+ and Tuner- function on your receiver, since you are overlaying the new function from the CABLE on to those keys. You will be in TV or CABLE mode when you are watching TV and it will still control the volume from the receiver (from the Volume Lock steps above), which is probably all you need from the receiver. If you don't do this procedure, you can still go to AUX mode to control the receiver and have the Tuner+ and Tuner- functions.
BTW, in case you haven't found it, the number keys in AUX mode will control the receivers input selections. There are a couple of other basic functions you can add to the AUX mode by using a similar procedure as adding the power off function if you are interested (I would need to give you the code to enter), but most other functions for the receiver can't be added to that remote without using slightly more complicated means (http://www.hifi-remote.com/forums/viewtopic.php?t=1009).
    Brigadier General:
  • 8,619 Answers
Hi!
The codes that are valid for dish dvr are---
DISH 588 589 590 613 628 647 648 654
    Sergeant:
  • 378 Answers
Tip
DISH Solo VIP612 DVR Quick Reference Download 2
Download DISH Solo VIP612 DVR Quick Reference Guide
Would you like to review the features of the DISH Solo DVR VIP612?
Have you lost your DISH Solo DVR VIP 612 Quick Reference Manual?
Would you like a digital, searchable, pdf version of the DISH Solo DVR VIP 612 Quick Reference Guide?
Follow this link (& click FREE) to download a pdf version of the DISH Solo DVR VIP 612 Quick Reference documentation.
I hope that helps.
________________________________________________________________
DISH Solo DVR VIP612 Manual Download
DISH Solo DVR VIP612 Quick Reference Download
DISH Solo DVR VIP612 Remote Code Scan
DISH Solo DVR VIP612 Program TV VCR Remote Codes
DISH Solo DVR VIP612 Program AUX (Stereo/Receiver) Remote Codes
DISH Solo DVR VIP612 Amplifier Control
DISH Solo DVR VIP612 What Is Limited Mode
DISH Solo DVR VIP612 Change Limited Mode
on Jul 05, 2010 | Televison & Video
Tip
DISH VIP612 Program AUX Remote Code 2
DISH Solo DVR VIP612 Program AUX Remote Code
Would you like to program the Universal Remote that came with your Dish Solo DVR VIP 612 to control your receiver, tuner, stereo, second TV or second VCR using your remote's AUX mode? (Instructions to setup a primary TV or a VCR are a little different, but can be found here.)
To setup your Dish Solo DVR VIP 612 Universal Remote, follow these steps to enter the remote control codes to control a device with the AUX mode:
  1. Turn the device you would like to control on.
  2. Find the brand name of the device you would like to control in the control code tables on page 112 of the Dish Solo DVR VIP 612 User Manual.
  3. Press and hold the AUX mode button until all the other buttons light up, and then let go. The AUX mode button will flash.
  4. Press 0 for a TV, 1 for a VCR, or 2 for a receiver, amplifier or tuner.
  5. Enter one of the three-digit codes from the tables in the manual.
  6. Press POUND (#). The mode button will flash three times.
  7. Press POWER to turn off the device. If the device does not turn off, skip to step 9.
  8. Turn the device back on and try some of the other buttons to make sure they work. If the code works, stop here.
  9. If the code didn't work, repeat steps 3 through 7 with the next device code from the tables in the manual.
Your device control codes for your amplifier or other AUX device are now programmed into your DISH Solo DVR ViP 612.
Now you probably want to set your Dish Solo DVR VIP 612 Universal Remote up so that it always controls the volume of your stereo, rather than of your TV, regardless of whether it is in SAT, TV, VCR or AUX mode. Help for this remote control programming can be found here.
(Help for programming a TV or VCR using the TV or VCR mode buttons can be found here.)
I hope that helps.
Tip
DISH VIP612 Remote Code Scan
Would you like to autoscan program the Universal Remote that came with your Dish Solo DVR VIP 612 to control your TV, VCR, receiver, or stereo?
To auto-program device codes into your Dish Solo DVR VIP 612 Universal Remote by searching for the code, follow these steps:
  2. Press and hold the mode (TV, VCR, or AUX) button until all the other buttons light up, and then let go. The mode button will flash.
  3. FOR AUX MODE ONLY - Press 0 for a 2nd TV, 1 for a 2nd VCR, or 2 for a receiver, amplifier or tuner. Then press the STAR (*) button.
  4. Press POWER to put your remote into scan mode.
  5. Press the UP or DOWN ARROW repeatedly until your device turns off. Each arrow press tries the next code your remote knows for your selected device type. When your device turns off, you have found a compatible code. When the remote runs out of codes to try, the device will flash rapidly eight times.
  6. Press POUND (#). The mode button will flash three times as it stores the found code.
  7. Turn the device back on and try some of the other buttons to make sure they work. If all functions work, your remote has been successfully programmed.
  8. If the code didn't work, repeat this scanning procedure to find a more compatible code. When your device turns off during your next scan, press the arrow key again until the device turns back on to signify you have found the next compatible code.
Your device's remote control codes for your TV, VCR, or receiver are now programmed into your DISH Solo DVR ViP 612 remote control.
(The other way to program your DISH Solo DVR ViP 612 remote control is to look at the tables in back of the user manual, and enter the code directly.)
I hope that helps.
Tip
DISH VIP612 Amplifier Control
DISH Solo DVR VIP612 Amplifier / Receiver Control
Would you like to program the Universal Remote that came with your Dish Solo DVR VIP 612 to control the volume of your receiver, tuner, or stereo instead of your TV's volume?
The first step in using the Universal Remote Control that came with your Dish Solo DVR VIP 612 to control the volume level of your receiver, tuner, or stereo is to program the remote to control your audio device using the AUX mode button.
Once your remote controls your audio device in AUX mode, you probably want to continue to control the volume of your stereo even if the remote is in SAT, TV or VCR mode.
To setup your Dish Solo DVR VIP 612 Universal Remote to control the volume of your stereo regardless of which mode it is in, follow these steps:
  1. Press and hold the AUX button until all the mode buttons are lit, and then let it go.
  2. Press the POUND (#) button.
  3. Press the PLUS side of the VOLUME button.
  4. Press 0.
  5. Press the POUND (#) button. The AUX button flashes three times to tell you the programming is complete.
  6. Confirm the VOLUME buttons are operating the tuner/amplifier's volume control by pressing SAT or TV, and then adjusting the volume. Your tuner/amplifier's volume should change rather than your TV's volume.
Your Dish Solo DVR VIP 612 Universal Remote is now setup to control the volume of your stereo regardless of which mode it is in
I hope that helps.
Tip
  4. Press 0.
I hope that helps.
on Jul 05, 2010 | DISH Network ViP 612
Tip
I hope that helps.
Tip
I hope that helps.
Tip
DISH Solo DVR VIP612 Program TV or VCR Remote Code
Would you like to program the Universal Remote that came with your Dish Solo DVR 612 to control your primary TV or a VCR? (Instructions to setup a receiver, tuner, stereo, second TV or second VCR are a little different, but can be found here.)
To setup your Dish Solo DVR VIP 612 Universal Remote, follow these steps to enter the remote control codes to control a primary TV or a VCR:
  2. Find the brand name of the device you would like to control in the control code tables on page 112 of the Dish Solo DVR 612 User Manual.
  3. Press and hold the mode button (TV or VCR) until all the other buttons light up, and then let go. The mode button will flash.
  4. Enter one of the three-digit codes from the tables in the manual.
  5. If you want to program Limited Mode, press 1. If not, skip to the next step. (You can add or remove Limited Mode later.)
  9. If the code didn't work, repeat steps 3 through 8 with the next device code from the tables in the manual.
Your device control codes for your TV or VCR are now programmed into your DISH Solo DVR VIP 612.
Help for programing a tuner, receiver, 2nd VCR, or 2nd TV using the AUX mode button can be found here.
I hope that helps.
Tip
I hope that helps.
on Jul 04, 2010 | DISH Network ViP 612
Tip
DISH Solo VIP612 DVR Manual Download
Download DISH Solo DVR VIP612 Manual
Would you like to review the features of the DISH Solo DVR VIP612 ?
Have you lost your DISH Solo DVR VIP 612 Owners Manual?
Would you like a digital, searchable, pdf version of the DISH Solo DVR VIP612 Users Guide?
Follow this link (& click FREE) to download a pdf version of the DISH Solo VIP DVR 612 documentation.
I hope that helps.
____________________________________________________________________
Televison & Video Logo
85 people viewed this question
Top Directed Televison & Video Experts
ted dux
Christopher Stearns
Are you a Directed Televison and Video Expert? Answer questions, earn points and help others
