Question about Filter Queen Majestic Canister Vacuum
Need a wiring diagram for a Filter Queen D31X
I am replacing a switch, and some wires came loose, and I need to find out how to re-wire this switch.
I need to make a filter
Posted on Feb 11, 2009
The white wire from the plug came loose where does it go? Need to see diagram for wire.
It is the ground wire. If it broke off from the plug, replace the whole plug. There should be a place to attach the white wire to the third round prong on the new plug
Jun 02, 2015 | Filter Queen Majestic Canister Vacuum
Actually ours is a Princess II made by Filter Queen, purchased in 1987. Wondering if motor going bad because when switch on sometimes it starts fine but other times you have to push the switch several...
It sounds like it's probably the switch. It could also be loose wiring connection to the switch, which can result in sparking. This presents a fire and/or shock hazard. Don't use it until you get it repaired. I do recommend having the vacuum checked out for a definite diagnosis. You're right about it possibly needing a new motor.
Mar 30, 2011 | Filter Queen Majestic Canister Vacuum
Fliter queen repair
I generally don't like answering questions like this cause it could lead to unwanted problems. But I will say that if the individual wires are color-coded (each wire is a different color and can easily be determined which go to which) and you are handy with some electrical tape and know about how to make wires connect, then you may be able to do this yourself.
If you are NOT able to determine which wires go to which wire, I definitely do NOT recommend you trying to this yourself.
If it is obvious to you which wires go to which, splice them to clean edges, connect metal to metal, wrap two connecting wires tightly with electrical tape, then once all wires are wrapped to one another, bunch all together and wrap all with electrical tape. That's it.
It's fairly simple, but again, YOU MUST, I STRESS MUST be able to distinguish which wires match which wires from the detached (thanks to dear sweet puppy) wires. :) Bad puppy!
Hope this helps at least some. A good repair person shouldn't charge that much to do it for you.
Best, Jenn
Jul 07, 2010 | Filter Queen Cheetah II Ash - MU305...
I just purchased a tune up kit for my filter queen, how do I replace the dome cap pad? I can see it but I dont know how to get to it.
I was trying to replace the silencer filter, we had to take the dome cap off and remove the screws by the sn plate then lift the top off. It looks like the motor has been replaced at some point (I purchased this one used) so the wires had wire nuts holding them together. We had to separate the wires for the light so we could remove the old filter and install the new one.
Feb 06, 2010 | Filter Queen Majestic Canister Vacuum
I need a wiring diagram & detailed specifications for my Filter Queen Majestic limited edition.
Open the vac by removing 3 screws below the handle area and the long screw at the bottom of the cone. If the motor has been removed, you will have 2 motor leads , 2 power head socket leads, and 2 switch leads as well as the cord. Do not twist your wires first when pairing, twist with the wire nut ony and tape afterword as there is metal nearby in the housing area
1 side of the cord goes to the switch only. The opposite side of the switch will go to 1 of each of the motor and Socket. The remaining motor and socket leads pair with the remaining cord lead.
While you are in there change the round filter dic covering the front of the motor and you could change the foam/ felt wrap around the inside of the housing.
There is a insulating disc at the top of the motor to prevent shock between motor and screen. Do not remove it.
Sep 07, 2009 | Filter Queen Majestic Canister Vacuum
Filter queen 95X (1991) Motor is noisy but still work fine. Can there be a loose screw inside ? Can I open the motor and look inside ?
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=766802
Generic problem for all Vacuums
Posted by alexun on Jul 10, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The sounds coming from the motor sounds like it is the 2 sheet metal fans that do loosen up and start to make noise; and if you are handy and can do service work yourself you can replace the fans, but make sure you mark the wires when you remove the wire and the motor. If you have questions feel free to contact your local vacuum cleaner dealer in your area or cal the Filter Queen cust serv line listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.filterqueen.com/
Customer Service 1-800-344-1840
custserv@filterqueen.com
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 10, 2008 | Vacuums
Motor
Filter ?Queen Majestic Canister Vacuum – Motor
Motor?
If your Filter Queen Motor is out or not working, the customer can replace the motor if they are mechanically minded and mark the wires as they remove the old motor with the new motor or you can have it serviced by your local vacuum dealer in your area, you can pickup the motor @ a local vacuum cleaner dealer in you area by checking the yellow pages or to contact the Filter Queen factory listed below. It requires a new motor and a new gasket; the biggest problem would be the wiring of the new motor. The factory information is listed below:
http://www.filterqueen.com Filter Queen Canisters Vacuums
Health-Mor World Headquarters
13325 Darice Parkway, Unit A
Strongsville, Ohio 44149
1-440-846-7800 or email @ custserv@filterqueen.com
Apr 18, 2008 | Filter Queen Majestic Canister Vacuum
Filter Queen Majestic Canister Vacuum Logo
656 people viewed this question
Top Filter Queen Vacuums Experts
Steve Sweetleaf
Steve Sweetleaf
Are you a Filter Queen Vacuum Expert? Answer questions, earn points and help others
