Question about Maytag PYE2300AY Electric Dryer
Where in Thermal fuse located maytag model #PYE2300AYW
Need to replace
  • 979 Answers
Take the top off the dryer and you should find it located at or near the drum.
Posted on Jan 17, 2009
3 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: Location of Thermal Fuse
The thermal fuse is located near the heating element. The part number for the replacement kit is LA-1053. You can view an illustrated parts break down of your dryer at searspartsdirect.com. Just type in your model number and locate item 5 under the "Heater" section. Pay close attention to the instructions in the thermal fuse replacment kit. One thermostat is for a GAS dryer, one is for an ELECTRIC dryer. Read the instructions and make sure you use the correct one. If you have any questions, please let me know. I hope this helps you.
Posted on Jan 06, 2010
Testimonial: "Excellent info. Thermal fuse was out of sight. Mention about LA-1053 helped. Honestly, I didn't know how thermal fuse looked like."
SOURCE: need to see a wiring diagram for Maytag PYE2300AYW
I replaced the Thermal fuse and now it get Too HOT
Posted on Dec 23, 2010
WHY MY MAYTAG DRYER PYE2300AYW WON'T START
Test the thermal fuse on the side of the heater housing. It should read closed for continuity. If open, you will need to replace the kit. Here is a link to the kit you need.
Oct 30, 2012 | Maytag Pye2300ayw Dryer Door Switch...
Maytag performa dryer model pye2300ayw, what should the ohms reading be on the thermal fuse?
doesn't matter,it's either good or bad,when you touch the meter to it if it reads 1 and doen't move it's bad if you get any reading it's good,if the dryer is loaded with lint in the duct that the lint filter slides into and the vent line is blocked it will keep popping on you, clean out the dryer,number one cause for popping the thermal fuse
Feb 22, 2010 | Maytag Dryers
Jan 06, 2010 | Maytag PYE2300AY Electric Dryer
Dryer won't run
thermal fused are one time fuses / maytag want's you to correct the problem that causes this . so dryer is safe. hi heat caused it to fail . so either the fan is not going or there is a restriction causing no air flow . try running the dryer off the vent if it works ok then clean the vent ,, hope this helped . pls leav feed back mm
Dec 14, 2009 | Maytag PYE2300AY Electric Dryer
Where would the fuss be located on a pye2300ayw model drye Would it be on the back or under the top
Hi, Yes the thermal fuse is located under the top and is fastened to the element housing on the right side. It has two white wires going to it. It comes in a kit with the safety theralstat. If you need any more assistance or need a place to order it, please let me know.
Thanks
Vic
May 17, 2009 | Maytag PYE4558A Electric Dryer
Maytag Dryer quit working mid cycle
sounds like the timer,the only thermal fuse i know of is to protect from overheating which cools and resets itself
May 10, 2009 | Maytag PYE2300AY Electric Dryer
Where is the thermal fuse located?
In the back of the dryer. Look for the coiled heaters and follow the lead wires back to the fuse.
Apr 30, 2009 | Maytag PYE2300AY Electric Dryer
Pye2300ayw Dryer will not start. I think it is a bad door switch. How can a confirm this?
Change your thermal fuse first. when thermal fuse goes bad either the whole dryer won't run or the heat element won't come on. Check out item # 3344 at www.repairclinic.com/Appliance-Parts?s=t-pye2300ayw-%3d%3d&z=100 If your thermal fuse is bad there will be no continuity through it.
Mar 01, 2009 | Maytag PYE2300AY Electric Dryer
WILL NOT START. LIGHT ON BUT WILL NOT START
Check the thermal fuse, located on the right side of the heater housing. If bad order LA1053 kit.
Fair warning it's a real patience tester to install correctly
Oct 16, 2008 | Maytag Dryers
Maytag PYE2300AY Electric Dryer Logo
1,073 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
