Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Ice maker does not work.
I emptied the container with the old ice and when I put it back nothing happed for 2 days. I check it often to see what's the problem and also washed and dried the container. The freezer is cold enough to freeze.
Thank you in advance for your help.
Ada Vazquez
  • 15 Answers
Make sure the wire lever is pushed down calling for ice.Otherwise the unit thinks its full.
Posted on Jan 17, 2009
My ice machine stopped working on my fridge it's only 1 and 4 months old.any suggestions
If a year old there is no warranty for the ice maker or the dual water control valve. Feel around the ice slots to see if there is still sitting there? What is the model number of your fridge? If the ice tray slots are empty fill with tap water until near full and if the water freezes and the ice maker drops the ice into the ice container the problem will link to a water control valve problem. If there is ice in the slots and ice maker is on and does nothing then the problem is the ice maker and it will need to be replaced.
Nov 23, 2015 | Refrigerators
Icemaker is making ice but will not dispense. continues to accumulate then over time ice in the bottom of the dispenser will freeze
I can think of two possible problems. The ice has frozen together and will not allow the ice screw to push the ice out the dispenser. Or the motor for the ice screw is broken.
1. Shut off icemaker with lever at icemaker
2. Remove ice container (either throw away ice or save in another container).
3. Put back empty ice container.
4. Leave ice maker off for about an hour.
5. After an hour , check if motor is working by trying to dispense ice. You should not expect any ice but you should hear the motor /auger moving.
A) If you do not hear any thing , you need to get your motor replaced.
B) If you hear the motor , mostlikely you had an ice dam which prevented the ice dispense from working..You can turn you icemaker on.
Oct 15, 2015 | Whirlpool Refrigerators
Ice maker stopped making ice
Pour about 1/2 cup of water into icemaker . If it dumps , replace the water valve . If doesn't dump , replace the icemaker . Also make sure the coils are clean of dust , lint , etc...
Aug 15, 2009 | Refrigerators
Ice maker not working
Usually when this happens the water line in the freezer is frozen. If this is the case, defrosting the freezer should free it up and all will work again.
Aug 02, 2009 | Refrigerators
Icemaker
Check to see if the little metal bar on top of the icemaker got flipped up or jammed when you put the ice container back in. This turns the ice machine off. This happed with my dad just the other day. I know it is simple, but he knew about this, and it still didn't dawn on him to check it. Just a thought!
May 30, 2009 | Whirlpool GD5SHAX Side by Side...
10 yr old Frigidaire ice maker stopped making ice
try forcing the cycle by manually triggering the cycle a few times. Sometimes you can detach the trip arm or turn the tray by hand by disconnecting it from the gear. There may have been a switch bumped to turn it off or the switch somehow jammed. Maybe check for freeze-up. If there is water in it, it's going somewhere.
Sep 27, 2008 | Frigidaire FRS26R4A Side by Side...
Kitchen Aid Ice maker Stopped working
The ice maker has stopped working. The red led light blinks when the freezer door is opened. Any thoughts?
Nov 22, 2007 | KitchenAid Superba Architect KSCS25INSS...
check to make sure the fill tube is not plugged with ice if it is not then i would guess the valve is shot
Oct 30, 2007 | Frigidaire FRS3R5EMB Side by Side...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
152 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
