Question about Reiker RRC120001 Ceiling Fan
I have a reiker heat and cooling fan but it doesnt work
The fan and heat uint is remote based and cannot be controlled otherwise. The switch on the wall when turned in the on position just makes the fan click as if it is trying to turn on. The remote batteries are new and the fan worked fine recently with no problems. It is as if the reciever to the remote is trying to connect with no success. what can I do? can the receiver be replaced or what? any suggestions would be appreciated.
  • 25 Answers
Replace reciever with a new ones.
Posted on Apr 16, 2009
Heating element for reiker room conditioner chalet ancient bronze model
I would look for a bad thermostat on or near the heating element. If your not sure with electrical work, it might be best to replace the whole thing. Most cieling fans cost less to replace than repair.
Dec 13, 2013 | Reiker Room Conditioner Chalet Ancient...
When i turn on the power switch fans on high and the light is on the remote does nothing heater on it stopped working a yr ago
Call the company, then buy another fan without remote control or heater
1-800-283-7031
Reiker ceiling fan warranty is 1 year limited:
http://www.buyreiker.com/default.aspx?page=10
Reiker troubleshoot is zero help:
http://www.buyreiker.com/default.aspx?page=51
Troubleshoot section page 15 of manual is zero help.
http://www.buyreiker.com/manuals/ownermanual-e.pdf
Oct 23, 2012 | Reiker Dryers
Reiker ceiling fan - does not turn on - theres is power to unit - maybe remmote is bad? how do i change code
Before trying to change the code, have you tried changing the batteries? Both in the hand held remote and the one in fan housing? If so, and that didn't help, make sure the batteries are turned in the right direction and fitting tightly.
Will the fan operate without using the remote control?
Feb 19, 2011 | Reiker Room Conditioner Heater
I have had a Reiker Heat/ cool fan for 3 years and have had no problems, till now. All parts are working ,lights , fan, remote, but I have no heat. How do I fix this. K.
I had the same problem and fixed it with a reset. The reset button is on the back of the remote next to the dip switches. You have to take the battery cover off to see it.
Turn on the fan with heat using the remote. Then, leaving the remote turned on, turn off the fan at the wall switch or circuit breaker. Wait a few minutes and turn the electricity back on. Then, within 30 seconds, and within range of the fan, press the reset button. You should be able to see a countdown from 5 to 0 on the remote screen.
Once I did this the heat began working again.
Jan 07, 2011 | Reiker RRC1200001 Heater
My new rieker fan stopped blowing heat- the fan works --not the heater
I had the same problem with my fan and solved it with a reset. The reset button is on the back of the remote next to the dip switches. You have to take the battery cover off to see it.
Turn on the fan with heat, even though the heat doesn't work. Then, leaving the remote on, turn off the fan at the wall switch (or circuit breaker box). Wait a few minutes. Then turn on the power and within 30 seconds, press the reset button. You should be able to see a countdown from 5 to 0 on the remote screen.
Once I did this the heat started working again.
Jan 05, 2011 | Reiker Ceiling Fan/Heater Combo Utility
Instruction manuel for Reiker fan model fan-15T.
Hello-my remote control stopped working. I can't turn the lights or control the fan! Please help!
Sep 26, 2010 | Heating & Cooling
Reiker room conditioner
called reiker, and they sent me a new thermostat for the fan. installed it and problem solved
Jan 27, 2009 | Reiker Room Conditioner Ceiling Fan with...
Reiker Corporation distribution fan motor is the largest and best available in the ceiling fan industry and carries a lifetime warranty.
Dec 14, 2008 | Reiker Room Conditioner Ceiling Fan with...
Reiker ''room conditioner'' heater stopped working
i have of course the same problem......5 times now in 3 years.
i have discovered that for some reason if i disconnect the fan and put it back up it works again for another 8 months or so.
Nov 16, 2008 | Reiker Room Conditioner Ceiling Fan with...
Fan and light no longer turn on
possibly the thermal overload sensor failed internally? as indicated in the instructions there is a overload sensor and thay will typically fail in others appliances.
Oct 30, 2008 | Reiker RRC120004 Brushed Steel Ceiling Fan
Reiker RRC120001 Ceiling Fan Logo
478 people viewed this question
Top Reiker Dryers Experts
Dan Webster
Dan Webster
Are you a Reiker Dryer Expert? Answer questions, earn points and help others
