Question about Kenmore 64802 Top Freezer Refrigerator
A leak from the fridge
For the past couple days, I have had what looks like oil leaking from my fridge. Its black but don't really smell like oil. It is coming from the left front of the fridge. Like right at the leg. As far as I know there is no kind of motor there. It was suggested that the water pan be full and it could be black water. But there is no way to empty the pan. Plus that pan is above the compressor in the back. Has anyone had this problem or have any suggestions? Thanks,
  • 1 more comment
  • Lisa Tyndall Jun 22, 2007
    Here is a picture of what is leaking. Like I said its black like oil but not as thick. But like you said there are different kinds of oil. I will check the water pan first. Even though I don't understand how could leak from up front. But there is no telling.
    I will let you know what I find.
    THanks for your help
  • JuiceW1 Dec 07, 2009
    I don't have a solution but I have the same problem. First it was with the fridge at our home, looked exactly like the photo only more liquid. Almost looks like soy sauce, but doesn't smell like anything. It dissolves easily with water clean up. We couldn't figure it out, so we cleaned it up and forgot about it. THEN we are moving to a different house. I clean the fridge at that house, next day same black puddle on the front corners of the fridge at new place. Nothing in the fridge to spill. '~' The only common denominator is that I had recently cleaned both fridges when I found the black puddle. I'm still confused......
  • Adam Jacobs Jun 09, 2012
    I have the same phenomenon. Smells very similar to soy sauce. Some kind of fermentation going on in there or something. Maybe I should try it on some rice, one might be able to achieve an enlightened state of mind from consuming this substance. I love you rare and mysterious black fridge sauce.
  • 944 Answers
Without knowing a bit more about the black fluid it is hard to guess where it could come from - in a fridge there should be no black fluid and the only oils are mixed in with the refrigerant so the fridge will not be working if any noticeable amount is leaking out, as the gas will leak out as well. As you mentioned, the most likely liquid is water from inside the fridge or condensation from inside or outside that has bacteria growing causing the blackness. this sort of water may usually only be in the water tray at the back but there are many possibilities of it leaking out somewhere else - only way to check is to get the fridge running, up on four chairs or a VERY strong glass table so you can see where it is comning from. Another possibility is that there is some insect, plant or rodent factor - the moist warm space under a fridge is quite popular and they can produce their own liquids and also especially rodents cause unpredictable holes and damage all over the place. also can only be checked by looking very closely at the source of the liquid. The last possible cause i can think of is some sort of corrosion - i have not heard of this type of corrosion with a fridge, but it is quite common on steel ships - salty humidity and chemicals (cleaners/cargo etc) reacting strangely with the paint or steel are normally blamed - just think if you get too many strong cleaning products near the bottom of the fridge and look for general condition of the paint/metal underneath you should be able to see it easily if the black fluid was in any significant quantity - there would usually be a sort of rusty look to the fluid, but not always depending on the combination of chemicals present. Where you describe the fluid coming from, sounds like it could be from the door insulation - maybe leaking through the bottom hinge holes - check that nothing is leaking into the door from inside, although condensation can easily happen in the door body itself if the insulation has separated slightly from the "skin" of the door inside. Last thing to try is to investigate the fluid itself a bit more closely - get some on a piece of kitchen paper towel or a coffee filter and then wet the paper with water also just next to the fluid- the parts of the liquid should separate out a little as the water soaks through the paper and you may just see something that looks familiar. If you get no luck post back and try to describe exactly what the fluid does smell like, without trying to imagine smells like "oil" which means nothing as they are all different and in particular fridge lubricants are relatively odourless. think of things you actually know the smell of and try and describe it in those terms - if you feel brave then it may be worth tasting the liquid - just taste a tiny tiny bit on a cotton bud/Q-tip dabbed on a few different areas of your tongue and then wash your mouth out with mouthwash straight after instead of spitting or swallowing - I know it sounds dangerous and disgusting but it is the way that many professionals identify unknown substances as taste has a much more specific "database" in the brain than smell has. just be sensible. Hope this helps - post back if not - photographs may help if you have a digital camera, especially of the coffee filter test if you get round to it :) Good luck
Posted on Jun 22, 2007
  • Nigel Ridehalgh
    Nigel Ridehalgh Jun 22, 2007
    ps - the comment about condensation in the door also can apply to the side walls of the fridge in the same way :)
  • Nigel Ridehalgh
    Sorry the photo only deepens the mystery - nothing i think i have seen before but let me know when you figure where it comes from.
    Another idea a friend suggested is that some sort of degradation of rubber/plastic feet or similar (sometimes happens if in contact with certain chemicals) could be the source of the blackness - if the fridge has such feet then just rubbing them will soon tell you if this is an issue.
    Good luck :)
I know this is old, but my refridgerator started doing just this same thing. Its been awfully humid lately, so its possible that it may be condensation of some sort, but I had a large puddle leak out almost all at once (very similar to the picture) and it smelled very metallic, like rust almost. I also noticed the leak was focused around the front feet, on both sides.
Posted on Aug 11, 2009
SOURCE:
Freon leak in refrigerator?
no refrigerant leaks have little to no odor and if it was leaking bad enough to smell it the unit would be out of refrigerant and not cooling...the problem sounds like gases coming off of a veggie of something un-covered inside the fridge--have you put any veggies in the fridge or freezer un-covered check real good if one or a piece of something has fallen behind something else where you cannot see...all else fails remove all your products from the unit and clean and get a box of odor control arm&hammer to rid the smell..as for a leak in the sealed system i think your just fine.
Mar 27, 2012 | Samsung RF265AA Bottom Freezer French Door...
HAD THE OIL CHANGED IN 2006 RENO OIL IS LEAKING ON PAVEMENT.TOOK IT BACK AND THEY SAID TIGHTENED ALL THAT THEY COULD IS STILL DOING IT
The leak is probably unrelated to the oil change, at least in a bad way. Many vehicles are poorly designed for oil changes. Oil gets on several components under the engine and could leak for a couple of days. You'll have to find the leak yourself if they are unwilling or unable to do it and you don't want another shop to look at it just yet.
Keep in mind that the older a vehicle gets, the more leaks it has. Place a piece of clean cardboard under the vehicle when you park it. Check above where you see the spot on the cardboard if it still leaks. Since the oil is traveling down, keep tracing upwards until you don't see oil leaking or seeping and you have found the location of the leak. Keep in mind as well that oil can be slung by the engine belts if you have any seals on the front of the engine leaking.
Jun 30, 2011 | 2007 Suzuki Reno Hatchback
SMELLED OIL IN CAR VENTS. LOOKED AT COOLANT RESEVOIR AND IT HAD OIL IN IT. OIL DIPSTICK AND OIL CAP LOOKED CLEAN, SO I SUSPECTED UPPER INTAKE MANIFOLD LEAK. WHEN MECHANIC CHANGED MY VALVE COVER GASKETS...
If the leaking gasket was a long term problem, the bearings may have been ready to fail. A standard procedure when replacing any gasket that has possibly been leaking anything into the engine is to do an oil change. If I read your question right, sounds like this wasn't done, if it was, then it would be hard to fault the shop. Any coolant or fuel that leaks into the oil will degrade the lubrication properties of the oil possibly to the point of metal to metal contact causing the bearings to fail.
Mar 25, 2011 | Pontiac Bonneville Cars & Trucks
I have a mini fridge and it was leaking this bright green substance after I unplugged it for about 3 days, and then when I pluggedit back in, it started smelling really bad. I have know idea what's going...
the bright green substance will have turned black fairly quickly as it is mould from the vent pipe,clean out with clorine bleach and dry before use to clear mould/smell.
Apr 28, 2010 | Refrigerators
Red /yellow cloured oil leak around behind front wheel line
if it is yellow it could be the aircon compressor, if it is really red to pink, power steering or automatic transmission leak
Jan 08, 2010 | 1997 Mercedes-Benz E-Class
Gas smell in the oil.....have to put coolant in often
It sounds as if you have an intake gasket leaking. This will cause both problems. The coolant is probably going out the exhaust. The fuel is probably loading up in the cylinder and leaking past the rings or valve seals.
Sep 14, 2009 | 1996 Chevrolet Tahoe
Engine smells like rubber burning and temperature gauge at normal temperature. Water/coolant leaking out of reservoir and needs to be filled ever 2 days. Oil level is normal, but when it's hot outside the...
Generally that smell is caused by an oil leak that is getting on either the exhaust pipe or manifold (doesn't take much to smell). As far as bottle getting low, I've got a 93 that never stays full but only needs coolant in the radiator about once every two months. Been like that for two or three years and has never overheated. I'm sure there is a small leak somewhere, but I'm not driving myself crazy looking for it. Check all hose connections, and look on the ground after being parked overnight...If it's leaking, something will show up. But if the radiator is staying full, just check it when checking oil level.
Jul 13, 2009 | 1995 Jeep Grand Cherokee
Bottom of my fridge is leaking and has a funny smell, all fans are running but fridge is not getting cold enough even the freezer, around the freezer feel really warm?
Does it smell like ammonia. Turn the unit off if it does. Look for yellow powder on the back this would be another sign the cooling unit has leaked. The only solution is to replace the cooling coil.
Sep 06, 2008 | Refrigerators
Fridge leaking oil on the bottom right side
OK, usually if you see an oily substance that you are sure is not from the fridge contents it's oil from the sealed system. When a leak in the sealed system happens the refrigerant gas leaks out and the lubricating oil also leaks out. I'm afraid you may be in this situation. As the refrigerant leaks out the cooling efficientcy drops off quickly and eventually there is no cooling at all. You would have to use a refrigerant leak detector "sniffer" to locate the leak and then have a certified company repair the unit. Sadly, the cost to do a compressor replacement and leak repair is 2/3's or more the cost of a new fridge...
Jan 15, 2007 | Frigidaire GLRS237ZA Side by Side...
Kenmore 64802 Top Freezer Refrigerator Logo
3,541 people viewed this question
Top Kenmore Refrigerators Experts
Fred Sops
Audrey Messer
Audrey Messer
Jimmy
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
