Question about Canon PowerShot A70 Digital Camera
Problem removing camera housing
I am following the instructions to strip down my Canon Powershot A70 found here: http://menthol.hit.bg/E18.html I'm having problems removing the camera housing. I can prise open the bottom of the housing, but the top bit, alongside the shutter, where the auto/video rotary dial is, just won't budge. The pictures show removing the shutter casing. Done that. Next they show removing a small green plastic square/cube. I can't see how to do this. It appears to be soldered onto a thin metal ribbon. Some other instructions don't mention this step at all. As an aside, the problem I am trying to fix is bent pins in the camera where the memory card attaches. If I can get in to the camera, I can try and fix or replace the part. Canon want £100+ to repair. No way! Any help gratefully received. Thank you, in anticipation! CD
    Problem Solver:
  • 4 Answers
The top is held in by two plastic snaps, one by the on/off button and the other beside the Canon lettering. The trick is to press down on the front half of the casing with your left thumb (on Canon logo) and use your right hand to gently twist the back half back and forth while pushing out the bottom until the snaps release. Be patient and it will eventually come apart.
Posted on Aug 18, 2007
SOURCE:
E18
Lens Drum gear broken so that it flash E:18,it need to replace
Mar 18, 2010 | Canon PowerShot A400 Digital Camera
Remove battery door of Canon A630
This is an old A70, but the way it's done is very similar as I don't think this has changed much over the years. It's a pin design that you have to push out with a stiff unbent paperclip. You push in on the side with the smaller hole. To access the pin you'll need to remove the front and back case covers. See the following:
http://blog.thustra.com/2007/03/canon-a70-ir-modification.html
Jun 19, 2009 | Canon PowerShot A540 Digital Camera
When I turn on my PowerShot A70, it comes on and immediately shuts itself off and the Error E18 appears on the screen.
Canon Powershot's error E18 has to do with the lens:
If it appears on a black LCD with E18 written on the corner, it is mostly due to the lens getting stuck while trying to extend. The camera will beep a few times and the LCD will display a little E18 in the lower-left corner. The lens gets stuck in the extended position, and refuses to move either to focus the lens or to retract when powered off.
I am giving below a link which will help you with E18 problem.
http://www.e18error.com/repair.html
Hope this helps, let me know if you have a proble.
Please do rate and thanks for using FixYa and Best fo luck to get you camera out of E18!
Mar 04, 2009 | Canon PowerShot A70 Digital Camera
E18
The following blog outlines some repair options for an E18 lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
It's important that you fix the E18 error first, as the blur of colors may be symproms of a failing CCD. If so, Canon would fix this for you for free IF the camera has no other problems (ie no E18 lens error). Please see the following info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
May 27, 2008 | Canon PowerShot A70 Digital Camera
Snap picture button jammed
If you have some jewelers phillips screwdrivers (very small tips) you can take off some screws and maybe pop a cover back in place. The zoom lever has 3 screws holding it in....2 at the bottom of the battery compartment and one in the compact flash card area. Go here for pictures....
May 25, 2008 | Canon PowerShot A75 Digital Camera
Cannon power shot a70
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. Have already fixed several cameras with this problem by using these methods:
Nov 24, 2007 | Canon PowerShot A70 Digital Camera
Removing casing
i know its not english, but follow the pics...the hard part is popping off the front face plate that is stuck on there with tape
Nov 17, 2007 | Canon PowerShot A70 Digital Camera
Can't take a picture or even see an image in picture mode. I get an error message E18? I am able to look at photos taken in the past.
SkiPowder, the E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Guest has a different problem. Guest's problem sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your cameras warranty status. Please check the following two links for more info:
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110
Oct 31, 2007 | Canon PowerShot A70 Digital Camera
I really don't know....E18
Check Canon customer support. If you have the CD, there is a comprehensive manual in PDF format on there.
Aug 06, 2007 | Canon PowerShot A70 Digital Camera
Cnaon power shot A70
Check out these links: http://blogs.yucs.org/~dwallach/2004/08/canon_e18_error_repair_instruc.html http://www.e18error.com/repair.html Good luck. If you resolve my problem on how to get the housing removed, please post me the solution! CD
Apr 16, 2007 | Canon PowerShot A70 Digital Camera
Canon PowerShot A70 Digital Camera Logo
41 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
