Question about Goodman GMS90703BXA Heater
The furnace will light but will not continue.
  • cycles Jan 18, 2009
    LED glows steady red. igniter glows, gas lights but goes out after about 5 seconds
  • Goodman Master
  • 3,238 Answers
Try cleaning the flame sersor or try jumping out the pressure switch , if that works change pressure switch check the air filters ?
Posted on Jan 17, 2009
What do I do if red LED light stays on and my furnace (Carrier WeatherMaker 9200), does not start.
turn power off for 5 min to reset and check thermostat wiring the red wire should be connecting to the white try a jumper at the furnace
Sep 12, 2014 | Heating & Cooling
2cxcb031ac3cuaa
This model number is for 2.5 ton evaporator which should not have any blinking lights. If it is also hooked up to an American Standard or Trane furnace the continually blinking light means normal operation.
May 14, 2014 | Heating & Cooling
York Diamond 90 furnace blows cold air
There maybe a few issues. They have multiple safeties on furnaces. With this in mind this process to find the problem would take a Technician to check these safeties. It could be a flame sensor or thermocoupler each senses a flame or heat to keep the gas going. Also the damper for the flue must open for the gas to stay on. There may be more safeties on this and each safety sends a 24 volt current back to control module in order for the gas valve to stay open. If these aren't being met it will try around three times and go into a lock out mode which will keep gas shut off entirely.
Feb 21, 2012 | Heating & Cooling
Furnace fires but cuts out after 10 seconds. Yellow lite flashing 2 times continuous. Green light flickers and sfter furnace cuts out gos bright green for 2 seconds and then goes back to flickering.
Since you didnt include Brand and Model number, you could check on the inside of'
the front panel you take off to access the furnace. Most have a diagram of the wiring
and will have an Problem Code list that tells you what those flashing lights indicate.
Good luck and feel free to reply with Brand and Model #
Mar 31, 2011 | Heating & Cooling
Bryant furnace plus 90 led code is blinking once then 3 times fast. What does it mean?
these codes are on the inside panel of the front cover of the furnace. lift off and look inside.there should be a code explain chart on the panel by the light. this panel will need to be replace correctly for the furnace to work as there is a door switch.
Jan 31, 2011 | Heating & Cooling
I have a EVCON furnace DGAT070BDC. I replace the igniter control, the gas valve and the thermostat. Same problem continues: glow stick works, then the pilot lights works.The igniter control clicks...
You may have a dirty/rusty burner that is clogged or your gas valve
manifold pressure setting may be too low. Normal manifold pressure
is 3.5 inches water column on natural gas furnaces. ( 1 psig is equivalent to 28 inches water column). Pull and clean burner. Also
check and clean pilot assy. including flame sensor (if present).
Please let me know.
Oct 24, 2009 | Coleman Heating & Cooling
Newly installed furnace led light flashes continuously
on some new furnaces that is the "heart beat" and means everything is ok. There should be a key on the control or on one of the doors somewhere
Oct 08, 2009 | Heating & Cooling
Furnace integrated control module
The light is supposed to be on, if there is a fault in the furnace the light will begin to give u a flash pattern... ie; three flashes...or two flashes.. on the furnace exterior or on one of the doors there should be a fault code chart.... read the chart on the unit it will tell you what light is on and when..
Jan 14, 2009 | Goodman GMS90703BXA Heater
Goodman GMS90703BXA Heater Logo
29 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
