Question about Jenn-Air JDS9865BDP Stainless Steel Dual Fuel (Electric and Gas) Kitchen Range
I am replacing the igniters for a Jenn Air range model SVD8310S. I would like to know the best way to do this.
Noggin
  • 944 Answers
SOURCE: I just got this Jenn Air...bought it 2nd hand in a store..how old is it?
Have a look through this lot, there are a few problems for your model discussed, but nothing that sounds like a known problem for the model; http://www.applianceblog.com/mainforums/archive/index.php/f-64.html This link has a good description of a common problem with the model (temperature too low compared to the digital readout) and it's solution; http://applianceguru.com/forum1/955.html this link has a good collection of reviews on the stove - people were still buying them new in '98, couldn't find exactly when they started selling them; http://www.epinions.com/hmgd-Ranges-Jenn-Electric-Jenn-Air_Slide-In_30-Inch_Electric_Range_SVE47100/display_~reviews If you have any problems and need parts, there are still many companies offering them online for this model - just type "jenn air SVE47100 parts" into google and you will get a good selection. Sorry I had no luck finding a user manual online, free or otherwise, you could try contacting jenn air direct to see if they could send you one; http://www.jennair.com/content.jsp?name=contact_us Hope this helps :)
Posted on Jul 07, 2007
  • 58 Answers
SOURCE: gas range igniters won't shut off
The problem that you're describing is commonly associated with the spark modulator. It usually occurs after a spill or when the ignitor electrodes have remained wet after a cleaning. If after a day or two it continues to spark intermittently on its own, then the only recourse would be to replace the module. Hope this helps,,,, Bill
Posted on May 28, 2009
erpaalai
  • 999 Answers
SOURCE: jenn-air electric range model JES9800AAB some kypad # not working
Unless they start working again after it has a chance to dry out the touch panel will have to be replaced. This happens when excess moisture gets between the very thin layers of the membrane.
eric
Posted on Jul 03, 2009
SOURCE: How to replace spark igniter - Jenn-Air SEG196 gas-electric range
took off the knob to the ignition system to clean and spray got onto the ignition under the dial and now the two front burners won't ignite unless I turn on one of the functional back burners then turn on the front burner. How do I repair this?
Posted on Oct 11, 2009
  • 35 Answers
SOURCE: we just spilled some water over the switches that
change oven igniter switch
Posted on Jan 02, 2010
I need to replace the igniter unit 2 gas burners on a Jenn air model svd48600
go please to www.repairclinic.com and buy it. give the model, serialnumber+marks.
God bless you
Jul 26, 2012 | Jenn-Air Kitchen Ranges
JennAir Gas Range Elect touch 800, model JGR8775QDS oven won't heat or ignite....
this is normally due to a failed oven igniter check the igniter if glowing read but no gas replace it to fix the issue, let me know,
http://www.appliancerepairlesson.com/
Mar 07, 2011 | Jenn-Air JGR8775QDS Gas Kitchen Range
Jenn Air JGR8750 - Oven heats _very_ slowly; take 45 to 60 minutes to heat to 450ºF. I can hear faint ''whump whump whump'' from the oven as it heats. Purchased in 1998.
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. This video will walk you thru the correct procedure for testing an oven igniter. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Sep 28, 2010 | Jenn-Air JGR8750 Gas Kitchen Range
My gas bake burner won't ignite.The igniter is on.Gas Range Jenn-Air model#JGS885OADW
If the bake ignitor comes on - check the amperage on the bake ignitor wires when it's on. Amperage should be 3 - 3.6A. If less than 3A - replace ignitor.
Ignitor part numbers (any will do, but the first one is a direct replacement): 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
All those are interchangeable, if you can splice the wires.
Apr 03, 2010 | Jenn-Air JGR8850 Gas Kitchen Range
F2 signal on Jenn-Air model su146 range
Hi there
i have found the code for and hope this helps you.let me know how it goes.
F2 Oven too hot Replace relay board (if present) or oven temperature sensorThank you for writing to fix ya.
Best Regards Richard
Mar 20, 2010 | Kitchen Ranges
Jan 22, 2009 | Jenn-Air JGR8850 Gas Kitchen Range
Self clean oven doesn't work
hi there,
does the keypad beep when you push the keys? if yes, the keypad is fine.
make sure that the keypad is plugged into the control board correct it. the control board is located behind the keypad
do you get any error messages? if yes, please tell me the #.
Nov 17, 2008 | Ovens
Jenn Air JES 9800
pop me an e mail with your complete model number and ill help b4829@yahoo.com
Apr 07, 2008 | Jenn-Air JES9800A Electric Kitchen Range
Jenn-Air JDS9865BDP Stainless Steel Dual Fuel (Electric and Gas) Kitchen Range Logo
76 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal De GO PATS
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
