Question about Integra DTR-9.1 7.1 Channels Receiver
No sound from speakers from components with Integra 6.9 receiver
Just bought an Integra 6.9 receiver and cannot get sound when playing CD or Dvd. Have great sound from the receiver though. Did the Audessy set-up already and that didn't fix the problem.
Turns out it had to do with one of the settings for the new Blu-Ray player.
Thanks anyway.
Posted on Jan 18, 2009
How do you make the 6.1 channel work? Right now it just says digital. Does 6. 1 channel sound better?
6.1 stands for six speakers and one sub-woofer - a total of seven actual speakers giving you the surround sound effect. Before it can play a surround sound environment, the media - a CD or DVD must have it encoded on the disc, like a movie that has 6.1 surround sound recorded on it or a music CD with recorded surround sound. Otherwise, it will just play stereo audio - two speakers and the others are redundant. And yes, it does sound better as if you are in the actual area it was produced - like if you were there.
Feb 23, 2011 | Yamaha RX-V459 Receiver
I have sound when I play the dvd or the cd player
Sounds like the setup info got scrambled in the receiver. Re-program the TV input...from optical or coax or whatever way it is going into the receiver.
Apr 06, 2010 | Harman Kardon AVR 230 6.1 Channels...
Low to no volume output from Integra DTR-5.2 receiver
most higher end integra's have a input level adjusment or input selection for each and every input. Perhaps you are not on the correct input, go to onscreen programming and check out the input level and input select - also try the tape in another input like tape 2 or cd. It will not hurt the receiver for a test. Also, if you are using the cheap cables from the manufacturer - try a pair of cables that you know work or go by some. BTW, you don't need to spend $40 for cables order them online through amazon or other store. Gold / sliver plated oxygen free are best.
Jun 30, 2009 | Integra DTR-5.2 Receiver
Won't Show DVD Picture or Hear From Surround Sound Speakers
The lack of video in the DVD can be isolated to the DVD players output mode, if you are using the component video out on the dvd player then be sure to follow the componet out of Receiver to the tv component inputs, if you are using the HDMI from a DVD HDMI into RECEIVER HDMI then go to TV HDMI, you cannot mix component and HDMI on this model of AVR receiver and acheive results, in other words keep the COMPONENT to Component and HDMI to HDMI signal path, the results will be similiar quality audio and video UNLESS you are doing a blu-ray source which will result 1080P quality, all other video, HD results to 1080i, about the audio, if all 5.1 test tones are satifactory to speakers but on playback modes for DVD or HD tv signals all you are receiving is LR which is basically 2 channel (stereo) you need to enable a MULTI-CHANNEL capability input, this must be a option on the DVD Player Audio MENU output, be sure it is set for DOLBY DIGITAl 5.1 or DTS outputs, be sure to have the receivers digital input enabled if you are running optical cable or coaxial digital for the audio, you will be sending a multi-channel input to the receiver when the Receivers Faceplace LCD displays 5-6 speakers. If it shows only LR or two speakers it is not locking into a 5.1 audio input.
Feb 21, 2009 | Yamaha HTR-6130 Receiver
Only plays one track from from DVD sound
Plug in center speaker -- seems right and left speakers are secondary carrying only the background / sound affects.
Jan 10, 2009 | Televison & Video
Audio won't play on DVD - but it will play for CDs
Hello, you can verify that your receiver is working or not. When you are playing a dvd unplug the audio RCA plugs (red and white) from the back of the Sony dvd player. Touch the tips of each of the RCA plugs with your fingertip. You will hear a buzz sound coming from the speaker associated with the plug if the receiver is working\ i.e. touch the red RCA plug tip and the right speaker will hum...touch the white tip and the left speaker will hum or buzz. This will not hurt your system or speaker. If you do not hear the hum turn the volume to 3 or so and wet your fingertip and tap the tip of the RCA connectors. You will hear "pops" coming from the respected channel. I believe your cd\dvd is at fault. Good Luck!
barneyluc
Oct 02, 2008 | Yamaha HTR-5440 Receiver
Zone 2 speakers will play from tuner but not from cd player
I have the denon as well two zones. 5 speakers inside and 2 speakers outside- can you play both zones at once? meaning can i watch tv in the 5 zone area inside. And play my IPOD in the outside speakers at the same time? PLEASE HELP! thx
May 24, 2008 | Denon AVR-1803 Receiver
Sound problem on new Aspire
In advanced sound settings you will find the the speakers are muted..go to control panel,sounds and audio and choose speakers then click advanced or properties..hope this helps
Jan 01, 2008 | Acer Aspire 3680 Laptop
Distortion
YOU SHOULD NOT PLAY CD,S IN SURROUND SOUND,SWITCH TO STEREO ONLY FOR CD,S AND OTHER MUSIC SOURCES.
HOPE THIS HELPS.
Dec 17, 2007 | Onkyo TX-SR500 Receiver
Integra DTR-9.1 7.1 Channels Receiver Logo
590 people viewed this question
Top Integra Audio Players & Recorders Experts
Electro Med Services...
Are you an Integra Audio Player and Recorder Expert? Answer questions, earn points and help others
