Question about HP Pavilion dv1000 Notebook
Hp DV1000 backlight flickers on then off on button press
Hi guys, I've got an HP DV1000, worked perfectly for years and then out of the blue the back light does not work. When I press the lid button the light flickers on from the right of the screen for a fraction of a second and then off again. I don't know if it's the inverter, just the switch or something i've missed. Linux (ubuntu) isn't detecting the button being pressed at all.
Any help would be great. cheers
  • 4 more comments
  • trafficcone Jan 17, 2009
    thanks Bill, that's pretty much what i thought. I'll give them a go. any idea which you think would be the most likely, or at least which I should try first? cheers :)
  • trafficcone Jan 18, 2009
    no worries. I've found an inverter for £7.60 on ebay so fingers crossed :) just have to wait for it to arrive from hongkong, the joys. thanks for the help. i'll post how it goes.
  • trafficcone Feb 09, 2009
    well a few weeks on and i've tried replacing the inverter and backlight and neither worked.does anyone have any other solutions? the backlight just flickers on across about half the screen then off again. cheers :)
  • jorgeasl Feb 17, 2009
    Same problem here, i replaced inverter AND screen AND cables, and still the same....
    P O S Laptop
  • Anonymous Apr 17, 2009
    Same....stays on for 1 second then shuts off. Occasionally will stay on while the bottom corner gets hot and buzzes...eventually turning black.
  • JulieSE Apr 19, 2009
    I have the exact same laptop with the exact same problem. It's driving me INSANE! Did you ever find a solution? I'm sitting here typing this with no backlight... I just hit the lid close switch every once in a while so I can see what I'm doing during the 1/2 second that the backlight flickers on. Pathetic.
  • 170 Answers
If you go to this site you can get step by step instructions. The lamps and inverter aren't really that hard to replace if you can follow directions and have patience. Good Luck, hope this helps.
Posted on Jan 17, 2009
    Problem Solver:
  • 12 Answers
Hi Friends,
Problem with HP Notebook Or Laptops? Follow the links.
For Software problems you can visit a link by just Click Here .
For Hardware problems with this Notebook you can Click Here
Posted on Jul 23, 2010
  • 114 Answers
It is usually the inverter or the CCFL (lamp). The lamps are sometimes very difficult to change without changing out the whole display (LCD). Changing out an inverter is usually a pretty easy job. No good way to tell whether it is the inverter or the lamp without very expensive equipment. I don't think it is the lid switch such such it tries to fire up the lamp. Although the inverter or the lamp quickly quits.
  • BillW50 Jan 17, 2009
    Hard to say, but it sounds more like the lamp. But it still can go either way you know. As it is still a 50/50 chance.
  • BillW50 Jan 18, 2009
    Good luck! :)
Hp dv1000 no backlight, repalced inverter, still no screen
plug in a monitor in the side of the laptop if it shows up then the lcd is bad. Also try and reset the memory by pulling it out and then put it back in if not in all the wall nothing will appear on the LCD.
Jan 15, 2010 | HP Pavilion dv1000 Notebook
Screen dim HP pavilion dv1000
The lid actuator switch may not be working correctly. It's a small switch above the keyboard and led's on either the right or left side. Try pressing it 2 or 3 times to see if the display starts working correctly again. If so, it will need to be replaced.
If that doesn't work, you can also turn it on with the ac adapter plugged in. After it boots, press the power button and hold it in until it shuts off and then turn it on again and see if the display has returned to normal.
If neither of these options work, your laptop may need to have the backlight replaced.
Aug 13, 2009 | HP Pavilion dv1000 Notebook
Pavillion dv1000 back light does not work
Well, I believe the reason why it isn't working is because:
The backlight only works when your at the dark or at a low light condition.
If not press "fn" and press the backlight increaser on the top of the keyboard.
Hope this helps!!
Jun 25, 2009 | HP Pavilion dv1000 Notebook
HP DV1000/screen turns on then turns off.
You could have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :-
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 16, 2009 | HP Pavilion dv1000 Notebook
NO VIDEO ON HP DV1000
lcd inverter backlight lcd screen or video card probably bad
Apr 10, 2009 | HP Pavilion dv1000 Notebook
Hp dv1000, how to connect pc too tv, which drivers do I need??
connect s-video lead from pc to tv and press fn + f4 to switch monitor (usually f4)or whichever f key has a little blue square on it.
on this pc its f2 but most hp machines is f4.
Jan 16, 2009 | HP Pavilion dv1000 Notebook
Hp pavilion dv1000 backlight invertor
Hi and welcome to FixYa,
Appreciate the direct "Ask Me"
The inverter would the the elongated PCB below the LCD screen.
They would be available here, here or here.
Good luck and Thank you for using FixYa. Happy New Year.
Jan 02, 2009 | HP Pavilion dv1000 Notebook
Turning on &sterio problems
Hi, my problem was that I had trouble turning my laptop on. It had been getting worse over the last couple of years. It was suggested that the power button should be replaced. While searching the HP site on how to do this, I ran across a solution that said to take out the battery, unhook anything else that might be connected to the laptop, and then press the power button for around 10 seconds to drain all remaining power out. Then put battery back in and try to turn on. It worked! My laptop now turns on and off just fine! Hope this can help someone else....Linda P
Nov 07, 2008 | HP Pavilion dv1000 Notebook
Pullin my hair out
  1. remove power
  2. remove battery
  3. remove memory modules
  4. reseat memory
  5. replace battery
  6. plug back in.
May 21, 2008 | HP Pavilion dv1000 Notebook
HP Pavilion dv1000
I found out how to fix the no sound problem on The HP Pavilion DV1000 Look under Dv1310 thats the model number the driver your looking for is SP30262.exe
Feb 27, 2008 | HP Pavilion dv1000 Notebook
HP Pavilion dv1000 Notebook Logo
1,392 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
