Question about Sony VAIO PCV-RX741 (T99860952) PC Desktop
Installing memory i have a sony PCV-RX741 and it's not look the hp computer i have where installing the rams is easy by unscrewing screws on the side This computer don't have any screws! except for the one on the top of the pc n when i do~ that dosent get me any where.
    Genius:
  • Sony Master
  • 1,102 Answers
Turn it over there should be a square so to speak with screws
your memory should go in there
Posted on Jan 17, 2009
How do I open my sony pcv-v1
1. Ground Yourself
2. Unplug everything and press the power button for 10 sec to
discharge any residual power.
3. Place PC face down on bench with base over edge.
4. Swing PC unit forward and unscrew the case retaining screw on both
sides of the PC unit, swing unit other way and remove other two
screws.
5. Case can be loosened, pull large cover up and remove both sides.
Parts are then exposed.
6. A shiny metal box covers the memory on the left side of the PC unit. 7. Remove tape that retains it,slide and lift off from the edge facing you.
8. Memory slots are then exposed....insert and reassemble PC.
Good Luck!
May 14, 2012 | Sony VAIO PCV-RX403N PC Desktop
How do i remove optical disc drive PCV-RX741 dissasembly instructions
http://www.youtube.com/watch?v=LbF14QT3Fks
Take a look on this video ..the procedure is similar the only differences may be the locking device for the drive ..it may be different or have only screws..Another thing it may not need to remove the front panel or do not have a front panel at all ..The idea is t open the left lid..and after that remove the power cable and the data cable ..and remove the screws if present or release the locking mechanism
http://www.youtube.com/watch?v=pzLdTuUf4Qw&feature=related
this is another one ..with slightly different system ..
Dec 23, 2011 | Sony VAIO PCV-RX741 PC Desktop
I need to install better processor for sony vaio pcv-rx741
http://www.price.ro/specificatii_amd_athlon_xp_1800+_1.53_ghz_80.htm
This is the CPU you have inside from the manufacturer..It is a rather slow one ..It is an AMD model ..with 1.53 G speed and what it is matter to you it is on a socket A type ..
What you need to do is to get another cpu on same socket with more speed ..and also a larger catch memory ..(it is important for to run smoother and faster .
I don't think you will find any cpu on this socket larger than 2.2 G ..buit it is an improvement if you want to speed it up a little ..
The ram memory should be upgraded too ..and will support up to 2x 512 DDr1 on pc 2100 ..This will allow you to install more things and will even run windows xp if you get 1 G of ram on it ..but not very fast ..
http://www.cpu-world.com/CPUs/K7/AMD-Athlon%20XP%203200+%20-%20AXDA3200DKV4E.html
here is a list with the fastest cpu on this socket..
To buy one ..I think you can ask to local computer store..usually they can guide you ..but look at the price too ..cause like it is said on the site I linked..there are other less expensive with almost similar performances ..
Jun 06, 2011 | Sony VAIO PCV-RX741 PC Desktop
How can ichange memory & how to open computer
Turn your computer off, and disconnect the power-cord.
Look at the "back" of the desktop.
There will be screws holding the two side-panels in place.
Select the panel that is *FARTHEST* away from the many connections (keyboard, mouse, USB), and remove those screws.
Remove the side-panel.
Look for the stick(s) of RAM.
Count the number of "slots" for RAM.
Make a note of which slot(s) are in-use, and which are empty.
If you have "empty" slots, you can add sticks of RAM. Otherwise, you'll have to remove the RAM, and buy a bigger/better replacement (compare to replacing a bald car-tire with one with full-treads).
Disconnect all the cables from the desktop unit,
and take the computer to a computer-store.
They will check (online) to see the maximum amount of RAM that your Sony will support, and compare it to the current amount of RAM.
They will sell you "compatible" RAM, and probably, if you ask nicely, will install the RAM for you (it only takes 15 seconds). The "smaller" a computer-store that you pick, the more-likely that you'll get "free" installation, if you buy the RAM from them.
Jun 15, 2010 | Sony VAIO PCV-V200G PC Desktop
Want to add memory card to sony pcv-v1/g
Easy! Tip the screen forward and you'll see a Phillips screw towards the top of each end of the lump that sits at the base of the back of the screen. Undo both of these THEN the 2 tabs you refer to can be pushed in the direction of the arrows and the whole top of 'the lump' then comes off. The memory is under the silver colored cover held down by 2 pieces of sticky tape(!). Remove tape. Remove cover. 2 slots are exposed. One has 512 in it. Put 512 in the other one! Easy!
Sep 25, 2009 | Sony VAIO Digital Studio PCV-RX660 PC...
Can the memory be upgraded (increased) from the basic (factory installed) 512mb on the Sony PCV-W300G?
Hi there.
As far as i know you can upgrade the RAM to 2GB, 2x1GB 184pin PC2100 DDR DIMM Desktop RAM modules is what it can take.
Thanks for choosing FixYa!!
May 28, 2009 | Sony VAIO PCV-W300G PC Desktop
How to open sony vaio-pcv-w101/w to replace bad ram?
Try this:
STEP 11
Lift up and remove notebook display panel.
13-taking-apart-notebook.jpg STEP 12
Remove hard drive cover, memory cover and modem cover from the bottom of the notebook. Each cover is secured by one screw.
14-taking-apart-notebook.jpg STEP 13
Here’s how you can remove the hard drive. Remove four screws securing the hard drive caddy to the base assembly. Slide the hard drive down to disconnect it from the motherboard. Lift up and remove the hard drive.
15-taking-apart-notebook.jpg STEP 14
Removing memory modules (if needed). Carefully spread latches on both sides of the memory slot. The memory module will pop up at 30 degree angle. Pull the memory module from the slot by the edges.
Removing modem card (if needed). Remove two screws securing the modem card. Lift up the modem card to disconnect it from the motherboard and unplug cable from the side.
Hope this Helps
DR GEEK MD
May 06, 2009 | Sony VAIO VGC-V617G PC Desktop
Install memory upgrade to Sony PCV V210P
Its very simple. You will find the DIMM slots(where you install the RAM) on the motherboard. Just plug the memory into the slot and use the latches on either side of the latch to lock it in place.
This is what a DIMM slot looks like.
http://www.bosamar.com/K9N/images/dimm_large.jpg
Nov 14, 2008 | Sony VAIO PCV-V210P PC Desktop
SONY VAIO PCV V1G
Model:PCV-V1/G
Unplug everthing and place PC face down on bench with base over edge. Earth yourself.
Swing pc unit forward and unscrew the case retaining screw on both sides of the pc unit, swing unit other way and remove other two screws. Case can be loosened, pull large cover up and remove both sides. Parts are then exposed. A shiny metal box covers the memory on the left side of the PC unit. Remove tape that retains it,slide and lift off from the edge facing you.
Ten minutes tops....good luck, much better performance.
Apr 03, 2008 | Sony VAIO PCV-V100G (PCVV100GKIT1) PC...
Computers & Internet Logo
53 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
