Question about Toshiba Satellite 1135-S1554 (PS113U-3SKYMV) PC Notebook
Will not start
Had a problem with jack so replaced and had a short that started fire. Replaced mother board from one on Ebay. Now when I plug it in the lights on front come on but that is the only thing that is coming one. My son who knows something about computers helped me break down the computer and put it back together. Since I replaced the mother board I just get the lights showing that there is power.
  • Donald Schrier Jun 22, 2007
    No noise or anything like that just lights.
  • Donald Schrier Jun 23, 2007
    No sir it did not
  • 432 Answers
Assuming the motherboard is good. Do you here any sound, like the hard drive spinning up or CD-rom checking? Ray CompuGuy44
Posted on Jun 22, 2007
  • Raymond Scott
    Raymond Scott Jun 22, 2007
    I hate to say it but, you'll need to take back apart and reseat everything, cpu, memory, ribbon cables, etc..
    Don't feel bad, I've had this happen to me a few times.
    You could try changing the memory to the other slot. also if the memory chip is bad it won't turn on. Also, pull the battery out and just plug the AC adapter in.
    Did the motherboard come with the bottom case intact, I mean as a unit and not just the board itself?
    Ray
Vehicle will not start. 98 Land Rover
Most likely electrical after such a long time.
You need to uncap the distributor. Clean the points with fine grain sand paper
Change out all eight leads to the spark plugs...you can get these at Pep Boys.
Hook up in the right order!
Try starting again.
Mar 08, 2014 | eBay Auctions
I replaced the DC jack on the laptops motherboard because my Charger Fried and also melted the inside of the DC Jack, But not That I have installed a new on the power doesn't seem to come on at all, The...
There is. It would appear that the DC jack was not the only thing that was fried. If all your solder connections are correct, the mother board may have been damaged be the shorting of some part on the board, and burned open. Look for fuses, and "resistors that are have a "0" on them. they should read a short. if you find nothing. the board is damaged beyond repair.
Apr 18, 2011 | Samsung V25 XVC 2800 Notebook
The laptop will not power on and has a fully charged battery. The power on button will not light when pushed. When plugged in the led light on the front edge of the laptop should start out pink then turn...
Hi
I presume you checked the DC power supply. Don't use a generic power supply on this model, because that will cause alot of different symptoms. I use the exact same model on service calls. A further way to test the mother board is to remove the CPU and memory. Carefully provide power and look for lights. If none, my next step would be to refloat the video chip. This requires special equipment. A replacement mother board without processor on eBay is $49.00 so it might be time to consider that. Good luck
May 05, 2010 | Gateway MX8738 Notebook
Hp dv9000 will not start up
Check the memory sticks pull them out then put them back in and see if that works. if the dc jack lights up when plugged in then most likely the mother board has gone bad.
Jan 08, 2010 | HP Pavilion dv9000z Notebook
HP Compaq NX9420 Laptop Power supply shorted out replaced new Power supply purchased but Laptop will not power up suspect mother board shorted out also. Any suggestions
The DC Jack Will Need To Be Visibly Inspected, and Tested ..
Most Likely Need To Replace The DC Jack (the port where your AC Adapter Plug Plugs into.....
Though, if you experienced a power surge/dip or similar, You could have shorted out the motherboard....
Dec 01, 2009 | HP Computers & Internet
Compaq V2000 overheats at power-in plug.
Sounds like the power jack has a short and needs to be replaced.If it melted the ac adapter tip then its a ground problem in the power jack or where it connects to the mother board.
Aug 11, 2009 | Compaq Presario Notebook
Pc starting problem
There is a battery on you motherboard and it needs to be replaced. Usually it's a large round lithium battery. If you replace that it should go to default.
Mar 10, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
I just replaced ac jack on acer travel mate 2480
most likely I would say sounds like your ac jack is shorting out this is common with acer computers there is one place that can fix this promblem it is in the internet type in jack repairs
there is a place in virgina that can fix this prombelm for $115.00+ 20.00 dollars sending fee
or you will prombally have to replace the mother board ..........
Jan 05, 2009 | Acer TravelMate 2300 Notebook
ZV500 power plug problem
I've repaired alot of laptops... One thing that I found works the best is get 3 bowls or dishes.... Label them; 'Top', 'Bottom', and 'Logic'. Almost all laptops require you start disassembly at the base of the unit. Unscrew every single screw you see, make sure there are none left before you start on the top. The way alot of laptops are set up is that you unscrew the bottom, pop off the top casings/covers then unscrew the top screws. Once you've removed all the screws from the top and the bottom, there will be very little attaching the casings, so be careful. Remember to Unplug everything you see attached to the logic(mother) board, or you risk ripping a fixture off the board. Once you have freed the logic(mother) board from the attachments and casings you should very careful.
Now as you start work on the power jack, I Highly recommend you use a solder wick and flux to remove any solder left on the board from the previous repair. It is never a good idea to leave old solder on the board. You should be careful with the solder you don't want to short anything out by using to much solder. Once you have finished your repairs to the DC jack you should test it out plug it in to the AC Adapter and look for any visual indicators of life(i.e. charge batt light).... So now you know it works.
If you get it back together and it suddenly doesn't work its possible you have a case short. If thats the case look on the metal casing for any discolorations or blackness and if you find any place some electrical tape over it... it should be fine.
Good Luck. Don't be nervous its not as hard as it seems.
Hope this helps lemme know if you have any questions.
Sep 14, 2008 | HP Pavilion dv6000z Notebook
Pentium 4
the motherboard and the power box should be replaced. you hade a short and the power box went out and the mother board shorted out as well. If you replace the mother board you will see. This happens alot to people. Check out the numbers on the board at type it in the web and find out what kind you have. you can find motherboards cheap on ebay.
Dec 15, 2007 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Toshiba Satellite 1135-S1554 (PS113U-3SKYMV) PC Notebook Logo
42 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
