Question about DB Drive SP10.1 Car Subwoofer
Powers up, but no sound
The problem is that there is no sound at all. the LED power light lights up, so there's definitely power, but somewhere between the power and the speaker, there's a problem. any suggestions? the capacitor gets real hot, but i thought that was always the case?? Cheers
No picture only sound.
Engineers are right, you need a new LED panel., or the component that supplies the light to the screen.
Mar 18, 2016 | Philips 55pfl4706df7 4000 Series Lcd...
Vizio tv has sound no image
If you can see an image on screen via flashlight test then the backlighting is not working. And the inverter board is the unit that powers those lights ..... So....................
Mar 05, 2016 | Vizio Televison & Video
Model 50LN5700-UHBUSYLJR. Why is there sound but no picture??
Chance your led strip if you are sure that your power supply led module is working perfectly
Jul 20, 2015 | LG Televison & Video
Unit powers on, is unresponsive
It sounds like you need to take it in for repair.
May 07, 2015 | Behringer US600 Ultra Shifter/Harmonist...
RCA D52W26 TV Powers on and has sound. It has no picture.
If this is an LCD TV, show a torch light on the screen from a safe distance. If you can see the picture, the back light is not getting on. You may have to call in a qualified service technician.
Aug 02, 2012 | RCA Televison & Video
No power to unit no led lights light,no display in the led screen
You need to check the 12v battery in the unit it is what powers the lcd display and led lights on the generator.
Oct 15, 2010 | Generac Guardian 200 Amp Transfer Switch...
No picture, when powering up the light will turn yellow, them the t.v powers up and can hear sound but no picture, and then hear a click and light flashes green.
First turn on,do the power LED light stable?Few sec.Power LED and LED OPC flashes?This very common on Sharp tv,tries power off/on at 4 or 5 each time it flashes,well power up have backlight on and it work.After this doesn't work than ur Tuner Signal board it dead.
Feb 03, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Won't post/boot
Try removing one of the two memory SODIMMS under the cover on the bottom of the unit. It sounds like you could have a bad memory problem that is keeping the machine from completing the POST (power on self test). I'd try one stick at a time and see if that helps.
Good luck, please rate this solution if you feel it has helped!!
May 13, 2009 | Dell Inspiron 1501 Notebook
Xm-6650 led light on short is on and no sound
Disconnect all speaker wires and signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down, the amp likely has blown output transistors.
Dec 16, 2007 | Koiiler XM-6650 Car Audio Amplifier
DB Drive SP10.1 Car Subwoofer Logo
62 people viewed this question
Top DB Drive Car Audio & Video Experts
Professor_V
Professor_V
Marvin
Marvin
Tom Chichester
Are you a DB Drive Car Audio and Video Expert? Answer questions, earn points and help others
