Question about Hotpoint First Edition FEW12 Front Load Washer
Washing machine not working
Hi there i turn my washing machine on as normal and the red active button comes on as normal,but no response from machine of movement at all,but also a red flashing light keeps flashing on & off where it says door locked & i can also still open the door with the red active button on and the red light flashing on & off where it says door locked ? could this be the doorlock mechanism,as the machine could of still been on a cycle and the door could of been forced open? i hope someone can help out there
  • forduk2008 Jan 20, 2009
    anyone out there with an anwser? please
  • john592 Feb 19, 2009
    Washer fills up and just stops. Drum won't turn. Have had circuit board checked it's ok ? Anyone any idear.
    Problem Solver:
  • 14 Answers
I Put A Set Of New Brushes In motor And It started
Posted on Feb 26, 2009
  • john592 Feb 26, 2009
    HAVE YOU TRYED PUSHING DOOR SHUT. MINE DID THAT AND I PUSHED THE DOOR SHUT AND ITS OK . HOPE THIS WILL HELP YOU
Hotpoint wma62 normal sign lashing red green sign flashing machine will not start what is the solution ?
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Jun 05, 2012 | Hotpoint Washing Machines
GE Dishwasher Won't turn on
Door may not be fully closing for some reason.
Mar 15, 2012 | General Electric GE Profile Dishwasher 24...
GE GLD4660N10SS dishwasher won't turn on
make sure your kithen ground fault detector has not poped closed. Push the red button to activate it.
Dec 30, 2011 | GE Computers & Internet
CL is coming across the screen. i don't no what to do? i have tried everything from unpluging to cleaning the rubber. also i tried to run with using tide for cleaning and nothing is working. need help.
hi.
CL normally means the child lock is active. look for a lock symbol, either next to a button, or in the middle of a line connecting 2 buttons on the front of your machine. press and hold the button(s) for five-10 seconds until the CL goes off. hope this helps
Aug 16, 2011 | LG Washing Machines
Here again is my model and serial it stops in the middle of the cleaning cycle Kenmore 665.16773402 serial # ft0302854 Here is how I have been resetting the dishwasher. I hit the following sequence of...
Door latch.
Open and close the door to make sure the door latch is securely fastened
Hi-Temp Wash, Hi-Temp Rinse, or Sanitize options.
Some models have options that may require a water heating delay, such as Hi-Temp Wash, Hi-Temp Rinse, or Sanitize. Additional time may be required to heat the water to the proper temperature. The dishwasher will continue to circulate water during this heating delay but the timer will not advance until the proper temperature is reached
Oct 06, 2010 | Dishwashers
My Hoover Optima OPH 714 D washing machine won't start
Hope your tried switching off the machine for half to one hour, to re plug. Machine might re-set.
If helped, pl click, it could help others.
Dec 07, 2009 | Bosch Washing Machines
Bosch classic 6 1400 express washing machine - key lock symbol illuminated on panel when machine turned on so machine will not start. No instruction manual so wondering how to turn the lock off? Many...
This is symbol shows that the child lock has been activated. This can only be turned on/off at the beginning or end of washing programme. To activate/de-activate this, just press and hold the Start/Pause button in for 5 seconds. The time settings will then re-appear and then you can proceed as normal
Oct 17, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Saeco Magic Deluxe - Coffee Cold,Lights not working
The thermoblock (boiler) element is burnt out and must be replaced.
Feb 10, 2009 | Saeco Magic De Luxe Espresso Machine
Hotpoint first edition few 12p,not working
parts are free but a call out charge is made approx £80.00
Jan 17, 2009 | Hotpoint First Edition FEW12 Front Load...
Buttons won't work on GE Profile PDW7980N10SS
You have the control lock activated. Press and hold the heated dry pad for 5 seconds and it should unlock it
Nov 15, 2008 | GE Profile PDW8400J Built-in Dishwasher
Hotpoint First Edition FEW12 Front Load Washer Logo
503 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
