Question about Panasonic DMR-EZ47V DVD Recorder/VCR
My dad put a dvd in upside down in a Panasonic DVD Recorder DMR-EZ485V and now the tray won't open. Any suggestions?
  • sknott2 Jan 17, 2009
    Thanks, got it by unplugging for five minutes then plugging back in. Will keep that info if the other way doesn't work.
    Sergeant:
  • 227 Answers
May be 4 to 6 screws holding on the cover. Remove the cover to access the disc.
Posted on Jan 17, 2009
Have a panosonic dmr-ez485v dvd recorder that cycles 5/6x when tray is closed with/without a dvd, and get "no read' message.
1.The DVD Drive makes two-three times noise than stop spin the media CD
or DVD.
-Bad DVDRW Drive.
2 The drive does spin CD-DVD but doesn't load.
-. Bad NDMi PCB VEP79180 or VJB79180
3. Drive spinning but don't load CD or DVD
More chance Bad Drive or Problem with drive PCB.
Open top Cover of drive, open tray,
close tray.
If laser flashed but doesn't play CD-DVD more chance bad drive PCB
Check: avsystemparts.com
Feb 01, 2013 | Panasonic DMR-EZ485VK DVD Recorder/VCR
No read on my 2008 panasonic dvd recorder DMR-EZ485V
Insert a lens cleaning disc into it and let it play. If this do not help you, the optical pickup unit to your playder is faulty, and should be replaced.
Apr 30, 2012 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
I have panasonic dmr-ez485v dvd recorder cambo, it has F60 code don't turn on or off
Hit reset button, unplug it or swear at it. If you looked up online find more problems listed on unit then ways to correct problems. Does have nice play back. I bought a DVD maintenance kit seams to help some issues. good luvk
Apr 24, 2012 | Panasonic DMR-EZ485VK DVD Recorder/VCR
Have panasonic dmr-ez485v error message -NO READ- changed disks used prerecorded movie same as my recorded disks, hit reset - still no change
I just saw the date on this message and realize that it was awhile ago. I assume that you have dealt with it by now... So for others who are trying to fix their DVD player:
I have a DMR-EZ485V DVD player and just started getting the error message "No Read." I couldn't find an answer on the internet and finally called Panasonic's customer service, (there is no charge 1.800.211.7262). Since it says "No Read" to everything--store-bought DVDs, burned DVDs, CDs; AND when there is nothing in there (it acts like it is trying to read when the tray is empty), the customer service rep thinks that I am having a lens issue. It either needs to be cleaned (can pick-up a product at Best Buy or Radio Shack) or, if that doesn't work, the lens needs to be replaced.
Aug 09, 2010 | Panasonic DMR-EZ485VK DVD Recorder/VCR
Panasonic DMR-EZ485V. Remote stopped working when
Panasonic website under FAQs. Using code shown on dvd readout,
such as RC2, press 2 & enter or ok, hold for 2 seconds, and machine
will reset connection between remote & dvd recorder. So stupidly simple it works.
Feb 15, 2010 | Panasonic DMR-EZ485VK DVD Recorder/VCR
Panasonic dmr-ez485v locked up with dvd inside, keeps cycling can't eject dvd.
Replace the CR14 changer mechanism. If it is under a year old it is covered by mfc warr. Seek auth Panasonic servicer.
Nov 20, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic DVD recorder won't recognize any disk inserted in tray
I am just wondering if you found the solution to this problem as it has happened to ours.
Regards
Oct 11, 2009 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
Need PANASONIC DMR-EZ485V remote control codes for vizio VA220E. Have tried 0178 and it works the on/off but what will also work the channel and volume? Thanks for any help. Fran
I connected my Panasonic DMR EZ485V DVD Recorder in 240 VA, and after to broke (burned) the safety fuse. Do you know what is the value of the fuse??? I need replace this, but I don´t know the specification. I know my Panasonic DMR EZ485V DVD Recorder work 120 VA. Best regard
Jun 29, 2009 | Panasonic DMR-EZ485VK DVD Recorder/VCR
Disc tray doesn´t open, no help from previous answers
One thing you can try is to disassemble unit and remove tray section . on the underneath side of tray is a plastic gear that will allow you to manually bring out the tray thus removing the dvd . then put back together and see if it works ok . Or just may only have to remove the spindle adaptor on the top of the dvd with the screws on the side that hold it down . then remove the dvd , put back together and try . Some disc's that a dvd player cannot read properly can cause the system to lock up as you described . Good luck
Feb 29, 2008 | Panasonic DMR-ES10 DVD Recorder
Panasonic DMR-EZ47V DVD Recorder/VCR Logo
507 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
