Question about Hitachi 61HDX98B 61" Rear Projection Television
Video blanks out, power light turns off, power supply shut down
TV comes on and displays the OSD menus. If left alone, power will stay up on the TV. All leds and power supply voltages check correct. When an antenna connection is selected, the video will display for 10 to 20 seconds without any audio then the video blanks out and the power on light goes out. All of the power supply and deflection chassis leds stay lit. A few seconds after that, the power supply crowbars and shuts down. Using the audio test function in the OSD menu (no video input), there is no sound and after a few seconds, the shut down sequence occurs. The DM-1 control module should blink the power led twice when AC power is plugged in, but I do not see this. I removed the main chassis and power supply, checked both with an ESR meter, checked for shorts on the deflection board, used a lighted magnifier to check for cold/cracked solder joints, re-soldered any that even looked dull and repaired a solder bridge on the -13V drive transistor. Any help would be greatly appreciated.
  • 4 more comments
  • Rick Corey Jun 27, 2007
    The repair manual only shows a block diagram for the DM-1
    control module, no schematic or parts list. The manual refers to the DM-1 as a "non-repairable front end module" and it contains the main microprocessor, the ntsc & atsc decoders, the osd generator and video and audio demodulation. I made a visual check and there is no fluid leak evidence on any of the circuit boards below the CRTs.
    I had clicked on the "another solution" before I added my comments, sorry.
    Removed the front control panel module, checked the caps with my ESR meter, all checked good. Ohm checked the diodes and transistors in circuit, no shorts. Remote control functions correctly, panel switches function correctly. Scoped the power on signal from the DM-1, it goes low at the same time the video blanks out. Appears that the DM-1 is not working properly or is detecting some other problem. Had a similar problem with this set while still under warranty and the service guy that Hitachi sent out replaced the activation plug-in card.
    Have been trying to scope blanking and shutdown signals, but it is very difficult to get at connector pins to see what is causing the shutdown.
    I have full screen video when the antenna is selected, but no sound. When the problem first started, I had sound and video for a few minutes before it blanked and shutdown. Will scope the 130V B+ and other voltages to see if any are dropping when the video is selected.
  • Rick Corey Jun 28, 2007
    Monitored B+ while switching from OSD to video, no change in value (130V DC). Monitored other voltages with the same result. All leds remain on (not blinking) as described in the service manual until the power supply shutdown occurs.
  • Rick Corey Sep 07, 2007
    Dyllan,
    I determined that the problem had to be coming from the DM-1 tuner assembly. Sent it to PTS for testing and repair. They got the same symptoms that I was seeing and, after working on it for 2 weeks, declared it unrepairable. Rather than invest another $700 or so to replace the module and be stuck with 10 year old technology (no hdmi, no component video, etc.), I decided to replace the set. Thanks for checking back on this.
    Sergeant:
  • 279 Answers
Are you still working on this one? It's been more than 2 months, so I thought someone should check in. If it still isn't working after the last advice given here, can you give us an update of the current status, so we can see if there's any other suggestions to be made?
Posted on Sep 07, 2007
  • 934 Answers
If your PS waveform drops out it could be your 130v regulator (photo coupler) IP05 Hitachi p/n#2000465... The load would change when simply displaying an OSD to then creating a full screen raster. And something beyond that could be loading it - like the vertical IC601. Do you have a full vertical deflection when you select antenna?
Posted on Jun 27, 2007
    President:
  • 3,130 Answers
There are bad capcitors in the control board, there are bad tact switches on the control board,or the CRTs are leaking fluid onto the printed circuit boards Good Luck
Posted on Jun 25, 2007
  • 1 more comment
  • Larry  Dillon
    Larry Dillon Jun 27, 2007
    How did you check what I wrote for you. There is no way to fix it magicly. You will need to check what i wrote .
  • Larry  Dillon
    Unplug the front control boardwith the front panel control switch on it, and make sure the remote sensor is disconnected.
  • Larry  Dillon
    Larry Dillon Jun 28, 2007
    Check and/or replace the opticoupler
SOURCE:
How do I fix my Jvc the screen won't power on. When I reset it the lights on the buttons light up...but shut off right away. It has power because the red light on the bottom left corner stays lit.
JVC LT-46AM73 LCD TV Won't Turn On - YouTube
? 3:28
https://www.youtube.com/watch?v=y5j3RGUe4gM
Feb 25, 2015 - Uploaded by Awesome Things
JVC LT-46AM73 LCD TV won't turn on after power outage. ...LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test - How to ...
JVC wont turn on - JVC - Streaming Video & TVs
www.tomsguide.com/answers/id-1677424/jvc-wont-turn.html
May 15, 2013 - JVC lcd tv will act like its turning on then the green light after 2 seconds ... wont turn on Forum; SolvedAcer Laptop V4DA2, screen won't turn on.
My Jvc Av-32F476 Tv Won't Power On, The Green On Timer Light Stays ...
www.diyforums.net/my-jvc-av-32f476-tv-wont-power-on-the-green-on-...
Dec 8, 2013 - My jvc av-32F476 tv won't power on, the green on timer light stays on and m. ... On the remote control, look for the buttons PICTURE MODE and DISPLAY, with ... My Jvc Lt24dd52j Won't Turn On The Blue Light Is Flashing But ...
Nov 1, 2014
I Have A JVC LT-42TG30J, Randomly The Tv Has Decided It ...
Aug 29, 2012
I Have No Picture On My 47 Inch On My Jvc Big Screen Just A ...
May 23, 2012
My Dynex 42" Wont Turn On Power Led Is Lit Up But It Won't C ...
May 24, 2011
More results from www.diyforums.net
Jan 18, 2016 | JVC Televison & Video
Panasonic Plasma - turns on, but stays blank.
Your TV probably has power supply trouble.
Jan 16, 2014 | Panasonic Televison & Video
When I'm told the system was not turned off correctly press ok then the screen stays blank
You corrupted your settings. Turn on the Ps3 let it power cycle, once you get to the blank screen hold down the power button until it beeps 3 times (about 25 secs) Your ps3 will shut off( note: if you have HDMI only, plug in your RCA connections as this will reset your ps3 display to analog) once you are back at xmb, plug in your HDMI and go to display settings and select HDMI. Always let your PS3 do its thing before shutting it down, its equivalent to unplugging your computer instead of logging off correctly.
Jul 06, 2012 | Sony Playstation 3 (PS3) Console
Power indicator light only blinks "red" 7 times and repeats. Is it a power supply problem? no OSD. nothing
I had similar problem with my panasonic tv, turned out to be a fan failure causing power supply to shut down due to overheating, Also could be a capacitor fault in the power supply.
pete
Mar 06, 2011 | Philips 42PF7220A 42 in. Plasma Television
My Sanyo HT28745 28" HDTV clicks but doesn't turn on
I have had a similar problem with my tv, it has something to do with the power supply.Try unplugging your tv from the AC outlet. While unplugged from the power supply hold down the - volume control and then plug the tv back in while holding down the - volume control. It should bring up the service screen. If the screen turns on and is blank then it may need to be brought in for repairs.
If the screen does turn on, either blank or with the service menu, turn off the tv and unplug it from the power supply again. With it still unplugged hold down the power button on the tv and then replug in the tv. continue to hold down the power button until the tv displays a video signal on screen.
Feb 02, 2008 | Sanyo HT28745 28" TV
Blank display on a Onkyo TX-SR501
try to connect the receiver to a tv via the monitor out from the receiver to the tv. you may be able to see the OSD (on screen display of your settings) change the function on that to turn on the front display. alternatively look on your remote to see if you can turn up the light of the front display.
if these don't work possible that the light of the display has blown.
good luck
smeags.
Dec 31, 2007 | Onkyo TX-SR501 Receiver
Screen stays blank after turning it on.
Hello, The blinking pattern you're observing is a result of a heavy current load on the power supply. The power supply could be defective but more than likely the scan or sustain boards have a direct short on them causing the power supply to shut down and display the error. A technician will be able to determine where the load is coming from and replace the appropriate board or component. I hope this helps you. Joe Weibel CustomElectronics.Org
Feb 28, 2007 | Maxent MX-42VM 42 in. Plasma HDTV
Open Questions:
Hitachi 61HDX98B 61" Rear Projection Television Logo
60 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
