Question about Dell Inspiron 1501 Notebook
Replacement adapter will not charge battery
I just purchased a new ac adapter for my Dell Inspiron 9100, but the computer is not recognizing it. The battery will not charge and is now at 0% power.
  • 3 more comments
  • wpmellinger Jan 17, 2009
    No. The battery was working and the adapter was charging. I have had multiple adapters go bad over the past few years
    At best two weeks. The battery still had a charge when I plugged in the adapter. But when the computer starts, it says that it does not recognize the adapter. I have tried going through the setup routine F2 and even reinstalled drivers but it will not charge the battery
    We ordered it online and I am beginning to think it is a generic
    Is there any way around the "trick"? :)
    Bummer! : ( I have written to the company that sold us the adapter, but I wondered if this was the problem. Thanks for trying.
  • 114 Answers
Did the old one do the same thing? If true, your battery sounds like it is dead.
Posted on Jan 17, 2009
  • 2 more comments
  • BillW50 Jan 17, 2009
    How long did the laptop sit without a charger, like months? Left the battery in? If true, the battery is mostly dead now. :(
    Oh I see. Is it a generic replacement? Or is it from Dell? A generic one might not work. As some manufactures use tricks to prevent clone replacements from working. :(
    No, they send proprietary data through the cable to see if it is a real Dell or not. And take out the battery if you are not going to use it for a week or more. As that will prevent any damage to the battery if you let it sit too long inside the computer.
    Okay you are welcome. I hope everything works out.
Had same problem dell adapters have a small prong in the center wair they plug into the laptop wich bends easly if it gets bent the laptop will not reconize the adapter or chare the batery but will still run with erro on start up i had be very cairfull using aneedel to strainting the prong now works fine
Posted on Jun 03, 2009
My dell inspirion ac charger will keep computer running but will not charge my battery. A pop up will inform me that the system doesnt recognize the charger.
it could be a couple things: Are you using the standard 90 Watt ac adapter, or the Travel auto/Air adapter. The travel adapter is only 65 watts can will charge the battery
If using the standard ac adapter, see if you can try another Dell D series adapter and see if you get the same error.
If same with another adapter, the issue is the charging circuit. If another adapter works, then replace the adapter.
If the charging circuit is bad, it will be the chargerboard or if intergrated, the motherboard
Sep 25, 2010 | Dell Inspiron 1545 Notebook
I have a Dell Inspirion 1525. I have a fairly new after market replacement battery which I have only had now for 4 months. I am using Vista. As soon as I unplug, computer shuts down. I go to power settings...
The adapter is working correctly. The battery is either slow to charge or in need of replacement.
It's possible your battery isn't charging at all so to test this boot into bios -> battery status and watch it run overnight.
Sep 09, 2010 | Dell Inspiron 1525 Notebook
My Dell inspiron 9400 wont charged my battery. Both the charger and battery are new
try to charge the battery while the computer is off for 3 hours. if that does not work, remove the battery from the computer and turn on the computer using only the ac adapter. if the computer is working fine using only the ac adapter, call your computer manufacturer for possible battery replacement
Jun 11, 2010 | Dell Inspiron 9400 Notebook
I just bought a replacement 9 cell battery and a 90 watt power adapter for my Dell E1505. With the new battery and power adapter my battery indicator light keeps flashing green and the battery doesn't...
If a new DELL ac adapter (3rd party Adapters are not recognized and the charging circuit is disabled) and a new battery doesn't resolve then the charging circuit on the motherboard is bad
Dec 29, 2009 | Dell Inspiron E1505 Notebook
Dell Inspiron 1545 AC Adapter error message
-check the system battery information and charger information of the computer; restart the computer, while the computer is booting up, press F2 repeatedly; check "battery info"
-if it stated ac adapter = unknown device ; update the BIOS (-visit support.dell.com
NOTE:other computers may have different BIOS, if it is not the same you may have to consult manufacturer
-click on drivers and downloads
-click or choose by service tag
-download the BIOS and install it on the computer)
-check information after updating; if same message AC adapter = unknown device; call manufaturer for a replacement AC adapter, if status has changed it is a battery problem or motherboard, contact manufacturer to test battery
Sep 29, 2009 | Dell Inspiron 1545 Notebook
I had the battery not recognized on boot up. then
the Dell AC adapter has a sensing pin so the bios can determine the wattage of the adapter. If the system cannot ID the adapter, the battery charger circuit is disabled. You'll need a functional DELL ac adapter to get the battery to charge
Sep 26, 2009 | Dell Inspiron 1501 Notebook
Inspiron 1525 plugged in not charging
replace u r computer, as the cost of mother board and the age of your computer I suggest replacement.
Jun 20, 2009 | Dell Inspiron 1525 Notebook
My computer will not recognize the battery. Runs OK on AC.
Since the system is not seeing the batteries the apparent fault is the motherboard connection for the battery. If under warranty , contact Dell, in not, you can try and purchase a replacement motherboard on EBay.
Apr 26, 2009 | Dell Inspiron 9300 PC Notebook
Dell Inspiron 1501 Notebook Logo
284 people viewed this question
Alun Cox
