Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Door opens and gets stuck on casing of motor
Our door opens and shuts fine but every two or three times the door opens too far and the piece of metal that the door attatches too gets stuck on the motor casing because it opens too far its the same piece of metal that the latch hooks to on the chain
    Champion:
  • 244 Answers
Do yu mean the trolley opens too far. Check travel limit mechanism (Take cover off). Wires attached. My need new board.
Posted on Jan 17, 2009
Sharp r520kst door won't stay shut
If the door will not stay closed it is the spring inside door, or the small plastic piece that holds the spring which is attached to the $80.00 piece called outer door.
To fix it, it is EASY and you do not have to even take the inside cover all the way off. Just remove the three sides of cover by gently slipping a plastic putty knife around rim to release the clips. Then attach the spring to the small hole below where the plastic piece used to be, which is located in the metal on the glass frame piece, use tweezers, hold the other end of spring as you place spring onto plastic door latch and set into place!
Snap the inside cover back on and YAY! FINI!
Aug 20, 2012 | Sharp Microwave Ovens
My GE dishwasher's door is stuck shut ~ I'm assuming a broken latch. I was told to fix the latch, the dishwasher has to be taken out from under the counter top (in order to get the door open). My...
Well I'll try to help you get this opened. I don't know how much space you have at the top side edge of the dishwasher. You need a long stiff rod like a metal clothes hanger straightened so it can reach from the side to a little past the dishwasher middle. You need to push it in between the door top and the dishwasher body up at the latch area. What holds the door closed is a flat metal piece with a plastic hook on the end facing down towards the floor. You need to try and get the rod under the metal piece and lift it slightly, hopefully to unhook the the door. If you can't do that, the only alternative is to pull hard on the door handle and you should be able to break the plastic part of the latch which will then have to be replaced. The part that should break is the top hook which would be an easy replacement, but I can't be sure thats all the damage to the latch that will happen. It may do some damage to the part inside the door also. This is last resort. I'll try to attach a parts breakdown of the tub so you can see the latch hook. Look at item #50
Jun 10, 2011 | GE Profile PDW9880NSS Stainless Steel...
The light control, a bi metal component, has seperated too far apart and does not allow the light to come on when the door is opened or closed. The two pieces can be pushed together by hand and that will...
Wow you have an old opener. You should be able to bend one of the pieces so that they stay closer together. Just in case this doesn't work that part is still available at Sears Parts. The part number is 1A35QB and the price is $12.09.
Apr 29, 2010 | Sears Craftsman LiftMaster Chamberlain...
How to install a rear window regulator on a 2000 Oldsmobile Intrigue
How do you remove door panels and replace window regulator on an Intrigue? Answer : For a 2002 Intrigue – Front Passenger I didn’t disconnect battery. You use window switch later to align window tabs to regulator frame – with ignition off power locks work, nothing is exposed.
1. Remove visible screw under armrest, pop out finger inset oval panel, remove exposed 2nd screw. 2. Pop off door handle trim – lock button assembly slide thru its hole in door panel. 3. Pop off window switch trim/holder – slide thru its hole in door panel. 4. Remove 2 slot screws under bottom of door.
5. I used a smooth metal letter opener (or old fork) to pry panel from door at each point plastic fasteners insert into metal. Start prying a little, see three on bottom perimeter two inches from edge. Three on door open edge and three on door hinge edge. Slow and easy = whole panel will pop off. A metal compression spring fastener connects at top door hinge edge trim – pry out. Be sure door lock and window switch remain inside. Clean all surfaces of door panel and lay on back seat.
6. With panel off you see clear plastic moisture sheet stuck to door with black rubbery paste - peel it from door for reattachment. You now see mechanism and fastener points. Lay out replacement window regulator and motor on mat by door to help you recognize fastening points, etc.
7. Carefully pull glass all way up and hold in place with two pieces duck tape two feet long with ¼# removal tabovers. Put a foot on outside glass and loop over door frame a foot to inside glass – with room to later redo when you twice lower and raise a foot to access bolts removing/attaching it to regulator bar.
8. Remove 3 bolts holding motor to door. 9. Remove upper 2 bolts and lower 2 bolts holding regulator frame to door.
10. Lower window to expose thru panel cutout area two bolts holding glass tabs to regulator, retape securely. Remove bolts, raise window, retape securely by looping over door frame.
11. Window regulator and motor assembly comes out as unit. Unplug window switch tab to release from motor. BEFORE reassembly clean the inside of the door, put in a little Borax for bugs, etc.
12. Reassemble by starting three motor bolts, fitting regulator assembly in door cavity. Replug window switch, motor can be placed in thru oval slots, leave all bolts loose. Replace two upper and two lower regulator bracket bolts, leave loose.
13. Turn on ignition, use window switch to lower window glass regulator tab bracket until accessible thru panel cutout. Turn off ignition, manually lower glass until tabs align with regulator bracket bolt holes and tighten these bolts. Take tape off, turn on ignition, raise window to top.
14. Tighten three motor bolts and four regulator bracket bolts, make sure alignment is OK. Remove your tape residue - clean goo from both glass sides with Goof Off. THEN raise and lower several times to assure all fits and works like new.
15. Reinstall clear plastic sheet, aligning any fastener holes and rubbing down perimeter with a cloth .
16. Align door panel, assure door lock and window switch are pulled thru. Visually align each tab on door opening side and pop them in one at a time. Continue on bottom – make sure you see them align or they will break. Finish on door hinge side and with metal fastener at top. IF you break a fastener, take one from small bag you bought from Pep boys - otherwise take bag back for refund…
17. Reinstall 2 armrest screws and 2 bottom panel screws, then pop in door lock, trim piece and window switch.
Clean the window inside and out with glass cleaner/polish/raineze so it will slide easily and your done. You can’t do anything about the motors going out. You can avoid regulator tab breaks by making sure the window is raised BEFORE closing those big doors – down is the weak moment!! I work slow and clean as I go, the job took two hours. I highly recommend partsgeek.com – saved a bundle over dealer and they shipped everything in several days – as ordered!
Jul 27, 2009 | 2000 Oldsmobile Intrigue
Motor will not perform a complete cycle sears 139.53675SRT1
I spent 30 minutes on this site and couldn't find the answer, then I was redirected to another post on this site after doing a different google search. User lftmstr1245r offered this advice in July 2008:
"The problem lies in the RPM sensor, most likely due to the interrupter cup assembly. The interrupter cup assembly is the black cap that runs through the RPM sensor. You may have forgotten to re-attach this piece or it is probably moving too far out when the garage sets in motion. To fix this, remove the cup assembly, unscrew the two screws on the top metal piece with a 1/8 allen wrench, push the metal piece as far in as possible and put the screws back on. This will give more room for the cup assembly to spin and be read by the RPM sensor. Hope this helps!"
Apr 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage Door Openenr Motor Buzz
Look at your manuel find the page that shows the limit access switch. (Unplug your opener.) It isn't really a switch, but the three white plastic screw like parts. The center has a brown wire connected to it, which has a metal piece that is as wide as all three white screws. The outside screws are your limit access stop guides, one for the up control stop guide and the other for the down control stop guide. If the center screw with the metal part gets caught behind on of the stop guides the motor will not engage. Gently move metal piece from behind the stop guide.
Nov 10, 2008 | Sears Craftsman LiftMaster Chamberlain...
Canon imageclass mf6530
Reason : the shutter of the laser is not opened by the cartridge. (I had same problem, and solved it)
Open the door and remove the toner. look inside and you will see in the upper part a rectangular window in the metal bar. This window is shut by a metal plate behind when the door is open. Try to raise it with a knife. This is the problem. Now, this shutter is here only for legal reasons (security to prevent the laser beam going out when door open, but when the door is opened the power is shut so...). Cut a piece of plastic just the width of the opening, fold it at angle in the form or an L, then place it on the left side of the opening, so that the shutter can no longer go down. A piece of scotch to fix it in place and you are done.
Now, if it works and you are grateful, I am interested in empty cartridges.If you have some tell me. Thanks.
Jul 27, 2008 | Canon imageCLASS MF6530 Monochrome Laser...
Amana 22 side-by-side refrigerator, freezer door opens slightly
There are three possibilities to this problem:
1. Door seal which should be magnetic is faulty.
2. Ice maker caddy (container) has not socketed properly into ice maker rear drive tang.
3. Door stay closed plastic hing pieces are damaged. These are tapered pieces that fit in hinge area that allow door weight to help close and hold door. Some are black in color and some are white. As far as I know they are interchangeable.
Jul 17, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Driver's side door power locks are stuck; door stuck shut.
sounds like the rods are disconnected the clips hold the rods in place the latching mechanism holds the handle in place as well did you replace the speakers or did a shop? if a shop did then they caused this if you did then you may have caused this either way untill you reattach the rods none of it will work. you will have to manually open the door at the latch from inside teh door behind the panel.
Jul 16, 2008 | 1993 Ford Mustang
Cannot put stove door back on mclary model
Hi, i have a eurolec and had the same problem. For ours the door had to hinged pieces of metal on either side of the door. To get the door back on we pulled the longer of the two pieces of metal as far down as the spring would allow (took a lot of force) and jamed a bit of metal (we used some slef tapping screws that we had) in their to stop it moving back. This is done on both sides.
You simply slide the door into place and then move it to the completely open position. Pushing the door a little more open allows you to remove the pieces of metal to be removed and then the door operated correctly
Apr 12, 2008 | Stoves Kitchen Ranges
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
147 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
