Question about Dell 3000cn Laser Printer
Print Quality Printer is puting a wide line down the right side of the printer. Wide line is black and may contain some color.
  • 73 Answers
It sounds like the drum needs to be replaced. They have a life cycle of around 30000 pages, but can also wear down over time. These can be purchased directly from Dell by calling 18002893355 (US).
Posted on Feb 08, 2009
Line on right side of copy from epson nx415
It sounds to me that there is an actual leak from the printer when in use. You need to have it serviced.
Mar 07, 2014 | Epson Stylus Nx415 Color Inkjet Printer...
When you change the ink cartraige and clean printer and test the colours the quality of colour is not good on the test! what do you segested i try beacaue the machine has been on its 100th clean and...
    1. Print a Print Quality Check Sheet.
    2. Press the Ink or Ink Management key on the control panel.
    3. Press the up or down arrow key to choose Test Print and press OK.
    4. Press the up or down arrow key to choose Print Quality and press OK.
    5. Press Color (Colour) start. The machine begins printing the Print Quality Check Sheet.
    1. Closely examine the Print Quality Check Sheet. Each of the four colors is represented by a slanted square pattern made up of individual blocks. The colors should appear in the following order from left to right: Black - Yellow - Cyan - Magenta.
    2. Compare the print quality of the Check Sheet you just printed with the three examples listed below:
      (A) One or more complete blocks of colors are missing:
      (B) Most of the short diagonal lines are missing from one or more color blocks:
      (C)Some parts of the short diagonal lines are missing from one or more color blocks:
    3. The display will then ask you if the print quality is OK for black. Press the down arrow key or 2 or "-" to choose No for black with the problem.
    4. The display will then ask you if the print quality is OK for Color. Press the down arrow key or 2 or "-" to choose No for color with the problem.
    5. The display will then show Start Cleaning? Yes No.
      Press the up arrow key or 1 or "+" to choose Yes and the machine will start cleaning the color ink cartridges.
    6. When the machine completes cleaning the print head, press Color(Colour) Start. Another Print Quality Check Sheet will print.
    7. Repeat the cleaning and the quality check process following the Step 4-7.
    Jun 02, 2011 | Brother MFC 6490CW InkJet Printer
    I have a macbook and an hp2600n printer and i have never gotten a good color print on it. do you know if I need to install something so the colors that you see in the computer are similar to what the...
    Improving print quality Use the print-quality settings in the HP Toolbox to improve print-quality problems. The following menus contain paper type, print mode, and print-quality settings. To restore the default settings, open the HP Toolbox and click Device Settings. Then click Settings, Service, and in Restore Factory Settings, click Restore. Paper Types menu The purpose of this menu is to specify the print mode for paper types which are non-specific. To make changes in the Paper Types menu, make the desired selections and click Apply. Print quality menu Under the Print Quality menu in HP Toolbox, there will be an Optimize section containing a number of On/Off adjustments which will apply to all media types.
    Oct 26, 2010 | HP Color LaserJet 2600n Printer
    Samsung ml1710 printer has both lights blinking after giving it for test print through printer button
    First, pull the tray out. Next, look for a WIDE rubber roller
    right in the middle of two smaller black rollers, that's the
    one you want to clean! Grab a lint-free rag (important!!),
    get some alcohol. Next, dampen the rag with the alcohol and
    start wiping across the wide roller so that when you rub your
    finger tip across it, your finger barley budges, this means
    it's completely clean. Now, here's the trick, there's a
    black, thin lever that hangs down on the left side under the
    bottom of the printer, this detects the paper level, it's
    hangs loosely and you can push it up easily with your finger.
    With the tray still pulled out, push the lever up so that the
    status light on the printer turns green. Now, if you're close
    enough to your computer, send one page to print while keeping
    that lever pushed in. What you want to do here is watch as
    that WIDE roller turns over to the other side where there is
    still dirt that needs to be cleaned off. You've got to be
    fast and time it right so that you can turn off the printer
    as the WIDE roller flips to the other side, cause once it
    gets there, you've got to turn the printer off to stop it
    dead in it's tracks. Getting another person to help would be
    best for this task. TRUST me, once you get that whole roller
    cleaned with alcohol, it works like new!! :)
    Sep 11, 2010 | Samsung ML 1710 Laser Printer
    Print quality: dark faded, but continuous
    Open top cover and remove toner, shake toner cartridge and try a test print. IF image good then problem is low toner level in cartridge.
    Apr 01, 2010 | HP LaserJet 4 plus Printer
    Our Dell 3100CN printer blocks out a 1/2" wide line (all colors) print area on the right side. We replaced the printer drum unit and that didn't fix the problem. It was printing fine until we replaced the...
    Try the cleaning rod. visit: http://support.dell.com/support/edocs/systems/3100cn/en/ug/section22.html
    for images (under replacing the "cleaning rod pad") for where to find the cleaning rod. You likely don't need to replace the pad, just use the rod (pull out and push in 10X) and try to print again.
    Cheers
    Oct 22, 2009 | Dell 3100cn Laser Printer
    Black vertical line (1 inch wide) appears while scanning/copying
    For this kind of problem you need to call the tech support because the printer is already messed up and it is in need of replacement
    Hope this help
    Byron
    Jun 15, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
    OkiC5200 has an inch wide faded print line down the left side
    It might be a dirty led assembly. The leds hang down from the top when it is opened.
    May 03, 2009 | OKI C5200n Laser Printer
    Black line on right side of prints
    the drum life is over, change PC drum, also you may clean laser glass whats under the pc drum
    Jun 06, 2008 | Konica Minolta magicolor 2400 Laser...
    Dell 3000cn Laser Printer Logo
    124 people viewed this question
    Top Dell Office Equipment & Supplies Experts
    jasbo
    jasbo
    Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
