Question about Saeco Vienna De Luxe Espresso Machine
Water leaking at the back of the machine.
It seems as if the seal around the valve where the tank in the back joins with the gasket of the body of the machine
  • Anonymous Jan 21, 2009
    I have a Saeco Vienna Deluxe which I purchase about 3 years ago. Water leaks when the machine is in use. Water is leaking towards the right side and on back. Once the coffee is dispense, I would hear a hissing sound. I went on the Saeco website but not able to open their site. Any help in getting the phone number to Saeco?
    Problem Solver:
  • 11 Answers
It may be your boiler leaking and not the tank. If you can open the case, check your boiler for white chalk like build up around the seams. That would confirm you leak is from the boiler.
Best Wishes,
Lane
Posted on Jan 18, 2009
Toilet tank leaking
Hello David McInnis,
There are Three basic opportunities for leaks from the classic TOILET TANK DESIGN (separate BASE & top-tank)... around the FLAPPER VALVE alone... Typically the flapper valve & two hold-down screws. These CANNOT be repaired without removing the entire tank. GREAT CARE should be used to not FRACTURE
the mated surfaces by OVER-TIGHTENING.
This is a great time to FRESHEN UP all the
Perishable gaskets & seals... and while I NEVER advocate using any ABRASIVES on gloss finishes... Pumas stone seems to be the FINAL TOUCH in a total renewal
(to REMOVE the built up (very unsightly
TOILET BOWL RING...
Amazon com toilet bowl pumice stone
ADDITIONAL PARTS:
- Water fitting to FILL VALVE (compression fitting).
- FILL VALVE through tank (gaskets)
- Flapper Valve base, gaskets & bowl interface ring
TO Make sure all the surfaces are clean an firmly
positioned and it is not LEAKING anywhere... place
clean dry paper on the floor behind the bowl
(under the tank).
EACH/EVERY drop will leave a mark...
Do NOT over-tighten any fittings!!!
If the WALL VALVE is less than NIMBLE... also a great opportunity to UPGRADE TO A QUARTER TURN
BALL VALVE... A little shopping will find you EXACT VALVE CONFIGURATION...
Hope this helps.
LASCO 04 3809 Toilet Tank To Bowl Bolt Kit Brass Bolts with Washers Hex...
Fluidmaster 6106 2 3 4 Inch Tank to Bowl with Three Bolts and Gasket...
BrassCraft G2CR19X C1 1 2 in NOM Comp Inlet 3 8 in OD Compression Outlet...
Kohler 1068031 Fill Valve Flush Valves Amazon com
Apr 02, 2017 | Plumbing
My Gaggia Syncrony Compact has developed some sort of leak. Every few days I notice a pool of water spreading across the countertop in our pantry and pooled under the machine. The leak might be happening...
HI
I would suspect the seal on the machine where the tank sets on the machine. There is a plastic cap that looks like a doughnut, that will pry off (there are 2 hooks, 1 on each side). The seal is under neath. If you can stick your finger in the center of the seal and lift it out it needs to be replaced. When you put the new one in, run your finger nail around the outside edge of the seal to get it to slip in or you could damage the new seal.
Oct 24, 2010 | Gaggia Syncrony Compact Coffee...
Bunn coffee maker leaks water only during operation...near end of the cycle (not when it just sits & not when water is first added).
There is a gasket where the water inters the tank,you have to remove the tank to get to it .mark down how it is wired so you can hook it back up.Use a high-temp
silacone ( auto ) and seal it under the the gasket and around the edge of the gasket.. 2 screws holding the metal plate plate. 4 screws holding tank need a 12 or 14 " phillips to reach down on the side of the tank to remove outer cover.
Oct 08, 2009 | Bunn NHB Coffee Maker
I have water leaking from the bottom of my waterheater PE50T9A
It is possible that the water heater has a leak at the bottom. They eventually rust out. The valve should be removed if it is leaking and you should replace it. They are cheap. Be sure to use teflon tape to seal it back up
Apr 27, 2009 | Water Heaters
Saeco Vienna leaks water from water tank
Sorry for the delay in response but I just read your complaint. I had similar water leakage issues and mistakenly replaced a bunch of stuff without stopping the leaks, until I discovered the real problem; the O ring seal that the water reservoir sits in located under the reservoir where it mates with the machine. Easy to replace and cheap. No leakage problems since I both replaced the O ring and started the routine of not taking off the water reservoir to fill it, but leaving it in place and filling it from a bottle. That technique does not any wear at all on the seal ring and so it won't leak in the future.
The item is called a "Saeco-water inlet valve gasket" , has a part number of NM05.006 and costs $7.50. I purchased it from Services Unlimited located at 650 N. Cannon Ave. WH-305, Lansdale PA 19446; phone 215-361-7000 Fax 215-361-7434, e mail granita@rcn.com but you can find it at any authorized dealer, I am sure. I ordered two and with shipping the cost came to $21.50.
You can request a fax with a parts diagram and listing, which I found most helpful in diagnosing issues and see where stuff goes..
Hope this helps you..
George W Conrad
Feb 18, 2009 | Saeco Vienna Espresso Machine
Water leaking under the tank
If the water is coming from under the cold water tank on the back of the machine it probably the o-ring seal in the grey machine recepticle which is visable when you remove the tank for filling. This seals the tank to the machine body and over time can leak (mine has!!). You can get them from Gaggia UK in Halifax
Dec 24, 2008 | Saeco Magic De Luxe Espresso Machine
Water Tank Leak
i had the same problem what i suggest to you clean where the water tank were its sit very good put the tank back me i never remove the water tank i clean regualy i put the tank empty on the machine and fill it with a glass never leak again pierre
Dec 08, 2008 | Saeco Vienna SuperAutomatica Coffee...
American standard cadet 3 leaking around seal
get a new filler assembly. the water in the tank is heavy enough to close the seal completely. or the rubber seal is not making contact. thats' why the leak.
change the whole assemble ususally correct the problem.
adjuste the flow to about 1/4 to 1/3 under the over flow. if that still don't give you the pressure. you ca adjust the flow tube to 1/5 under the cover. that is the max.
Oct 28, 2008 | American Standard 2294.011.020 Afwall...
Saeco Royal Exclusive expresso
hello you say sometime water leak out normally when the water valve seal is defective it will always leak. look under the water tank you got 4 plastic guide moulded in the container make sure no guide broken or missing a little pease of plastic if you got a pease missing add whatever missing inthe hole like a shim check it out cheers
Jan 11, 2008 | Saeco Royal Exclusive 30153 Espresso...
Pump prime lost
After further examination of the pump I re-installed it in the machine and removed the inlet hose from the mixer valve body and placed the end in a shallow pan of water. I turned the machine on and the pimp picked up the water from the pan and pumped without failure for several minutes as I had the pump output refilling the same pan.
If I take the end of the inlet hose out of the pan for only a couple of seconds, the pump loses prime and will not recover until I remove the vacuum hose from the pump. Upon replacing the vacuum hose the pump primes and begins working.
At that point I suspected an air leak at the base of the water tank or somewhere in the mixer valve assembly. I then took the hose off of the tank fitting in the base and placed the end of the hose in the pan of water. Again, the pump performed without any problem. Therefore, I assume I have an air leak at the base of the tank where the tank connects to the machine.
I will explore this further and provide you with additional info as I make progress
Jan 06, 2008 | Bissell 1697-7 Powersteamer Pro Deluxe...
Saeco Vienna De Luxe Espresso Machine Logo
113 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
