Question about Maytag MAH6500 Neptune Front Loading Washer w/Built in Water Heater
My neptune washer will not drain the fabric softner container
The fabric softner tray will not drain completly. I've removed it and cleaned it.
    Scholar:
  • 99 Answers
This is joyce
I have advice for you check the siphon cap to see if its twisted reposition cap.
thanks
joyce
Posted on Feb 06, 2009
My washer wont drain out the fabric softner just adds water to it. cleaned the part where i put the softner thinking it was clogged but still happening.
Usually, the softener syphons out from the tray. The tray will have a tube, the tube will have a cap. Water filling the tray forces the liquid around the cap and tube. The falling water (now inside the tube) creates a vacuum-syphon effect.
Pull the tray, remove the cap, clean and try again. Provided the water's getting there, this should help.
Regards! --W/D--
Jul 14, 2009 | Frigidaire ATF6000ES Front Load Washer
Softner cup is not draining completely on Maytag Neptune TL
Dot,
If your machine is a FAV6800AW/FAV9800AW See if this post will help you. Once the Fabric Softener top is removed you can flush the dispenser and run some pipe cleaners thru the exit ports to help remove some gunk. If there is a water flow issue into the Fabric Softener dispenser then further investigation may need to take place. I discuss how I would start the troubleshooting for that as a possible issue. Rich
May 28, 2009 | Maytag Neptune FAV6800AW Top Load Washer
FABRIC SOFTNER TRAY STAYS FULL AND IS NOT RINSEING OUT
HiYa dh1200s
The softener tray needs to be cleaned out or the sensor for this replaced.
Yes, not enough water entering machine so not enough water to rinse out the softner
Please leave a good rating before you sign off.
Mar 29, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Jetstream 1200 wont take away fabric softner
strip and clean out the soap tray then remove the tray and clean the fill water holes above it with a stiff washing up brush.
Mar 16, 2009 | Zanussi ZWF1430W Front Load Washer
Tray that holds fabric softner does not drain
I have had three sepaerate service calls and one independant analysis about this problem. For the whirlpool duet washer - this is a design flaw - nothing else - please notice that when you take the detergent tray completely out (and turn it upside down) a piece of plastic falls out but even if you put it back correctly the water only flows out into the washer - either washing everything away or leaving it behind - I have been told there is no fix.
Aug 31, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Eco Care Front load washer:Fabric softner clog
pull drawer out press down on tab rear left side and slide drawer out
Jun 04, 2008 | Kenmore 44832 Front Load Washer
NEPTUNE WASHER
"downy ball" is designed to open at the end of first spin that is the way to go without stopping machine. works very well and costs just a few dollars
Feb 07, 2008 | Maytag Neptune MAH5500B Front Load Washer
Fabric softner
Remove the dispenser tray. Inspect the area just above the fabric softener portion of the dispenser. There should be a series of holes where water feeds into the tray during the rinse cycle. Sometimes these holes become clogged with fabric softener residue. If the holes are clogged, water will never dispense the fabric softener out and it will stay in the tray. If you take some cotton swabs and meticulously clean all the holes out, I bet your problem will go away. Let me know if this was helpful to you.
Oct 05, 2007 | Frigidaire GLTF2940ES Front Load Washer
Maytag MAH6500 Neptune Front Loading Washer w/Built in Water Heater Logo
128 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
